Hi folks
I’m trying to compile the povray raytracer on manjaro, but having difficulties. Is there anyone out there that can give a few tips? I run machines with debian and manjaro. The povray is easily installed from source on debian, but I’m having trouble resolving dependency issues in the arch repos. Any help is greatly apprecated!
EDIT: Specifically, I’m stalled deep, deep, deep in a tragic descent into dependecy hell by povray’s requirement of a libjpeg with ‘jpeg_std_error’. Povray stumbles over this in the configure phase.
The PKGBUILD is the description of the process you are trying to do “manually”
I’d first try to build it “as is” - to make sure it works for you
then try to incorporate your modifications.
The script as it is should take care of the dependencies - install them.
Don’t know whether your modifications will require additional dependencies.
yes - but:
he want’s to modify the source this package is built from
build a modified package from it
so:
installing the unmodified package … will not do
not for him, anyways …
Well, I think I did say what I actually wanted to do, namely, compile povray from source. If I wanted to download the package and run a stock povray I would have done that.
The PKGBUILD for this standard package seems a little different than what I normally deal with - packages from the AUR
I usually do not recompile packages which are … available as a precompiled package.
The referenced patch, the patch you need/the PKGBUILD needs
is in the same diretory as the PKGBUILD:
Thanks Moson, I tried what you said. ./configure is still failing with:
checking whether to use the JPEG library... yes
checking for library containing jpeg_std_error... no
configure: error: cannot find a suitable JPEG library
but now I’m over the openexr patch thing, thanks for that. I’ve been looking for that elusive jpeg library that has a ‘jpeg_std_error’, but maybe I’m barking up the wrong tree. Any ideas?
