My DE just froze. Here are the logs:
journalctl -b0 -p4 --no-pager 1 ✘
mar 30 15:24:06 mr-mnjro kernel: #7 #8 #9 #10 #11
mar 30 15:24:06 mr-mnjro kernel: Expanded resource Reserved due to conflict with PCI Bus 0000:00
mar 30 15:24:06 mr-mnjro systemd[1]: Configuration file /etc/systemd/system/windscribe-helper.service is marked executable. Please remove executable permission bits. Proceeding anyway.
mar 30 15:24:06 mr-mnjro systemd-modules-load[365]: Failed to find module 'vboxdrv'
mar 30 15:24:06 mr-mnjro systemd-modules-load[365]: Failed to find module 'vboxnetadp'
mar 30 15:24:06 mr-mnjro systemd-modules-load[365]: Failed to find module 'vboxnetflt'
mar 30 15:24:07 mr-mnjro kernel: nvidia: loading out-of-tree module taints kernel.
mar 30 15:24:07 mr-mnjro kernel: nvidia: module license 'NVIDIA' taints kernel.
mar 30 15:24:07 mr-mnjro kernel: Disabling lock debugging due to kernel taint
mar 30 15:24:08 mr-mnjro kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 525.89.02 Wed Feb 1 23:23:25 UTC 2023
mar 30 15:24:08 mr-mnjro kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
mar 30 15:24:08 mr-mnjro bluetoothd[678]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
mar 30 15:24:08 mr-mnjro bluetoothd[678]: src/plugin.c:plugin_init() Failed to init vcp plugin
mar 30 15:24:08 mr-mnjro bluetoothd[678]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
mar 30 15:24:08 mr-mnjro bluetoothd[678]: src/plugin.c:plugin_init() Failed to init mcp plugin
mar 30 15:24:08 mr-mnjro bluetoothd[678]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
mar 30 15:24:08 mr-mnjro bluetoothd[678]: src/plugin.c:plugin_init() Failed to init bap plugin
mar 30 15:24:11 mr-mnjro systemd[784]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
mar 30 15:24:11 mr-mnjro systemd[784]: Failed to start Update XDG user dir configuration.
mar 30 15:24:12 mr-mnjro sddm-greeter[794]: QFont::fromString: Invalid description '(empty)'
mar 30 15:24:12 mr-mnjro sddm-greeter[794]: file:///usr/lib/qt/qml/SddmComponents/LayoutBox.qml:35:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 30 15:24:12 mr-mnjro sddm-greeter[794]: file:///usr/share/sddm/themes/elarun/Main.qml:40:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 30 15:24:12 mr-mnjro sddm-greeter[794]: file:///usr/share/sddm/themes/elarun/Main.qml:155: ReferenceError: session_button is not defined
mar 30 15:24:12 mr-mnjro sddm-greeter[794]: file:///usr/share/sddm/themes/elarun/Main.qml:175: ReferenceError: session_button is not defined
mar 30 15:24:12 mr-mnjro kernel: kauditd_printk_skb: 64 callbacks suppressed
mar 30 15:24:14 mr-mnjro systemd[1]: pkgfile-update.service: Failed with result 'exit-code'.
mar 30 15:24:14 mr-mnjro systemd[1]: Failed to start pkgfile database update.
mar 30 15:24:18 mr-mnjro kernel: kauditd_printk_skb: 27 callbacks suppressed
mar 30 15:24:39 mr-mnjro kernel: kauditd_printk_skb: 15 callbacks suppressed
mar 30 15:25:11 mr-mnjro sddm-helper[864]: [PAM] authenticate: Authentication failure
mar 30 15:25:11 mr-mnjro sddm[766]: Authentication error: "Authentication failure"
mar 30 15:25:11 mr-mnjro sddm[766]: Auth: sddm-helper exited with 1
mar 30 15:25:16 mr-mnjro ksplashqml[899]: file:///home/mr1077/.local/share/plasma/look-and-feel/com.github.vinceliuice.Orchis-dark/contents/splash/Splash.qml:89: ReferenceError: bottomRect is not defined
mar 30 15:25:16 mr-mnjro ksplashqml[899]: file:///home/mr1077/.local/share/plasma/look-and-feel/com.github.vinceliuice.Orchis-dark/contents/splash/Splash.qml:88: ReferenceError: bottomRect is not defined
mar 30 15:25:16 mr-mnjro baloo_file[914]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.33'
mar 30 15:25:16 mr-mnjro ksmserver[972]: Qt: Session management error: networkIdsList argument is NULL
mar 30 15:25:17 mr-mnjro ksmserver[972]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.15'
mar 30 15:25:17 mr-mnjro kwin_x11[975]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
mar 30 15:25:17 mr-mnjro kwin_x11[975]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
mar 30 15:25:17 mr-mnjro kded5[974]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.15'
mar 30 15:25:17 mr-mnjro plasmashell[1019]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
mar 30 15:25:17 mr-mnjro plasmashell[1019]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
mar 30 15:25:17 mr-mnjro kded5[974]: kscreen.kded: PowerDevil SuspendSession action not available!
