Posts then reloads after typing password
New to Manjaro.
Did a fresh install. Tried both Manual and Auto Partitioning, Tried reinstalling Manjaro.
All end the same way.
I type in my password → Very Short Black Screen → Image of my Post screen (ASUS) → Very Short Black Screen → Back to login screen → Repeat.
Have you checked the checksum of the ISO prior to installation?
At the Login screen , bottom left, if it offers x11 or wayland select x11.
I ran into same problem.
is not needed when and while doing a fresh install - inconsistent information detected :sunglasses:
@eddier
… yours does not seem to be the same problem
You got the system booted up and then something failed, but the OP could not even boot
by his/her description
create your own thread for your issue please
Thank you so much! It works now!
Checked it and there were no errors. Turns out I just needed to select x11 on the login screen!
