My laptop’s keyboard is probably broken. I disabled the power off menu from appearing but sometimes, textboxes get deselected randomly. This is really annoying at times.
Here is a video (sorry for low quality :p) https://streamable.com/pk4n2k
So you did successfully disable it?
I cant tell if you are asking for guidance or not. ![]()
Hot Tip - Try loading up another environment, such as on a Ventoy USB … if its still happening on the live system it becomes even easier to assume its the hardware.
If you’re using X and have a USB keyboard, you can disable your keyboard to test.
xinput
# find the id of your keyboard
# should look something like this
# ↳ AT Translated Set 2 keyboard id=14 [slave keyboard (3)]
xinput disable 14
For a more permanent option and for wayland, you can create a udev rule to disable the keyboard.
It happens on Windows aswell.
I am asking for guidance
I get
zsh: correct 'xinput' to '_xinput' [nyae]? n
zsh: command not found: xinput
Sorry I forgot to say it isn’t installed by default.
The package is xorg-xinput, but for future reference you can find the package like this:
sudo pacman -Fy xinput
# or use the full path
sudo pacman -Fy /usr/bin/xinput
I don’t want to disable the keyboard. I want to disable the power off key.
I thought you already had disabled it, and were thinking the keyboard was still causing issues. Perhaps I missed the “menu” part.
Anyway the power button should be the same, if using X. Not sure if the udev rule would work, but we can make a systemd service to make it permanent.
↳ Power Button id=6 [slave keyboard (3)]
If in doubt please post the output of xinput, unless you’re using wayland. Not sure how to do it in wayland, yet.
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ HTIX5288:00 0911:5288 Mouse id=9 [slave pointer (2)]
⎜ ↳ HTIX5288:00 0911:5288 Touchpad id=10 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=7 [slave keyboard (3)]
↳ Intel HID events id=11 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=13 [slave keyboard (3)]
↳ USB 2.0 Camera: USB 2.0 Camera id=8 [slave keyboard (3)]
↳ Intel HID 5 button array id=12 [slave keyboard (3)]
↳ Video Bus id=6 [slave keyboard (3)]
I did xinput disable 7 and I don’t have my issue anymore, so I think that’s good enough. I’ll just make a systemd service to do that everytime.
I forgot to mention that the id changes, so best to use the name for the systemd service. I’m too used to using the id as I mostly just play around with this stuff.
xinput disable "Power Button"