mar 30 15:25:18 mr-mnjro backlighthelper[1092]: org.kde.powerdevil: no kernel backlight interface found
mar 30 15:25:18 mr-mnjro ksplashqml[899]: file:///home/mr1077/.local/share/plasma/look-and-feel/com.github.vinceliuice.Orchis-dark/contents/splash/Splash.qml:89: ReferenceError: bottomRect is not defined
mar 30 15:25:18 mr-mnjro org_kde_powerdevil[1050]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
mar 30 15:25:18 mr-mnjro org_kde_powerdevil[1050]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
mar 30 15:25:18 mr-mnjro pipewire[1107]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
mar 30 15:25:18 mr-mnjro pipewire[1107]: mod.rt: found session bus but no portal
mar 30 15:25:18 mr-mnjro pipewire-media-session[1108]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
mar 30 15:25:18 mr-mnjro pipewire-media-session[1108]: mod.rt: found session bus but no portal
mar 30 15:25:19 mr-mnjro org_kde_powerdevil[1050]: org.kde.powerdevil: Handle button events action could not check for screen configuration
mar 30 15:25:19 mr-mnjro org_kde_powerdevil[1050]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
mar 30 15:25:19 mr-mnjro org_kde_powerdevil[1050]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
mar 30 15:25:19 mr-mnjro plasmashell[1019]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
mar 30 15:25:19 mr-mnjro plasmashell[1019]: file:///usr/lib/qt/qml/org/kde/plasma/private/containmentlayoutmanager/BasicAppletContainer.qml:144: TypeError: Cannot read property 'width' of null
mar 30 15:25:20 mr-mnjro plasmashell[1019]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
mar 30 15:25:20 mr-mnjro plasmashell[1019]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
mar 30 15:25:20 mr-mnjro plasmashell[1019]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
mar 30 15:25:20 mr-mnjro plasmashell[1019]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
mar 30 15:25:21 mr-mnjro plasmashell[1019]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
mar 30 15:25:21 mr-mnjro plasmashell[1019]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
mar 30 15:25:21 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:58:17: Unable to assign [undefined] to int
mar 30 15:25:21 mr-mnjro plasmashell[1019]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5633b12e1d80) QQmlContext(0x5633b0161c10) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
mar 30 15:25:21 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
mar 30 15:25:21 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
mar 30 15:25:21 mr-mnjro plasmashell[1019]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/InfiniteList.qml:43:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 30 15:25:22 mr-mnjro plasmashell[1019]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/MonthView.qml:381: TypeError: Cannot read property 'cellHeight' of null
mar 30 15:25:22 mr-mnjro plasmashell[1019]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/InfiniteList.qml:43:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 30 15:25:22 mr-mnjro plasmashell[1019]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
mar 30 15:25:22 mr-mnjro kwin_x11[975]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
mar 30 15:25:22 mr-mnjro plasmashell[1019]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/TabBar.qml:21:18: QML ListView: Binding loop detected for property "implicitWidth"
mar 30 15:25:22 mr-mnjro plasmashell[1019]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/private/IconLabel.qml:55:5: QML GridLayout: Binding loop detected for property "width"
mar 30 15:25:22 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.weather/contents/ui/SwitchPanel.qml:69:5: QML TabBar: Binding loop detected for property "implicitWidth"
mar 30 15:25:22 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 4821, resource id: 16777378, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 15:25:23 mr-mnjro kernel: kauditd_printk_skb: 3 callbacks suppressed
mar 30 15:25:23 mr-mnjro plasmashell[1019]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
mar 30 15:25:24 mr-mnjro plasmashell[1019]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
mar 30 15:25:24 mr-mnjro rtkit-daemon[944]: Warning: Reached burst limit for user '1000', denying request.
