Hi,
I tried to print multuple pdf usin bash with
lp *.pdf
in the direcotry wiht interest pdf but only 1 file is printed,
how to solve?
thankyou
Hi,
lp *.pdf
how to solve?
thankyou
Hi @matrixfede, and welcome!
One option, well the only one I can think of if the lp *.pdf command executed successfully for that one document, is writing a little bash script that loop thorough the files and exececute the command for each. Something like:
for file in directory do
lp file
enfor
Note:
This is definitely not valid code and will not work. It is just to demonstrate the technique of my answer.
Also, it might not be the only answer out there.
thankyou. I searched a lot by didn0t find anythings that works.
Although question is not about printing - but the principle is valid for printing too
I cannot say this will work for printing your files but if you can make one file print then you may be able to use something like this - please do adjust for your specific use case - I have not tested - just copy-pasted
This is actually what I initially thought would do it - but did a search so maybe you could learn from it
$ find -name '*.pdf' -exec lp {} \;
thank you this works
