Prevent Bluetooth starting Automatically on Startup / Resume
I have currently installed Manjaro Gnome Edition on my laptop and am a beginner in linux. On every bootup I see that bluetooth is turned on automatically.
I tried the following command to disable startup:
sudo systemctl disable bluetooth.service try this
But it looks like it completely disabled Bluetooth for me (wouldn’t turn on at all). Basically, I just want it disabled (turned off) when I boot my laptop or resume, but I would still ne able to enable it when I needed it.
Any assistance would be appreciated. Thanks!
edit /etc/bluetooth/main.conf
[Policy]
AutoEnable=false
that should do the job
please remember to enable the bluetooth.service
https://wiki.archlinux.org/title/Bluetooth
So you turn it off in the settings and it gets enabled again? When I remember correctly, then gnome just toggles rfkill (software switch) and usually it should save it.
Check this on the terminal:
rfkill list
rfkill block bluetooth
rfkill unblock bluetooth
rfkill toggle bluetooth
Thank @Olli, this was the fix to get things working properly for me. Thanks!