mar 30 15:25:24 mr-mnjro pulseaudio[1349]: stat('/etc/pulse/default.pa.d'): No such file or directory
mar 30 15:25:25 mr-mnjro plasmashell[1019]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
mar 30 15:25:25 mr-mnjro plasmashell[1019]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
mar 30 15:25:28 mr-mnjro plasmashell[1019]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5633b3e9b910) QQmlContext(0x5633b0161c10) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
mar 30 15:25:28 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
mar 30 15:25:28 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
mar 30 15:27:18 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
mar 30 15:29:51 mr-mnjro kstart5[2463]: Omitting both --window and --windowclass arguments is not recommended
mar 30 15:29:52 mr-mnjro konsole[2466]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
mar 30 15:29:52 mr-mnjro konsole[2466]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
mar 30 15:30:00 mr-mnjro sudo[2589]: mr1077 : a password is required ; TTY=pts/1 ; PWD=/home/mr1077 ; USER=root ; COMMAND=/sbin/file -s /dev/sdb1
mar 30 15:39:48 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
mar 30 15:45:56 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
mar 30 15:45:57 mr-mnjro dolphin[3363]: kf.kio.core: "The file or folder /run/media/mr1077/Games1 does not exist."
mar 30 15:46:03 mr-mnjro kernel: ntfs3: Unknown parameter 'windows_names'
mar 30 15:46:04 mr-mnjro kioslave5[3404]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so: Cannot load library /usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so: (libappimage.so.1.0: cannot open shared object file: No such file or directory)"
mar 30 15:46:04 mr-mnjro kioslave5[3404]: kf.kio.workers.thumbnail: Failed to load "/usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so" "Cannot load library /usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so: (libappimage.so.1.0: cannot open shared object file: No such file or directory)"
mar 30 15:46:04 mr-mnjro kioslave5[3404]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
mar 30 15:46:19 mr-mnjro plasmashell[1019]: kf.sonnet.core: No language dictionaries for the language: "en_US"
mar 30 15:46:19 mr-mnjro plasmashell[1019]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
mar 30 15:46:19 mr-mnjro plasmashell[1019]: libpng warning: iCCP: known incorrect sRGB profile
mar 30 15:46:19 mr-mnjro plasmashell[1019]: libpng warning: known incorrect sRGB profile
mar 30 15:46:19 mr-mnjro plasmashell[1019]: libpng warning: profile matches sRGB but writing iCCP instead
mar 30 15:46:21 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
mar 30 15:46:23 mr-mnjro kioslave5[3584]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
mar 30 15:46:23 mr-mnjro steam[3559]: Unable to locate theme engine in module_path: "adwaita",
mar 30 15:46:25 mr-mnjro steam[3559]: gtk_disable_setlocale() must be called before gtk_init()
mar 30 15:46:34 mr-mnjro kwin_x11[975]: kwin_core: Failed to focus 0x400079 (error 8)
mar 30 15:46:34 mr-mnjro kwin_x11[975]: kwin_core: Failed to restore focus. Activating 0x400021
mar 30 15:46:58 mr-mnjro kwin_x11[975]: kwin_core: Failed to focus 0x400089 (error 8)
mar 30 15:46:58 mr-mnjro kwin_x11[975]: kwin_core: Failed to restore focus. Activating 0x400021
mar 30 15:48:05 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 3 (BadWindow), sequence: 61066, resource id: 106954763, major code: 129 (SHAPE), minor code: 3 (Combine)
mar 30 15:48:05 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 3 (BadWindow), sequence: 61067, resource id: 106954763, major code: 129 (SHAPE), minor code: 3 (Combine)
mar 30 15:48:06 mr-mnjro gameoverlayui[4324]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
mar 30 15:48:07 mr-mnjro kwin_x11[975]: kwin_core: Failed to focus 0x400093 (error 8)
mar 30 15:48:07 mr-mnjro kwin_x11[975]: kwin_core: Failed to restore focus. Activating 0x400021
mar 30 16:28:06 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 3 (BadWindow), sequence: 56232, resource id: 56623115, major code: 129 (SHAPE), minor code: 3 (Combine)
mar 30 16:28:06 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 3 (BadWindow), sequence: 56233, resource id: 56623115, major code: 129 (SHAPE), minor code: 3 (Combine)
mar 30 16:28:07 mr-mnjro gameoverlayui[4591]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
mar 30 16:28:13 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 61180, resource id: 16850624, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 16:45:18 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 45610, resource id: 16904564, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 16:47:22 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
mar 30 16:47:24 mr-mnjro kioslave5[9740]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
mar 30 16:47:29 mr-mnjro kioslave5[9740]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
mar 30 16:47:30 mr-mnjro kioslave5[9740]: libpng warning: iCCP: known incorrect sRGB profile
