Hi! When I try to apply the latest update to Prey, this is what I get:
Summary
https://aur.archlinux.org/packages-meta-ext-v1.json.gz: Connection terminated unexpectedly
Preparing...
Refreshing AUR...
Cloning prey-node-client build files...
Generating prey-node-client information...
Checking prey-node-client dependencies...
Resolving dependencies...
Checking inter-conflicts...
Building prey-node-client...
==> Making package: prey-node-client 1.9.17-1 (Thu 03 Feb 2022 15:35:58 CET)
==> Retrieving sources...
-> Found prey-node-client.patch
-> Found prey_project
-> Found prey-linux-1.9.17-x64.zip
prey-node-client.patch ... Passed
prey_project ... Passed
==> Validating source_x86_64 files with sha256sums...
prey-linux-1.9.17-x64.zip ... Passed
==> Extracting sources...
-> Extracting prey-linux-1.9.17-x64.zip with bsdtar
==> Removing existing $pkgdir/ directory...
==> Entering fakeroot environment...
==> Starting package()...
ERROR: ld.so: object 'libfakeroot.so' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
can't find file to patch at input line 5
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff --git bin/prey bin/prey
|index 5b5203c..915abd7 100755
|--- bin/prey
|+++ bin/prey
File to patch:
Skip this patch? [y]
Skipping patch.
1 out of 1 hunk ignored
can't find file to patch at input line 23
|diff --git lib/agent/actions/alert/linux/flash.py lib/agent/actions/alert/linux/flash.py
|index 38a26b2..e7ac631 100755
|--- lib/agent/actions/alert/linux/flash.py
|+++ lib/agent/actions/alert/linux/flash.py
File to patch:
Skipping patch.
can't find file to patch at input line 39
|diff --git lib/conf/gui/linux/prey-config.py lib/conf/gui/linux/prey-config.py
|index f9f9eb4..66549ef 100755
|--- lib/conf/gui/linux/prey-config.py
|+++ lib/conf/gui/linux/prey-config.py
File to patch:
Skipping patch.
can't find file to patch at input line 49
|diff --git prey.conf.default prey.conf.default
|index 2b2b141..d39a885 100644
|--- prey.conf.default
|+++ prey.conf.default
File to patch:
Skipping patch.
can't find file to patch at input line 62
|index 66549ef..a7f4730 100755
File to patch:
Skipping patch.
can't find file to patch at input line 76
|diff --git lib/conf/shared/messages.js lib/conf/shared/messages.js
|index 55bc13c..a30ab1a 100644
|--- lib/conf/shared/messages.js
|+++ lib/conf/shared/messages.js
File to patch:
Skipping patch.
2 out of 2 hunks ignored
can't find file to patch at input line 96
|diff --git lib/conf/shared/keys.js lib/conf/shared/keys.js
|index 95a77b9..fdec9d1 100644
|--- lib/conf/shared/keys.js
|+++ lib/conf/shared/keys.js
File to patch:
Skipping patch.
can't find file to patch at input line 109
|diff --git lib/agent/plugins/console/index.js lib/agent/plugins/console/index.js
|index 9448533..7f5afb0 100644
|--- lib/agent/plugins/console/index.js
|+++ lib/agent/plugins/console/index.js
File to patch:
Skipping patch.
can't find file to patch at input line 127
|diff --git package.json package.json
|index 8383b5d..697816b 100644
|--- package.json
|+++ package.json
File to patch:
Skipping patch.
==> ERROR: A failure occurred in package().
Aborting...
Any guidance on how I could fix this?
