Use this script for zsh, but the prompt changes back to the standard manjaro prompt. How to fix this, should i delete all the lines above neofetch ?
# Use powerline
USE_POWERLINE="true"
# Source manjaro-zsh-configuration
if [[ -e /usr/share/zsh/manjaro-zsh-config ]]; then
source /usr/share/zsh/manjaro-zsh-config
fi
# Use manjaro zsh prompt
if [[ -e /usr/share/zsh/manjaro-zsh-prompt ]]; then
source /usr/share/zsh/manjaro-zsh-prompt
fi
neofetch
function powerline_precmd() {
PS1="$(powerline-shell --shell zsh $?)"
function install_powerline_precmd() {
for s in "${precmd_functions[@]}"; do
if [ "$s" = "powerline_precmd" ]; then
return
fi
done
precmd_functions+=(powerline_precmd)
if [ "$TERM" != "linux" -a -x "$(command -v powerline-shell)" ]; then
fi