mar 30 16:47:34 mr-mnjro kioslave5[9740]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:40 mr-mnjro kioslave5[9762]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:42 mr-mnjro kioslave5[9770]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:43 mr-mnjro kioslave5[9777]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:44 mr-mnjro kioslave5[9782]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:45 mr-mnjro kioslave5[9788]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:46 mr-mnjro kioslave5[9793]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:47 mr-mnjro kioslave5[9798]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:48 mr-mnjro kioslave5[9802]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:49 mr-mnjro kioslave5[9807]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:50 mr-mnjro kioslave5[9812]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:53 mr-mnjro kioslave5[9846]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:54 mr-mnjro kioslave5[9851]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:54 mr-mnjro kioslave5[9856]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:55 mr-mnjro kioslave5[9860]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:56 mr-mnjro kioslave5[9865]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:56 mr-mnjro kioslave5[9871]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:47:59 mr-mnjro kioslave5[9875]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:48:02 mr-mnjro kioslave5[9881]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:48:05 mr-mnjro kioslave5[9895]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:48:06 mr-mnjro kioslave5[9899]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:48:08 mr-mnjro kioslave5[9904]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:48:09 mr-mnjro kioslave5[9909]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:48:12 mr-mnjro kioslave5[9918]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 16:48:39 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 49312, resource id: 16918381, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 16:51:30 mr-mnjro kded5[974]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
mar 30 16:51:30 mr-mnjro plasmashell[1019]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/2”"
mar 30 16:51:30 mr-mnjro kdeconnectd[1138]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/2”"
mar 30 16:51:30 mr-mnjro kded5[974]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/2”"
mar 30 16:51:31 mr-mnjro kscreenlocker_greet[10145]: Qt: Session management error: networkIdsList argument is NULL
mar 30 16:51:31 mr-mnjro kscreenlocker_greet[10145]: kf.kirigami: Failed to find a Kirigami platform plugin
mar 30 16:51:31 mr-mnjro kscreenlocker_greet[10145]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:151: TypeError: Cannot call method 'createObject' of undefined (exception occurred during delayed function evaluation)
mar 30 17:04:27 mr-mnjro kernel: xhci_hcd 0000:03:00.0: xHC error in resume, USBSTS 0x401, Reinit
mar 30 17:04:27 mr-mnjro kernel: done.
mar 30 17:04:28 mr-mnjro kscreenlocker_greet[10145]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
mar 30 17:04:29 mr-mnjro plasmashell[1019]: qt.qpa.clipboard: QXcbClipboard::setMimeData: Cannot set X11 selection owner
mar 30 17:04:30 mr-mnjro plasmashell[1019]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
mar 30 17:04:30 mr-mnjro plasmashell[1019]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5633b10d4130) QQmlContext(0x5633b0161c10) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
mar 30 17:04:30 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
mar 30 17:04:30 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
mar 30 17:04:34 mr-mnjro kded5[974]: org.kde.plasma.nm.kded: Unhandled active connection state change: 1
mar 30 17:04:34 mr-mnjro plasmashell[1019]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5633b49fcc60) QQmlContext(0x5633b0161c10) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
mar 30 17:04:34 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
mar 30 17:04:34 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
mar 30 17:04:40 mr-mnjro kernel: kauditd_printk_skb: 16 callbacks suppressed
mar 30 17:10:33 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
mar 30 17:11:35 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 49238, resource id: 16940210, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 17:22:19 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 29126, resource id: 16983139, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 17:23:22 mr-mnjro plasmashell[1019]: kf.sonnet.core: No language dictionaries for the language: "en_US"
mar 30 17:23:26 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 9982, resource id: 16988063, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 17:23:26 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 9986, resource id: 16988067, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 17:23:26 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 9990, resource id: 16988071, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 17:23:29 mr-mnjro VirtualBoxVM[12949]: QSettings::value: Empty key passed
mar 30 17:23:38 mr-mnjro kstart5[12957]: Omitting both --window and --windowclass arguments is not recommended
mar 30 17:23:39 mr-mnjro konsole[12960]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
mar 30 17:23:39 mr-mnjro konsole[12960]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
mar 30 17:23:51 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 27847, resource id: 16989524, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 17:23:51 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 27851, resource id: 16989528, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 17:23:51 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 27855, resource id: 16989532, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 17:27:33 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 33962, resource id: 17004167, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 17:28:05 mr-mnjro VirtualBoxVM[12949]: <html><b>Kernel driver not installed (rc=-1908)</b><br/><br/>The VirtualBox Linux kernel driver is either not loaded or not set up correctly. Please try setting it up again by executing<br/><br/> <font color=blue>'/sbin/vboxconfig'</font><br/><br/>as root.<br/><br/>If your system has EFI Secure Boot enabled you may also need to sign the kernel modules (vboxdrv, vboxnetflt, vboxnetadp, vboxpci) before you can load them. Please see your Linux system's documentation for more information.<br><br><!--EOM-->where: suplibOsInit
what: 3
VERR_VM_DRIVER_NOT_INSTALLED (-1908) - The support driver is not installed. On linux, open returned ENOENT.
