Hi @rethus,
Let’s find out why postfix was installed. It looks like it is, but let’s first confirm it with:
pamac search postfix
It’ll give an output similar to this:
$ pamac search postfix
postfwd 2.03-1 community
Combines complex postfix restrictions in a ruleset similar to those of the most firewalls
postfixadmin 3.3.10-2 community
Web based interface to manage Postfix mailboxes, virtual domains and aliases
postfix-sqlite 3.6.2-2 extra
Fast, easy to administer, secure mail server (SQLite integration)
postfix-pgsql 3.6.2-2 extra
Fast, easy to administer, secure mail server (PostgreSQL integration)
postfix-pcre 3.6.2-2 extra
Fast, easy to administer, secure mail server (PCRE integration)
postfix-mysql 3.6.2-2 extra
Fast, easy to administer, secure mail server (MySQL integration)
postfix-lmdb 3.6.2-2 extra
Fast, easy to administer, secure mail server (LMDB integration)
postfix-ldap 3.6.2-2 extra
Fast, easy to administer, secure mail server (LDAP integration)
postfix-cdb 3.6.2-2 extra
Fast, easy to administer, secure mail server (CDB integration)
postfix 3.6.2-2 extra
If it is installed, it’ll show [installed]
on the right-hand side. Then, if it is installed, let’s find out whether it was explicitly installed or as a dependency:
pacman -Qi postfix
It should give an output similar to this:
Version : 5.8-1
Description : A very advanced and programmable command interpreter (shell) for UNIX
Architecture : x86_64
URL : https://www.zsh.org/
Licenses : custom
Groups : None
Provides : None
Depends On : pcre libcap gdbm
Optional Deps : None
Required By : manjaro-zsh-config zsh-autosuggestions zsh-completions zsh-history-substring-search zsh-syntax-highlighting zsh-theme-powerlevel10k
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 6.22 MiB
Packager : Pierre Schmitz <pierre@archlinux.de>
Build Date : Sun 16 Feb 2020 19:55:21
Install Date : Fri 11 Sep 2020 18:41:03
Install Reason : Installed as a dependency for another package
Install Script : Yes
Validated By : Signature
What we’re interested in is the Install Reason
. It should be either
Explicit or
Installed as a dependecy for another package.
If it is “Explicit” it should, theoretically be safe to just uninstall it:
pamac uninstall postfix
Note: This’ll break anything relying on it.
If it is “Installed as a dependecy for another package”, we need to find out what that dependency is, to see if it’s important or not. That is in the Required By
of the same output.
Depending on the importance of the packages, you can uninstall them, or ignore the error and continue.
Edit:
Of course, you can just uninstall it and handle the fallout:
pamac remove postfix
