Hello, is it possible to transfer the quick commands created in the terminal, such as export and import, to another computer? Thank you
Check ~/.config/konsolerc on your old computer, is there something in there that appears to be those commands?
1536x864 screen: Window-Maximized=true
State=AAAA/wAAAAD9AAAAAQAAAAAAAAD7AAAC0/wCAAAAAvsAAAAiAFEAdQBpAGMAawBDAG8AbQBtAGEAbgBkAHMARABvAGMAawEAAABMAAAC0wAAAXwBAAAD+wAAABwAUwBTAEgATQBhAG4AYQBnAGUAcgBEAG8AYwBrAAAAAFQAAAODAAABFQEAAAMAAAUEAAAC0wAAAAQAAAAEAAAACAAAAAj8AAAAAQAAAAIAAAACAAAAFgBtAGEAaQBuAFQAbwBvAGwAQgBhAHIBAAAAAP////8AAAAAAAAAAAAAABwAcwBlAHMAcwBpAG8AbgBUAG8AbwBsAGIAYQByAQAAAxL/////AAAAAAAAAAA=
[General]
ConfigVersion=1
[KFileDialog Settings]
Recent Files[$e]=file:$HOME/Рабочий стол/вав.txt,file:$HOME/Рабочий стол/вав.txt
Recent URLs[$e]=file:$HOME/Рабочий стол/,file:$HOME/
detailViewIconSize=16
[MainWindow]
1536x864 screen: Height=662
1536x864 screen: Width=1034
1536x864 screen: XPosition=0
1536x864 screen: YPosition=86
1600x900 screen: Height=666
1600x900 screen: Width=1207
1600x900 screen: Window-Maximized=true
1920x1080 screen: Height=957
1920x1080 screen: Width=1881
1920x1080 screen: Window-Maximized=true
MenuBar=Enabled
State=AAAA/wAAAAD9AAAAAQAAAAAAAAD7AAAC0/wCAAAAAvsAAAAiAFEAdQBpAGMAawBDAG8AbQBtAGEAbgBkAHMARABvAGMAawEAAABMAAAC0wAAAXwBAAAD+wAAABwAUwBTAEgATQBhAG4AYQBnAGUAcgBEAG8AYwBrAAAAAFQAAAODAAABFQEAAAMAAAUEAAAC0wAAAAQAAAAEAAAACAAAAAj8AAAAAQAAAAIAAAACAAAAFgBtAGEAaQBuAFQAbwBvAGwAQgBhAHIBAAAAAP////8AAAAAAAAAAAAAABwAcwBlAHMAcwBpAG8AbgBUAG8AbwBsAGIAYQByAQAAAn7/////AAAAAAAAAAA=
ToolBarsMovable=Disabled
eDP-1=eDP-1
eDP-1 Height 1536x864 eDP-1=799
eDP-1 Height 1920x1080=643
eDP-1 Height 1920x1080 eDP-1=643
eDP-1 Width 1536x864 eDP-1=1536
eDP-1 Width 1920x1080=1280
eDP-1 Width 1920x1080 eDP-1=1280
eDP-1 Window-Maximized 1536x864 eDP-1=true
eDP-1 XPosition 1536x864 eDP-1=0
eDP-1 XPosition 1920x1080=347
eDP-1 XPosition 1920x1080 eDP-1=320
eDP-1 YPosition 1536x864 eDP-1=30
eDP-1 YPosition 1920x1080=243
eDP-1 YPosition 1920x1080 eDP-1=207
[Notification Messages]
quick-commands-question=true
[SaveHistory Settings]
[UiSettings]
ColorScheme=
There are no such commands.
Okay, not there. How about in one of the files in ~/.local/share/konsole ?
Ok after some investigation I believe I found the file they are stored in. Try ~/.config/konsolequickcommandsconfig
In the konsole
Either
→ Settings menu
→ configure keyboard shortcuts
Or
→ use the predefined shortcut CtrlAlt,
Then
→ click the button Manage Schemes >>
→ click the buttion More Actions
→ select Export Scheme
Result
The file can then be imported at another system.
I believe OP is referring to the Quick Commands plugin, not the keyboard shortcuts, based on the menu in the screenshot.
Ahh - I missed that - it was the import export mention I stumbled upon.
You are likely more correct
No, there are just keys, and these are quick commands that you create to speed up input to the terminal, and they live here ~/.config/konsolequickcommandsconfig. Thank you for your attention!
