Port forwarding to libvirt guest stopped working in 10.4.0
Unfortunately I’ve very little knowledge of networks/firewall/… But still some time ago I managed to pass traffic to my virtual machine, so I could access services running inside from any device in my network. This worked quite well for the last few years, but now somehow stopped working. I still can get a connection to the host machine, but the forwarding to the guest no longer works. I didn’t change anything so I suspect some update broke it.
I read in the most recent update notes that libvirt changed firewall backends from iptables to nftables - I’ve little idea what consequences that might have. Could it be the reason for my problems? or any other idea, what might be going on?
Here’s what I did in the past and what was working:
/usr/sbin/iptables -I FORWARD -o virbr0 -d 192.168.122.200 -j ACCEPT
/usr/sbin/iptables -t nat -I PREROUTING -d 192.168.1.200 -p tcp --dport 5001 -j DNAT --to 192.168.122.200:5001
/usr/sbin/iptables -t nat -I PREROUTING -d 192.168.1.200 -p tcp --dport 9000 -j DNAT --to 192.168.122.200:9000
/usr/sbin/ip address add 192.168.1.200/24 dev enp7s0
Currently I can access the guest from the host machine via 192.168.122.200:5001, so this is working. I can also access services on my host from the other devices (e.g. 192.168.1.200:80), so this is working as well.
I already tried changing /usr/sbin/iptables to /usr/sbin/iptables-nft but that didn’t change anything.
Update: I’ve established that it is an update-problem. After downgrading to libvirt 10.3.0 it worked again. Going back to 10.4.0 it breaks.
solved a similar issue by manually setting libvirt’s firewall_backend to “iptables” in /etc/libvirt/network.conf
There is a report on libvirt failing to automatically detect firewall_backend too
network.conf - libvirt will NOT choose the first available backend
Thank you, I really don’t like the idea of setting it up that way because I know that I will run into problems a few years from now and by then I will have forgotten what I did in the first place :frowning:
But since there seems to be no explanation available on how to set up portforwarding with nft and nft seems to make everything more complicated by at least a factor of 10 I’m afraid I’ll have to follow your suggestion.