</html>
mar 30 17:28:05 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 51680, resource id: 16988536, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 17:28:05 mr-mnjro systemd-coredump[13853]: [🡕] Process 12949 (VirtualBoxVM) of user 1000 dumped core.
Stack trace of thread 12949:
#0 0x00007faaed5858ec n/a (libc.so.6 + 0x878ec)
#1 0x00007faaed536ea8 raise (libc.so.6 + 0x38ea8)
#2 0x00007faaed52053d abort (libc.so.6 + 0x2253d)
#3 0x00007faaeac9fede _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0x9fede)
#4 0x00007faaed40b859 TrustedError (VirtualBoxVM.so + 0x52859)
#5 0x0000557b3eab4a7e n/a (VirtualBoxVM + 0x4a7e)
#6 0x0000557b3eab4b0c n/a (VirtualBoxVM + 0x4b0c)
#7 0x0000557b3eab51af n/a (VirtualBoxVM + 0x51af)
#8 0x0000557b3eab5659 n/a (VirtualBoxVM + 0x5659)
#9 0x00007faaed521790 n/a (libc.so.6 + 0x23790)
#10 0x00007faaed52184a __libc_start_main (libc.so.6 + 0x2384a)
#11 0x0000557b3eab3245 n/a (VirtualBoxVM + 0x3245)
Stack trace of thread 12951:
#0 0x00007faaed5f89df __poll (libc.so.6 + 0xfa9df)
#1 0x00007faaed39b26b n/a (libxcb.so.1 + 0xd26b)
#2 0x00007faaed39cd1d xcb_wait_for_event (libxcb.so.1 + 0xed1d)
#3 0x00007faae5b2c252 n/a (libQt5XcbQpa.so.5 + 0x62252)
#4 0x00007faaeace432a n/a (libQt5Core.so.5 + 0xe432a)
#5 0x00007faaed583bb5 n/a (libc.so.6 + 0x85bb5)
#6 0x00007faaed605d90 n/a (libc.so.6 + 0x107d90)
Stack trace of thread 12950:
#1 0x00007faae8cc5c2f n/a (libglib-2.0.so.0 + 0xacc2f)
#2 0x00007faae8c6d0e2 g_main_context_iteration (libglib-2.0.so.0 + 0x540e2)
#3 0x00007faaeaed8c6c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d8c6c)
#4 0x00007faaeae866ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2866ec)
#5 0x00007faaeace725f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe725f)
#6 0x00007faaeaabbcba n/a (libQt5DBus.so.5 + 0x23cba)
#7 0x00007faaeace432a n/a (libQt5Core.so.5 + 0xe432a)
#8 0x00007faaed583bb5 n/a (libc.so.6 + 0x85bb5)
#9 0x00007faaed605d90 n/a (libc.so.6 + 0x107d90)
mar 30 17:29:14 mr-mnjro plasmashell[1019]: kf.sonnet.core: No language dictionaries for the language: "en_US"
mar 30 17:29:17 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
mar 30 17:29:17 mr-mnjro systemsettings[13959]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
mar 30 17:29:17 mr-mnjro systemsettings[13959]: QFSFileEngine::open: No file name specified
mar 30 17:29:17 mr-mnjro systemsettings[13959]: kf.coreaddons.desktopparser: Error: Failed to open ""
mar 30 17:29:17 mr-mnjro systemsettings[13959]: QFileDevice::seek: IODevice is not open
mar 30 17:29:17 mr-mnjro systemsettings[13959]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
mar 30 17:29:17 mr-mnjro systemsettings[13959]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "implicitHeight"
mar 30 17:29:21 mr-mnjro systemsettings[13959]: QFSFileEngine::open: No file name specified
mar 30 17:29:21 mr-mnjro systemsettings[13959]: kf.coreaddons.desktopparser: Error: Failed to open ""
mar 30 17:29:21 mr-mnjro systemsettings[13959]: QFileDevice::seek: IODevice is not open
mar 30 17:29:29 mr-mnjro kinfocenter[13988]: kf.xmlgui: cannot find .rc file "kinfocenterui.rc" for component "kinfocenter"
mar 30 17:29:29 mr-mnjro kinfocenter[13988]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
mar 30 17:29:30 mr-mnjro kinfocenter[13988]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
mar 30 17:29:30 mr-mnjro kinfocenter[13988]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "implicitHeight"
mar 30 17:29:38 mr-mnjro plasmashell[1019]: kf.sonnet.core: No language dictionaries for the language: "en_US"
mar 30 17:37:23 mr-mnjro plasmashell[1019]: kf.sonnet.core: No language dictionaries for the language: "en_US"
