I have a Behringer UMC204HD which works fine on my work laptop, but when using it with my personal laptop it clicks and pops while audio is playing. This doesn’t happen using the thinkpad’s built in audio or on bluetooth, and doesn’t change whether I use pulseaudio or jackd. It also doesn’t change with increasing or decreasing sample rate, frames/period, or periods/buffer.
Here’s the pulseaudio sinks and sources
mvanorder@malcolm-p72 ~ master ● pacmd list-sinks
2 sink(s) available.
* index: 0
driver: <module-alsa-card.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY
state: RUNNING
suspend cause: (none)
priority: 9049
volume: front-left: 49808 / 76% / -7.15 dB, front-right: 49808 / 76% / -7.15 dB, rear-left: 49808 / 76% / -7.15 dB, rear-right: 49808 / 76% / -7.15 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 100.85 ms
max request: 34 KiB
max rewind: 34 KiB
monitor source: 0
sample spec: s16le 4ch 44100Hz
channel map: front-left,front-right,rear-left,rear-right
Surround 4.0
used by: 1
linked by: 3
fixed latency: 99.95 ms
card: 1 <alsa_card.usb-BEHRINGER_UMC204HD_192k-00>
module: 7
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "USB Audio"
alsa.id = "USB Audio"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "3"
alsa.card_name = "UMC204HD 192k"
alsa.long_card_name = "BEHRINGER UMC204HD 192k at usb-0000:00:14.0-1.4, high speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:00:14.0-usb-0:1.4:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/sound/card3"
udev.id = "usb-BEHRINGER_UMC204HD_192k-00"
device.bus = "usb"
device.vendor.id = "1397"
device.vendor.name = "BEHRINGER International GmbH"
device.product.id = "0508"
device.product.name = "UMC204HD 192k"
device.serial = "BEHRINGER_UMC204HD_192k"
device.string = "surround40:3"
device.buffering.buffer_size = "35264"
device.buffering.fragment_size = "8816"
device.access_mode = "mmap"
device.profile.name = "analog-surround-40"
device.profile.description = "Analog Surround 4.0"
device.description = "UMC204HD 192k Analog Surround 4.0"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-usb"
ports:
analog-output: Analog Output (priority 9900, latency offset 0 usec, available: unknown)
properties:
active port: <analog-output>
index: 1
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
state: IDLE
priority: 9039
volume: front-left: 37886 / 58% / -14.28 dB, front-right: 37886 / 58% / -14.28 dB
balance 0.00
volume steps: 65537
muted: no
current latency: 99.91 ms
max request: 18 KiB
max rewind: 18 KiB
monitor source: 2
sample spec: s16le 2ch 48000Hz
Stereo
used by: 0
linked by: 1
fixed latency: 99.94 ms
card: 3 <alsa_card.pci-0000_00_1f.3>
module: 9
properties:
device.api = "alsa"
alsa.name = "ALC285 Analog"
alsa.id = "ALC285 Analog"
alsa.device = "0"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0x404a108000 irq 156"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "a348"
device.product.name = "Cannon Lake PCH cAVS"
device.string = "front:0"
device.buffering.buffer_size = "19188"
device.buffering.fragment_size = "6396"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Built-in Audio Analog Stereo"
device.icon_name = "audio-card-pci"
ports:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
active port: <analog-output-speaker>
mvanorder@malcolm-p72 ~ master ● pacmd list-sources
4 source(s) available.
index: 0
flags: DECIBEL_VOLUME LATENCY
state: RUNNING
priority: 1040
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB, rear-left: 65536 / 100% / 0.00 dB, rear-right: 65536 / 100% / 0.00 dB
balance 0.00
volume steps: 65537
muted: no
current latency: 0.00 ms
max rewind: 34 KiB
Surround 4.0
used by: 2
linked by: 2
monitor_of: 0
module: 7
properties:
device.description = "Monitor of UMC204HD 192k Analog Surround 4.0"
device.class = "monitor"
alsa.card = "3"
device.bus = "usb"
device.string = "3"
* index: 1
state: RUNNING
priority: 9048
balance 0.00
volume steps: 65537
muted: no
current latency: 0.81 ms
max rewind: 0 KiB
sample spec: s32le 2ch 44100Hz
Stereo
used by: 1
linked by: 1
module: 7
properties:
alsa.resolution_bits = "32"
device.api = "alsa"
alsa.device = "0"
alsa.card = "3"
device.bus = "usb"
device.string = "iec958:3"
device.profile.name = "iec958-stereo"
device.profile.description = "Digital Stereo (IEC958)"
device.description = "UMC204HD 192k Digital Stereo (IEC958)"
ports:
iec958-stereo-input: Digital Input (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
properties:
active port: <iec958-stereo-input>
index: 2
state: RUNNING
priority: 1030
balance 0.00
volume steps: 65537
muted: no
max rewind: 18 KiB
Stereo
used by: 1
linked by: 1
monitor_of: 1
module: 9
properties:
device.description = "Monitor of Built-in Audio Analog Stereo"
alsa.card = "0"
device.bus = "pci"
device.string = "0"
index: 3
state: RUNNING
priority: 9039
volume: front-left: 11995 / 18% / -44.25 dB, front-right: 11995 / 18% / -44.25 dB
balance 0.00
base volume: 6554 / 10% / -60.00 dB
volume steps: 65537
muted: yes
current latency: 0.17 ms
max rewind: 0 KiB
sample spec: s16le 2ch 44100Hz
Stereo
used by: 1
linked by: 1
module: 9
properties:
device.api = "alsa"
alsa.device = "0"
alsa.card = "0"
device.bus = "pci"
device.buffering.buffer_size = "17632"
device.buffering.fragment_size = "4408"
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
active port: <analog-input-internal-mic>
