Possible to disable pin?
Hello,
I just installed the x64 plasma mobile release on my tablet and wonder if it’s possible to disable the fact you have to enter the pin. I already changed sddm to autologin, but it keeps asking the pin number. Probably you can do it somewhere in a config file, but which?
In your ~./config/kscreenlockerrc there’s a section for [Daemon] where LockOnStart=true. Switch that to LockOnStart=false and reboot and it should not show lockscreen on login anymore.
Thanks for the swift reply.
