Hi all,
I notice powerdevil being quite busy on the system.
Just like baloo it slows things down…
Any hope of disabling powerdevil? If so…how?
Thanks a ton
Melissa
Edit : as I try to tweak the power settings, the system comes back that the power management service is not running, could this be the reason org_kde_powerde is peaking at 100% cpu?
If you use the search button in the top right you will notice a few other threads …
Thanks, you’re a life-saver (as usual ) - I’ll wait-n-sweat this one out, then. Thanks again…
I marked this as the solution so the thread can go to sleep
