Power savings options not applied (not saved)
Hello!
I’ve got an issue with power settings options. While i’m changing period of turning screen off (inactive) to 15 minutes it’s not saved. Same thing with “Power Button Behavior”.
How can i fix that?
Here is my config:
Manjaro Linux x86_64
Host: B550I AORUS PRO AX
Kernel: 5.15.71-1-MANJARO
Uptime: 13 mins
Packages: 1338 (pacman)
Shell: zsh 5.9
Resolution: 2560x1440
DE: GNOME 42.5
WM: Mutter
WM Theme: Adwaita
Theme: Adw [GTK2/3]
Icons: Papirus-Dark [GTK2/3]
Terminal: tmux
CPU: AMD Ryzen 7 3800X (16) @ 3.900GHz
GPU: AMD ATI Radeon RX 6600/6600 XT/6600M
Memory: 2236MiB / 15896MiB
Welcome to the forum! :wave:
See: FS#75909 - [gnome-control-center] Some settings changes not persisted
If you use proper formatting, neofetch output looks a lot nicer. :wink:
Please also see [HowTo] Request support
Hello!
Thank u for response!
As i see fixing this issue will be in GNOME 43, am i right?
Or i have to change code line in some file? (according to this commit)
Yes, it’s fixed in GNOME 43.
You could apply it as a patch to the PKGBUILD if you wish. Either that or you can change settings using dconf-editor or gsettings in the meantime.
Thank u so much!
i’m newbie in linux, so hope to try PKGBUILD.
But while i’m learn gsetting and other stuff, could you give some forecast or ETA for GNOME43 will be released for MANJARO?
When it’s ready. :wink:
