Did I brick my machine ?
I launched today’s update and had a power outage during process.
Now, it doesn’t boot and tell me the famous
error : file "boot/vmlinux-6.6.x86_64" unavailable
So I booted on a live USB and tried the sudo manjaro-chroot with the path of my broken system (witch is /dev/nvme1n1p1), but I get a can't change root on non-directory /dev/nvme1n1p1
Something I don’t get ?
Any help will be welcome
the command would normally be:
manjaro-chroot -a
(that will attempt to autodetect the correct partitions to mount and then chroot)
It didn’t work for you because
/dev/nvme1n1p1
isn’t a PATH - that is a device
It was simply a wrong command that had no hope of succeeding.
If autodetection doesn’t work for some reason, you mount the partitions yourself
to /mnt for example
and then issue
manjaro-chroot /mnt /bin/bash
That will chroot into the /mnt directory, where you mounted your system to
and start the bash shell
Narsil:
No.
It’s quite easily fixable.
If you would have given system info
inxi -Fazy
for example …
the information here could have been even more specific.
Let’s go step by step if you agree, I’m on a live USB and sudo -i
#manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/nvme1n1p1]
--> mount: [/mnt]
--> mount: [/mnt/home]
--> mount: [/mnt/boot/efi]
--> mount: [/mnt/home/diego/VM]
chroot: failed to run command '/bin/bash': Input/output error
--> umount: [/mnt/home/diego/VM]
--> umount: [/mnt/boot/efi]
--> umount: [/mnt/home]
--> umount: [/mnt]
I don’t get what I should manually mount from that
#lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 67.8M 1 loop /run/miso/sfs/livefs
loop1 7:1 0 1.1G 1 loop /run/miso/sfs/mhwdfs
loop2 7:2 0 1.7G 1 loop /run/miso/sfs/desktopfs
loop3 7:3 0 653.7M 1 loop /run/miso/sfs/rootfs
sda 8:0 1 7.3G 0 disk /run/miso/bootmnt
├─sda1 8:1 1 3.6G 0 part
└─sda2 8:2 1 4M 0 part
nvme0n1 259:0 0 953.9G 0 disk
└─nvme0n1p1 259:1 0 953.9G 0 part /run/media/manjaro/Home
nvme1n1 259:2 0 465.8G 0 disk
├─nvme1n1p1 259:3 0 244.1G 0 part /run/media/manjaro/System
├─nvme1n1p2 259:4 0 125G 0 part
├─nvme1n1p3 259:5 0 600M 0 part
└─nvme1n1p4 259:6 0 96G 0 part /run/media/manjaro/VM
Here’s my inix
#inxi -Fazy 127 ✘
Kernel: 6.1.30-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=fr_CH keytable=ch tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2213 quiet systemd.show_status=1
splash driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20TH000XMZ v: ThinkPad P1 Gen 3
Mobo: LENOVO model: 20TH000XMZ v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N2VET45W (1.30 )
date: 08/29/2023
ID-1: BAT0 charge: 20.3 Wh (26.8%) condition: 75.7/80.0 Wh (94.7%)
volts: 15.6 min: 15.4 model: Celxpert 5B10X19050 type: Li-poly
serial: <filter> status: charging cycles: 57
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xF8
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2043 high: 2600 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 974 2: 2600 3: 2600
4: 2600 5: 2600 6: 1110 7: 2600 8: 2600 9: 2600 10: 843 11: 2600 12: 800
bogomips: 62431
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: NVIDIA TU117GLM [Quadro T1000 Mobile] vendor: Lenovo
driver: nouveau v: kernel non-free: 530.xx+ status: current (as of 2023-05)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-22 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1fb9
class-ID: 0300 temp: 37.0 C
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 13d3:5405
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: nouveau gpu: nouveau display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x150c built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 800x600
API: OpenGL v: 4.3 Mesa 23.0.3 renderer: NV167 direct-render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0401
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
API: ALSA v: k6.1.30-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 1.4 TiB used: 635.88 GiB (44.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 30.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Kingston model: DataTraveler 2.0
size: 7.27 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP
scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 model: USB 2.0 Flash Disk size: 3.75 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: PMAP scheme: MBR
Message: No partition data found.
System Temperatures: cpu: 49.0 C pch: 55.0 C mobo: N/A gpu: nouveau
temp: 37.0 C
Fan Speeds (RPM): fan-1: 2587 fan-2: 2372
Processes: 298 Uptime: 22m wakeups: 6 Memory: available: 62.54 GiB
used: 2.59 GiB (4.1%) Init: systemd v: 252 default: graphical tool: systemctl
Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman pkgs: 1211
libs: 330 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.27
Narsil:
Since chroot isn’t working, your system info’s are the wrong one’s because its from the liveboot, instead the Install.
Its recommend that you using a Iso that isn’t this old… Because of Plasma 5 and Kernel 6.1 (even when its LTS) this version is aged.
ok, managed to mount /dev/nvme1n1p1 on /mnt/sys and tried this:
#manjaro-chroot /mnt/sys
chroot: failed to run command '/bin/sh': Input/output error
bad
to manually mount a chroot - you need to know the root partition
Narsil:
/dev/nvme1n1p1
I assume /dev/nvme1n1p1 is the root partition
And the error message point to a severe filesystem error where files has been corrupted
from the lsblk output it looks like you have mounted the partitions in a file manager.
I suggest you unmount them all
umount -R /run/media/manjaro
unmount that as well
You will need to run a file systemcheck on the root partition and that can only be done after you unmount the device - use the -y argument to repair errors automagically
fsck /dev/nvmen1p1 -y
Let me know what the outcome is
sudo fsck /dev/nvme1n1p1 -y 8 ✘
fsck from util-linux 2.40.2
e2fsck 1.47.1 (20-May-2024)
System contains a file system with errors, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Orphan file (inode 12) block 13 is not clean.