mar 30 17:37:26 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 30518, resource id: 17037591, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 17:37:26 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 30522, resource id: 17037595, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 17:37:26 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 30526, resource id: 17037599, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 17:37:29 mr-mnjro VirtualBoxVM[14969]: QSettings::value: Empty key passed
mar 30 17:37:34 mr-mnjro VirtualBoxVM[14969]: <html><b>Kernel driver not installed (rc=-1908)</b><br/><br/>The VirtualBox Linux kernel driver is either not loaded or not set up correctly. Please try setting it up again by executing<br/><br/> <font color=blue>'/sbin/vboxconfig'</font><br/><br/>as root.<br/><br/>If your system has EFI Secure Boot enabled you may also need to sign the kernel modules (vboxdrv, vboxnetflt, vboxnetadp, vboxpci) before you can load them. Please see your Linux system's documentation for more information.<br><br><!--EOM-->where: suplibOsInit
what: 3
</html>
mar 30 17:37:34 mr-mnjro systemd-coredump[14977]: [🡕] Process 14969 (VirtualBoxVM) of user 1000 dumped core.
Stack trace of thread 14969:
#0 0x00007f24f75108ec n/a (libc.so.6 + 0x878ec)
#1 0x00007f24f74c1ea8 raise (libc.so.6 + 0x38ea8)
#2 0x00007f24f74ab53d abort (libc.so.6 + 0x2253d)
#3 0x00007f24f4a9fede _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0x9fede)
#4 0x00007f24f7396859 TrustedError (VirtualBoxVM.so + 0x52859)
#5 0x0000564cff0baa7e n/a (VirtualBoxVM + 0x4a7e)
#6 0x0000564cff0bab0c n/a (VirtualBoxVM + 0x4b0c)
#7 0x0000564cff0bb1af n/a (VirtualBoxVM + 0x51af)
#8 0x0000564cff0bb659 n/a (VirtualBoxVM + 0x5659)
#9 0x00007f24f74ac790 n/a (libc.so.6 + 0x23790)
#10 0x00007f24f74ac84a __libc_start_main (libc.so.6 + 0x2384a)
#11 0x0000564cff0b9245 n/a (VirtualBoxVM + 0x3245)
Stack trace of thread 14971:
#0 0x00007f24f75839df __poll (libc.so.6 + 0xfa9df)
#1 0x00007f24f732626b n/a (libxcb.so.1 + 0xd26b)
#2 0x00007f24f7327d1d xcb_wait_for_event (libxcb.so.1 + 0xed1d)
#3 0x00007f24efb2c252 n/a (libQt5XcbQpa.so.5 + 0x62252)
#4 0x00007f24f4ae432a n/a (libQt5Core.so.5 + 0xe432a)
#5 0x00007f24f750ebb5 n/a (libc.so.6 + 0x85bb5)
#6 0x00007f24f7590d90 n/a (libc.so.6 + 0x107d90)
Stack trace of thread 14970:
#1 0x00007f24f2b6dc2f n/a (libglib-2.0.so.0 + 0xacc2f)
#2 0x00007f24f2b150e2 g_main_context_iteration (libglib-2.0.so.0 + 0x540e2)
#3 0x00007f24f4cd8c6c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d8c6c)
#4 0x00007f24f4c866ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2866ec)
#5 0x00007f24f4ae725f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe725f)
#6 0x00007f24f4f84cba n/a (libQt5DBus.so.5 + 0x23cba)
#7 0x00007f24f4ae432a n/a (libQt5Core.so.5 + 0xe432a)
#8 0x00007f24f750ebb5 n/a (libc.so.6 + 0x85bb5)
#9 0x00007f24f7590d90 n/a (libc.so.6 + 0x107d90)
mar 30 17:37:35 mr-mnjro VirtualBoxVM[14991]: QSettings::value: Empty key passed
mar 30 17:37:43 mr-mnjro VirtualBoxVM[14991]: <html><b>Kernel driver not installed (rc=-1908)</b><br/><br/>The VirtualBox Linux kernel driver is either not loaded or not set up correctly. Please try setting it up again by executing<br/><br/> <font color=blue>'/sbin/vboxconfig'</font><br/><br/>as root.<br/><br/>If your system has EFI Secure Boot enabled you may also need to sign the kernel modules (vboxdrv, vboxnetflt, vboxnetadp, vboxpci) before you can load them. Please see your Linux system's documentation for more information.<br><br><!--EOM-->where: suplibOsInit
what: 3
</html>
mar 30 17:37:43 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 41589, resource id: 17038398, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 17:37:44 mr-mnjro systemd-coredump[15001]: [🡕] Process 14991 (VirtualBoxVM) of user 1000 dumped core.
Stack trace of thread 14991:
#0 0x00007fba67f188ec n/a (libc.so.6 + 0x878ec)
#1 0x00007fba67ec9ea8 raise (libc.so.6 + 0x38ea8)
#2 0x00007fba67eb353d abort (libc.so.6 + 0x2253d)
#3 0x00007fba6549fede _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0x9fede)
#4 0x00007fba67d9e859 TrustedError (VirtualBoxVM.so + 0x52859)
#5 0x000055f9a2c20a7e n/a (VirtualBoxVM + 0x4a7e)
#6 0x000055f9a2c20b0c n/a (VirtualBoxVM + 0x4b0c)
#7 0x000055f9a2c211af n/a (VirtualBoxVM + 0x51af)
#8 0x000055f9a2c21659 n/a (VirtualBoxVM + 0x5659)
#9 0x00007fba67eb4790 n/a (libc.so.6 + 0x23790)
#10 0x00007fba67eb484a __libc_start_main (libc.so.6 + 0x2384a)
#11 0x000055f9a2c1f245 n/a (VirtualBoxVM + 0x3245)
Stack trace of thread 14993:
#0 0x00007fba67f8b9df __poll (libc.so.6 + 0xfa9df)
#1 0x00007fba67d2e26b n/a (libxcb.so.1 + 0xd26b)
#2 0x00007fba67d2fd1d xcb_wait_for_event (libxcb.so.1 + 0xed1d)
#3 0x00007fba6052c252 n/a (libQt5XcbQpa.so.5 + 0x62252)
#4 0x00007fba654e432a n/a (libQt5Core.so.5 + 0xe432a)
#5 0x00007fba67f16bb5 n/a (libc.so.6 + 0x85bb5)
#6 0x00007fba67f98d90 n/a (libc.so.6 + 0x107d90)
Stack trace of thread 14992:
#1 0x00007fba6356dc2f n/a (libglib-2.0.so.0 + 0xacc2f)
#2 0x00007fba635150e2 g_main_context_iteration (libglib-2.0.so.0 + 0x540e2)
#3 0x00007fba656d8c6c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d8c6c)
#4 0x00007fba656866ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2866ec)
#5 0x00007fba654e725f _ZN7QThread4execEv (libQt5Core.so.5 + 0xe725f)
#6 0x00007fba65984cba n/a (libQt5DBus.so.5 + 0x23cba)
#7 0x00007fba654e432a n/a (libQt5Core.so.5 + 0xe432a)
#8 0x00007fba67f16bb5 n/a (libc.so.6 + 0x85bb5)
#9 0x00007fba67f98d90 n/a (libc.so.6 + 0x107d90)
mar 30 17:38:09 mr-mnjro kernel: kauditd_printk_skb: 3 callbacks suppressed
mar 30 17:38:16 mr-mnjro kioslave5[15157]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so: Cannot load library /usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so: (libappimage.so.1.0: cannot open shared object file: No such file or directory)"
mar 30 17:38:16 mr-mnjro kioslave5[15157]: kf.kio.workers.thumbnail: Failed to load "/usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so" "Cannot load library /usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so: (libappimage.so.1.0: cannot open shared object file: No such file or directory)"
mar 30 17:38:21 mr-mnjro ktraderclient5[15230]: kf.service.services: KMimeTypeTrader: MIME type "x-scheme-handler/gdlauncher" not found
mar 30 17:38:21 mr-mnjro ktraderclient5[15244]: kf.service.services: KMimeTypeTrader: MIME type "x-scheme-handler/gdlauncher" not found
mar 30 17:39:56 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 61650, resource id: 17048281, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 18:13:08 mr-mnjro plasmashell[1019]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5633b06c89e0) QQmlContext(0x5633b0161c10) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
mar 30 18:13:08 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
mar 30 18:13:08 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
mar 30 18:13:09 mr-mnjro kwin_x11[975]: kwin_core: XCB error: 152 (BadDamage), sequence: 53506, resource id: 17170237, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 30 18:20:21 mr-mnjro kwin_x11[975]: QOpenGLVertexArrayObject::destroy() failed to make VAO's context current
mar 30 18:20:30 mr-mnjro systemd-coredump[19527]: [🡕] Process 15185 (gdlauncher) of user 1000 dumped core.
