Prime-run only works for glxgears
When I execute prime-run brave for example, it dosn’t use the dGpu (I check it using nvtop)
I’m using an asus laptop with hybrid intel-nvidia(940m) gpu
prime-run glxinfo | grep "OpenGL"
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: NVIDIA GeForce 940M/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 470.129.06
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6.0 NVIDIA 470.129.06
OpenGL shading language version string: 4.60 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 470.129.06
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
mhwd -li
Installed PCI configs:
video-hybrid-intel-nvidia-470xx-prime            2021.12.18               false            PCI
lsmod | grep nvidia
nvidia_uvm           2576384  0
nvidia_drm             73728  2
nvidia_modeset       1204224  2 nvidia_drm
nvidia              35401728  76 nvidia_uvm,nvidia_modeset
nvidia-smi
Fri Jul 29 21:23:55 2022
| NVIDIA-SMI 470.129.06   Driver Version: 470.129.06   CUDA Version: 11.4     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   45C    P8    N/A /  N/A |      3MiB /  2004MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A       874      G   /usr/lib/Xorg                       2MiB |
Thanks for advance
Hi @Jokin22,
By default Chromium on Linux does not use any GPU acceleration. You can follow the Chromium ArchWiki page as Brave is based on Chromium:
https://wiki.archlinux.org/title/Chromium#Force_GPU_acceleration
There is also a dedicated HowTo in this forum:
I think you totally misinterpreted/misunderstood that.
