Printing used to work fine but for some reason I don’t know it stopped working. My printer is a M2070FW (Samsung).
I took the logs from the journal:
Nov 26 09:27:27 amaury-pc dbus-daemon[763]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Unit dbus-org.freedesktop.Avahi.service not found.
Nov 26 09:27:27 amaury-pc dbus-daemon[763]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.2886' (uid=1000 pid=21780 comm="gnome-control-center printers " label="unconfined")
Nov 26 09:27:27 amaury-pc cupsd[21942]: free(): invalid pointer
Nov 26 09:27:27 amaury-pc audit[21942]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 subj==unconfined pid=21942 comm="cupsd" exe="/usr/bin/cupsd" sig=6 res=1
Nov 26 09:27:27 amaury-pc kernel: kauditd_printk_skb: 1 callbacks suppressed
Nov 26 09:27:27 amaury-pc kernel: audit: type=1701 audit(1606379247.074:485): auid=4294967295 uid=0 gid=0 ses=4294967295 subj==unconfined pid=21942 comm="cupsd" exe="/usr/bin/cupsd" sig=6 res=1
Nov 26 09:27:27 amaury-pc audit: BPF prog-id=34 op=LOAD
Nov 26 09:27:27 amaury-pc kernel: audit: type=1334 audit(1606379247.087:486): prog-id=34 op=LOAD
Nov 26 09:27:27 amaury-pc kernel: audit: type=1334 audit(1606379247.087:487): prog-id=35 op=LOAD
Nov 26 09:27:27 amaury-pc audit: BPF prog-id=35 op=LOAD
Nov 26 09:27:27 amaury-pc systemd[1]: Started Process Core Dump (PID 21989/UID 0).
Nov 26 09:27:27 amaury-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@4-21989-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 26 09:27:27 amaury-pc kernel: audit: type=1130 audit(1606379247.091:488): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@4-21989-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 26 09:27:27 amaury-pc systemd[1]: org.cups.cupsd.service: Main process exited, code=dumped, status=6/ABRT
Nov 26 09:27:27 amaury-pc dbus-daemon[763]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.2887' (uid=1000 pid=21780 comm="gnome-control-center printers " label="unconfined")
Nov 26 09:27:27 amaury-pc gsd-color[1830]: failed to connect to device: Failed to connect to missing device /org/freedesktop/ColorManager/devices/cups_M2070FW
Nov 26 09:27:27 amaury-pc systemd-coredump[21990]: [🡕] Process 21942 (cupsd) of user 0 dumped core.
Stack trace of thread 21942:
#0 0x00007f6228bd4615 raise (libc.so.6 + 0x3d615)
#1 0x00007f6228bbd862 abort (libc.so.6 + 0x26862)
#2 0x00007f6228c165e8 __libc_message (libc.so.6 + 0x7f5e8)
#3 0x00007f6228c1e27a malloc_printerr (libc.so.6 + 0x8727a)
#4 0x00007f6228c1f64c _int_free (libc.so.6 + 0x8864c)
#5 0x00007f6228d99f0f n/a (libcups.so.2 + 0x39f0f)
#6 0x00007f6228d99dcb ippDelete (libcups.so.2 + 0x39dcb)
#7 0x0000558d5287489c n/a (/usr/bin/cupsd + 0x1389c)
Nov 26 09:27:27 amaury-pc systemd[1]: systemd-coredump@4-21989-0.service: Succeeded.
Nov 26 09:27:27 amaury-pc kernel: audit: type=1131 audit(1606379247.401:489): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@4-21989-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 26 09:27:27 amaury-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@4-21989-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 26 09:27:27 amaury-pc systemd[1]: org.cups.cupsd.service: Failed with result 'core-dump'.
Nov 26 09:27:27 amaury-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Nov 26 09:27:27 amaury-pc kernel: audit: type=1131 audit(1606379247.441:490): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Nov 26 09:27:27 amaury-pc audit: BPF prog-id=35 op=UNLOAD
Nov 26 09:27:27 amaury-pc audit: BPF prog-id=34 op=UNLOAD
Nov 26 09:27:27 amaury-pc kernel: audit: type=1334 audit(1606379247.501:491): prog-id=35 op=UNLOAD
Nov 26 09:27:27 amaury-pc kernel: audit: type=1334 audit(1606379247.501:492): prog-id=34 op=UNLOAD
Nov 26 09:27:27 amaury-pc systemd[1]: org.cups.cupsd.service: Scheduled restart job, restart counter is at 5.
Nov 26 09:27:27 amaury-pc systemd[1]: Stopped CUPS Scheduler.
Nov 26 09:27:27 amaury-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 26 09:27:27 amaury-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 26 09:27:27 amaury-pc systemd[1]: org.cups.cupsd.path: Succeeded.
Nov 26 09:27:27 amaury-pc systemd[1]: Stopping CUPS Scheduler.
Nov 26 09:27:27 amaury-pc systemd[1]: Started CUPS Scheduler.
Nov 26 09:27:27 amaury-pc kernel: audit: type=1130 audit(1606379247.604:493): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 26 09:27:27 amaury-pc kernel: audit: type=1131 audit(1606379247.604:494): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 26 09:27:27 amaury-pc systemd[1]: org.cups.cupsd.socket: Succeeded.
Nov 26 09:27:27 amaury-pc systemd[1]: Closed CUPS Scheduler.
Nov 26 09:27:27 amaury-pc systemd[1]: Listening on CUPS Scheduler.
Nov 26 09:27:27 amaury-pc systemd[1]: Starting CUPS Scheduler...
Nov 26 09:27:27 amaury-pc dbus-daemon[763]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.2888' (uid=1000 pid=21780 comm="gnome-control-center printers " label="unconfined")
Nov 26 09:27:48 amaury-pc gnome-shell[1674]: setup_framebuffers: assertion 'width > 0' failed
One can see that cups crashes followed by a systemd core dump. After a few retries, the cups service just restarts and forgets about the print job. In the GNOME settings, I can see the printer disappearing from the list of printers and reappearing later.
I’d appreciate greatly any idea about what could be going wrong or how I could fix things.