[Shortcuts]
activate-menu=Ctrl+Shift+F10
add_bookmark=Ctrl+Shift+B
add_bookmarks_list=none
adjust-history=none
allow-mouse-tracking=none
clear-history=none
clear-history-and-reset=Ctrl+Shift+K
clone-tab=none
close-session=Ctrl+Shift+W
close-window=Ctrl+Shift+Q
copy-input-to=none
copy-input-to-all-tabs=none
copy-input-to-none=Ctrl+Shift+/
copy-input-to-selected-tabs=Ctrl+Shift+.
detach-tab=none
detach-view=Ctrl+Shift+H
edit-current-profile=none
edit_bookmarks=none
edit_copy=Ctrl+Shift+C
edit_copy_contextmenu=none
edit_copy_contextmenu_in=none
edit_copy_contextmenu_in_out=none
edit_copy_contextmenu_out=none
edit_find=Ctrl+Shift+F
edit_find_next=F3
edit_find_prev=Shift+F3
edit_paste=Ctrl+Shift+V; Shift+Ins
enlarge-font=Ctrl++; Ctrl+=
equal-size-view=Ctrl+Shift+\\
expand-active-view=Ctrl+Shift+]
file_print=Ctrl+Shift+P
file_save_as=Ctrl+Shift+S
focus-view-above=Ctrl+Shift+Up
focus-view-below=Ctrl+Shift+Down
focus-view-left=Ctrl+Shift+Left
focus-view-right=Ctrl+Shift+Right
fullscreen=F11
hamburger_menu=none
help_about_app=none
help_about_kde=none
help_contents=none
help_donate=none
help_report_bug=none
help_whats_this=Shift+F1
last-tab=none
last-used-tab=Ctrl+Tab
last-used-tab-reverse=Ctrl+Shift+Tab
load-layout=none
load-terminals-layout-1x2=none
load-terminals-layout-2x1=none
load-terminals-layout-2x2=none
mainToolBar=none
manage-profiles=none
monitor-activity=Ctrl+Shift+A
monitor-process-finish=none
monitor-silence=Ctrl+Shift+I
move-tab-to-left=Ctrl+Alt+Left
move-tab-to-right=Ctrl+Alt+Right
new-tab=Ctrl+Shift+T
new-window=Ctrl+Shift+N
new_bookmark_folder=none
next-tab=Shift+Right; Ctrl+PgDown
open-browser=none
open_kcommand_bar=Ctrl+Alt+I
options_configure=Ctrl+Shift+,
options_configure_keybinding=Ctrl+Alt+,
options_configure_notifications=none
options_configure_toolbars=none
options_show_menubar=Ctrl+Shift+M
paste-selection=Ctrl+Shift+Ins
previous-tab=Shift+Left; Ctrl+PgUp
rename-session=Ctrl+Alt+S
reset-font-size=Ctrl+Alt+0
save-layout=none
select-all=none
select-line=none
select-mode=Ctrl+Shift+D
semantic-setup-bash=Ctrl+Alt+]
send-signal=none
sessionToolbar=none
set-encoding=none
shrink-active-view=Ctrl+Shift+[
shrink-font=Ctrl+-
sigcont-signal=none
sighup-signal=none
sigint-signal=none
sigkill-signal=none
sigstop-signal=none
sigterm-signal=none
sigusr1-signal=none
sigusr2-signal=none
split-view-auto=Ctrl+*
split-view-auto-next-tab=none
split-view-left-right=none
split-view-left-right-next-tab=none
split-view-top-bottom=none
split-view-top-bottom-next-tab=none
switch-to-tab-0=Alt+1
switch-to-tab-1=Alt+2
switch-to-tab-10=none
switch-to-tab-11=none
switch-to-tab-12=none
switch-to-tab-13=none
switch-to-tab-14=none
switch-to-tab-15=none
switch-to-tab-16=none
switch-to-tab-17=none
switch-to-tab-18=none
switch-to-tab-2=Alt+3
switch-to-tab-3=Alt+4
switch-to-tab-4=Alt+5
switch-to-tab-5=Alt+6
switch-to-tab-6=Alt+7
switch-to-tab-7=Alt+8
switch-to-tab-8=Alt+9
switch-to-tab-9=Alt+0
switch_application_language=none
toggle-line-numbers=Ctrl+Alt+\\
toggle-maximize-current-view=Ctrl+Shift+E
toggle-semantic-hints=Ctrl+Alt+[
toggle-two-tabs=none
view-readonly=none
window-colorscheme-menu=none
zmodem-upload=Ctrl+Alt+U