Stack trace of thread 15185:
#0 0x00007fed2ed3e8ec n/a (libc.so.6 + 0x878ec)
#1 0x00007fed2ecefea8 raise (libc.so.6 + 0x38ea8)
#2 0x00007fed2ecd953d abort (libc.so.6 + 0x2253d)
#3 0x00005623f87d7ce4 n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x207bce4)
#4 0x00005623fee0d046 n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x86b1046)
#5 0x00007fed2cde2c75 n/a (/tmp/.org.chromium.Chromium.ZxwO05 + 0xfc75)
#6 0x00007fed2cde9c53 n/a (/tmp/.org.chromium.Chromium.ZxwO05 + 0x16c53)
#7 0x00005623fee0d457 n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x86b1457)
#8 0x00005623fee0e8ef n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x86b28ef)
#9 0x00005623fee0d296 n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x86b1296)
#10 0x00005623fee0dc9c n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x86b1c9c)
#11 0x00005623fee0dd0e n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x86b1d0e)
#12 0x00005623fee0e020 n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x86b2020)
#13 0x00005623f87cc7ba n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x20707ba)
#14 0x00005623fedf9c81 n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x869dc81)
#15 0x00005623fedfa1d8 n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x869e1d8)
#16 0x00005623fedc1b84 n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x8665b84)
#17 0x00005623f88abf95 n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x214ff95)
#18 0x00005623f8897140 n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x213b140)
#19 0x00005623fa88d7fb n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x41317fb)
#20 0x00005623fa88f23d n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x413323d)
#21 0x00005623fa88acc9 n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x412ecc9)
#22 0x00005623f8a69ce1 n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x230dce1)
#23 0x00005623f8a6b1de n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x230f1de)
#24 0x00005623f8a6accb n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x230eccb)
#25 0x00005623f8a6830d n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x230c30d)
#26 0x00005623f8a68af4 n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x230caf4)
#27 0x00005623f87dd79b n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x208179b)
#28 0x00007fed2ecda790 n/a (libc.so.6 + 0x23790)
#29 0x00007fed2ecda84a __libc_start_main (libc.so.6 + 0x2384a)
#30 0x00005623f845c8ea n/a (/tmp/.mount_GDLaunT5rUZu/gdlauncher + 0x1d008ea)
mar 30 18:20:34 mr-mnjro kwin_x11[975]: QOpenGLVertexArrayObject::destroy() failed to make VAO's context current
mar 30 18:20:47 mr-mnjro plasmashell[1019]: trying to show an empty dialog
mar 30 18:20:47 mr-mnjro plasmashell[1019]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
mar 30 18:32:09 mr-mnjro plasmashell[1019]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
mar 30 18:32:11 mr-mnjro kioslave5[20916]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so: Cannot load library /usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so: (libappimage.so.1.0: cannot open shared object file: No such file or directory)"
mar 30 18:32:11 mr-mnjro kioslave5[20916]: kf.kio.workers.thumbnail: Failed to load "/usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so" "Cannot load library /usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so: (libappimage.so.1.0: cannot open shared object file: No such file or directory)"
mar 30 18:32:41 mr-mnjro kioslave5[20931]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/ffmpegthumbs.so: Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
mar 30 18:32:46 mr-mnjro kioslave5[20949]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
mar 30 18:32:56 mr-mnjro kioslave5[20949]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so: Cannot load library /usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so: (libappimage.so.1.0: cannot open shared object file: No such file or directory)"
mar 30 18:32:56 mr-mnjro kioslave5[20949]: kf.kio.workers.thumbnail: Failed to load "/usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so" "Cannot load library /usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so: (libappimage.so.1.0: cannot open shared object file: No such file or directory)"
mar 30 18:32:58 mr-mnjro kioslave5[21029]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
mar 30 18:32:58 mr-mnjro kioslave5[21029]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so: Cannot load library /usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so: (libappimage.so.1.0: cannot open shared object file: No such file or directory)"
mar 30 18:32:58 mr-mnjro kioslave5[21029]: kf.kio.workers.thumbnail: Failed to load "/usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so" "Cannot load library /usr/lib/qt/plugins/kf5/thumbcreator/appimagethumbnail.so: (libappimage.so.1.0: cannot open shared object file: No such file or directory)"
mar 30 18:33:00 mr-mnjro kioslave5[21045]: kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
mar 30 18:33:02 mr-mnjro dolphin[20893]: Cannot initialize model with data QJsonObject(). missing: QJsonValue(string, "urls")
