Habe dasselbe Ergebnis. (Ich) Mache mir keine Sorgen - das ist sinnlos. https://www.linuxquestions.org/questions/slackware-14/possible-infection-chrootkit-reports-linux-xor-ddos-4175605450/ https://forums.linuxmint.com/viewtopic.php?t=342027
Mittlerweile habe ich ein frisch heruntergeladenes Live-System geprüft: gleiches Ergebnis.
Damit ibetrachte ich das Problem als gelöst und die Meldung als falsch.
Danke für eure Mühen!
akern
To me, this looks like a syntax error in the programs testing routine itself.
Just look at the file /usr/bin/chkrootkit less /usr/bin/chkrootkit and go to that line
It’s throwing a syntax error for one of it’s own, built in procedures.
That file it is trying to analyze/test does not even exist in your system anyway
or
/etc/cron.hourly/gcc.sh
… it doesn’t even exist in an Arch/Manjaro installation
If you read the message - it’s not even a false positive, as it is a non existent file
If you really have this file/directory though … different story
You should also probably run this program from a known good source and have it check the target file system from there.
ps:
my comment came too late - issue already resolved
oh well