Clear? yes
System: ***** FILE SYSTEM WAS MODIFIED *****
System: 689763/16007168 files (0.2% non-contiguous), 14940840/64000000 blocks
It looks like it was not as bad as I thought.
Now I want you to mount the partition on /mnt - no other partitions mount - not on any subfolder - just /mnt.
mount /dev/nvmen1p1 /mnt
Just one more test with chroot - to deduce what’s next
sudo mount /dev/nvme1n1p1 /mnt ✔
sudo chroot /mnt /bin/bash ✔
chroot: failed to run command ‘/bin/bash’: Input/output error
That is not good
pacman has some switches that can make it work in alternate ways and we are going to do that to ensure we have valid versions of sh and bash
switch to root context
su -l root
Then
pacman -Syy --sysroot --root /mnt bash sh
@ManjaroDevOps
perhaps /bin/zsh is still in working condition - it seems to be a Plasma system where this shell is available
or just /bin/sh
… don’t forget to mount /boot too
[manjaro ~]# pacman -Syy --sysroot --root /mnt bash sh
erreur : le fichier --root/etc/pacman.conf ne peut pas être lu : Aucun fichier ou dossier de ce nom
That is strange - I thought the parttition was your root partition?
What size is your root partition ?
What is the content of /mnt
ls /mnt
What is the output of
lsblk -f
Deducing from the above - since the partition we have mounted does not contain the file /etc/pacman.conf there is another candidate /dev/nvme1n1p2 for a root file system.
Run a filesystem check on that partition as well
fsck /dev/nvme1n1p2 -y
I just moved the mount on /mnt/sys, but that’s what’s in:
[manjaro ~]# ls -l /mnt/sys
total 112
lrwxrwxrwx 1 root root 7 8 avr 15:26 bin -> usr/bin
drwxr-xr-x 5 root root 4096 8 aoû 10:15 boot
-rw-r--r-- 1 root root 22826 29 mai 2023 desktopfs-pkgs.txt
drwxr-xr-x 2 root root 4096 19 jui 2023 dev
drwxr-xr-x 129 root root 12288 8 aoû 10:15 etc
drwxr-xr-x 2 root root 4096 19 jui 2023 home
lrwxrwxrwx 1 root root 7 8 avr 15:26 lib -> usr/lib
lrwxrwxrwx 1 root root 7 8 avr 15:26 lib64 -> usr/lib
drwx------ 2 root root 16384 19 jui 2023 lost+found
drwxr-xr-x 3 root root 4096 20 jui 2023 mnt
drwxr-xr-x 7 root root 4096 31 jui 15:20 opt
drwxr-xr-x 2 root root 4096 19 jui 2023 proc
drwxr-x--- 7 root root 4096 20 jui 08:15 root
-rw-r--r-- 1 root root 5318 29 mai 2023 rootfs-pkgs.txt
drwxr-xr-x 2 root root 4096 19 jui 2023 run
lrwxrwxrwx 1 root root 7 8 avr 15:26 sbin -> usr/bin
drwxr-xr-x 5 root root 4096 22 jui 2023 srv
drwxr-xr-x 2 root root 4096 19 jui 2023 sys
drwxrwxrwt 2 root root 4096 19 jui 2023 tmp
drwxr-xr-x 10 root root 4096 7 aoû 06:48 usr
drwxr-xr-x 14 root root 4096 2 aoû 10:06 var
lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squash 4.0 0 100% /run/miso/sfs/livefs
loop1 squash 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squash 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squash 4.0 0 100% /run/miso/sfs/rootfs
sda iso966 Joliet MANJARO_KDE_2405 2024-07-30-08-30-25-00 0 100% /run/miso/bootmnt
├─sda1 iso966 Joliet MANJARO_KDE_2405 2024-07-30-08-30-25-00
└─sda2 vfat FAT12 MISO_EFI 0DE6-E8D4
nvme0n1
└─nvme0n1p1
ext4 1.0 Home 780f7a6e-f521-4bd2-86e1-eaaefe2d49ca
nvme1n1
├─nvme1n1p1
│ ext4 1.0 System 9007dd44-0f45-4e87-9b08-0f5683791833 174.9G 22% /mnt/sys
├─nvme1n1p2
│ swap 1 Swap a492060d-ca46-4059-85c0-d0e430155978
├─nvme1n1p3
│ vfat FAT32 EFI BBCC-445E
└─nvme1n1p4
ext4 1.0 VM 4cbe7ad7-1b68-4945-8646-40f4b0a7bad2
nvme1n1p2 is swap
125G swap ?
My swap is 69G so OK - I was just surprised
I’m an old man, born when RAM was expensive
don’t tell - I have seen expensive ram too an old man too …
There is a folder /etc in the root - so let’s list the content of /mnt/sys/etc/pacman
Then we try another approach - again assuming you are in a root context - I prepend commands with # - I accept your root is mount /mnt/sys - so I will use that path
# pacman -S --root /mnt/sys --cache-dir /mnt/sys/var/cache/pacman/pkg - < /mnt/sys/rootfs-pkgs.txt
[manjaro ~]# sudo chroot /mnt/sys /bin/zsh
chroot: impossible d'exécuter la commande « /bin/zsh »: Input/output error
[manjaro ~]# sudo chroot /mnt/sys /bin/sh
chroot: impossible d'exécuter la commande « /bin/sh »: Input/output error
/boot is in /
it looked different from your second post
but I will shut up now and not interfere with @ManjaroDevOps
