Potential gwenview bug? or a build issue?
starting gwenview from Konsole results in the following errors - in the 2nd set of errors, the line Watching absolute paths is not supported is not specific to gwenview - i’ve seen this for other KDE apps
gwenview 23.08.4-1 (repo)
KDE Plasma 5.27.10
$ gwenview
kf.i18n.kuit: "Unknown subcue ':whatsthis,' in UI marker in context {@info:whatsthis, %1 the action's text}."
org.kde.kdegraphics.gwenview.lib: Unresolved mime type  "image/x-aptus-mos"
[ many more removed for brevity ]
org.kde.kdegraphics.gwenview.lib: Unresolved mime type  "image/x-sti"
org.kde.kdegraphics.gwenview.lib: Unresolved raw mime type  "image/x-samsung-srw"
if i pass a folder of images to gwenview, this is the result - notice the last line…
kf.config.core: Watching absolute paths is not supported "/usr/share/gwenview/color-schemes/fullscreen.colors"
They’re not errors they’re warnings. The “Unresolved mime type” ones should probably be using notice log priority level instead of spamming warnings because they’re harmless. No idea about the others but unless you actually have a problem with gwenview then they’re safe to ignore.
thanks for the info - the problem i have is that the warnings stop the execution of a shell script in which i’m passing a folder of images to gwenview
aSpecViewerExe=( 'gwenview' '--fullscreen' '../spectro/' )
given the “Watching absolute paths is not supported” warning, i’ll have to try passing the full path and see if that solves the problem, even if sounds counterintuitive … and no, that didn’t work
no big deal - i’ll figure out something
kf.config.core: Watching absolute paths is not supported “/usr/share/gwenview/color-schemes/fullscreen.colors”
The above warning has no relation to the path ../spectro/ you passed to gwenview.
Try to test it by opening your terminal and directly running
gwenview --fullscreen ../spectro/
And see if gwenview opens or not at that specified folder.
gwenview always works and displays the requested images, it’s just that it “interrupts” the console, thus the calling script is unable to complete (i have to Ctrl+C)
the mime type warnings have no effect, only when the “Watching absolute paths is not supported” happens does gwenview cause the problem
whatever is causing it started fairly recently
probably should have mentioned, not that it’s any help, the full command is:
gwenview '--fullscreen' '../spectro/' > '/dev/null' & disown
but even with ‘disown’, gwenview sits in the console waiting for input, hence why i need to kill it, which also kills my script
Why are you using quotes?
What’s wrong with
gwenview -f ../spectro & disown
