Hi,
firstly sorry for my english and now … this.
I have realy wierd issue, I bought a dock with a usb-C charger from i-tech “C31DUALDPDOCKPD65W”.
- When I use just dock, everything is OK.
- When I use just the USB-C charger everything is OK.
- But when I charge notebook using dock with this charger, in a time 10minutes to 5 hours, my internet connection stops working.
Trying to do anything with NetworkManager.service just freezes whatever was used (console, system settigns, …).
Weird part is that the interenet is actualy working, since when I have active RDP connection to pc at office, connection still works and i can use remote desktop, like nothing is going on.
I have tried to change kernel but that did not helped.
My notebook is acer swift 3 sf313-52
OS is quite new, I was forced to reinstall. (One time, restart reseted BIOS, which set my drive to Optane and after seting all up, I was not able to boot to linux anymore)
Results of inxi -Fza:
System: Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=8cf2582a-3224-40a2-9fb5-d6d2bbe08825 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Acer product: Swift SF313-52 v: V1.02 serial: Chassis: type: 10 serial:
Mobo: IL model: Skol_IL v: V1.02 serial: UEFI: Insyde v: 1.02 date: 12/07/2019
Battery: ID-1: BAT0 charge: 51.5 Wh condition: 51.5/56.0 Wh (92%) volts: 17.1/15.4 model: SMP KT00407008 AP18C7M
type: Li-ion serial: status: Full cycles: 23
CPU: Topology: Quad Core model: Intel Core i5-1035G4 bits: 64 type: MT MCP arch: Ice Lake family: 6 model-id: 7E (126)
stepping: 5 microcode: 78 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23968
Speed: 713 MHz min/max: 400/3700 MHz Core speeds (MHz): 1: 763 2: 818 3: 838 4: 956 5: 848 6: 725 7: 707 8: 911
Graphics: Device-1: Intel Iris Plus Graphics G4 vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:8a5a
Device-2: Chicony HD WebCam type: USB driver: uvcvideo bus ID: 3-6:4 chip ID: 04f2:b5c5 serial:
Display: x11 server: X. Org 1.20.9 compositor: kwin_x11 driver: intel unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 4176x1504 s-dpi: 96 s-size: 1102x397mm (43.4x15.6") s-diag: 1171mm (46.1")
Monitor-1: eDP1 res: 2256x1504 hz: 60 dpi: 205 size: 280x190mm (11.0x7.5") diag: 338mm (13.3")
Monitor-2: DP1-3 res: 1920x1200 hz: 75 dpi: 90 size: 540x340mm (21.3x13.4") diag: 638mm (25.1")
OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT1.5) v: 4.6 Mesa 20.1.8 direct render: Yes
Audio: Device-1: Intel Smart Sound Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
alternate: snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:34c8
Device-2: C-Media Audio Adapter (Unitek Y-247A) type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 3-3.3.4:121 chip ID: 0d8c:0014
Sound Server: ALSA v: k5.8.16-2-MANJARO
Network: Device-1: Intel Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter driver: iwlwifi v: kernel port: 3000
bus ID: 00:14.3 chip ID: 8086:34f0
IF: wlp0s20f3 state: up mac:
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus ID: 2-1.2.3:39 chip ID: 0bda:8153
serial:
IF: enp0s13f0u1u2u3 state: down mac:
IF-ID-1: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
Drives: Local Storage: total: 476.94 GiB used: 209.08 GiB (43.8%)
ID-1: /dev/nvme0n1 vendor: Kingston model: RBUSNS8154P3512GJ1 size: 476.94 GiB block size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 serial: rev: E8FK12.3 scheme: GPT
Partition: ID-1: / raw size: 119.71 GiB size: 117.33 GiB (98.01%) used: 18.40 GiB (15.7%) fs: ext4 dev: /dev/nvme0n1p5
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 56.0 C mobo: N/A
Info: Processes: 278 Uptime: 5d 5h 44m Memory: 15.32 GiB used: 5.01 GiB (32.7%) Init: systemd v: 246 Compilers:
gcc: 10.2.0 Packages: pacman: 1266 lib: 366 flatpak: 0 Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.05
Please help me, I just do not get, what is going on there.
