I recently updated to PostGIS Version 3.0.3-1. Afterwards I started my server as usual and got the following error in the log:
ERROR: could not load library "/usr/lib/postgresql/postgis-3.so": /usr/lib/postgresql/postgis-3.so: undefined symbol: list_make1_impl
I also get an additional statement:
STATEMENT: SELECT
a.attnum,
a.attname,
a.atttypmod,
a.attstattarget,
a.attstorage,
t.typstorage,
a.attnotnull,
a.atthasdef,
a.attisdropped,
a.attlen,
a.attalign,
a.attislocal,
pg_catalog.format_type(t.oid, a.atttypmod) AS atttypname,
a.attgenerated,
CASE WHEN a.atthasmissing AND NOT a.attisdropped THEN a.attmissingval ELSE null END AS attmissingval,
a.attidentity,
pg_catalog.array_to_string(ARRAY(SELECT pg_catalog.quote_ident(option_name) || ' ' || pg_catalog.quote_literal(option_value) FROM pg_catalog.pg_options_to_table(attfdwoptions) ORDER BY option_name), E',
') AS attfdwoptions,
CASE WHEN a.attcollation <> t.typcollation THEN a.attcollation ELSE 0 END AS attcollation,
array_to_string(a.attoptions, ', ') AS attoptions
FROM pg_catalog.pg_attribute a LEFT JOIN pg_catalog.pg_type t ON a.atttypid = t.oid
WHERE a.attrelid = '18597'::pg_catalog.oid AND a.attnum > 0::pg_catalog.int2
ORDER BY a.attnum
Originally I thought this is an issue with the proj-package. Unfortunately it appears to be something deeper within PostgreSQL or PostGIS. It appears to be a general problem with the latest version of PostgreSQL and PostGIS in Manjaro, but I can’t find a solution to this anywhere online.
I have a recent backup of my DB so I could try to restore everything from scratch, but of course I would like to try and avoid this, if at all possible.
My current package-setup is as follows:
QGIS: Version 3.16.5
Postgres: Version 12.6-1
PostGIS: Version 3.0.3-1
