Hi, I am Gunit .
Just updated Counter Strike: Global Offence. And got these bad graphics
even in-game got same graphics.
I have played it before the update which was of 150mb download,1.6gb on disk and graphics were fine no lag and no poor graphics
Kernel: 5.14.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=3d92a08e-ec54-419d-a9ac-5513127177cd ro quiet apparmor=1
Desktop: herbstluftwm 0.9.3 info: polybar vt: 7 dm: LightDM 1.30.0
Type: Laptop System: LENOVO product: 81D6 v: Lenovo ideapad 330-15AST
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 330-15AST
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55724WIN
serial: <superuser required> UEFI: LENOVO v: 8UCN19WW date: 05/14/2021
ID-1: BAT0 charge: 22.4 Wh (100.0%) condition: 22.4/30.6 Wh (73.3%)
volts: 8.5 min: 7.6 model: CPT-COS L16C2PB2 type: Li-poly serial: <filter>
status: Full
RAM: total: 6.67 GiB used: 1.64 GiB (24.6%)
Info: Dual Core model: AMD A6-9225 RADEON R4 5 COMPUTE CORES 2C+3G bits: 64
type: MCP arch: Excavator family: 15 (21) model-id: 70 (112) stepping: 0
microcode: 6006705 cache: L1: 256 KiB L2: 2 MiB bogomips: 10402
Speed: 2571 MHz min/max: 2400/3600 MHz boost: disabled Core speeds (MHz):
1: 3824 2: 3668
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avic avx avx2
bmi1 bmi2 bpext clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy
cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fma4 fpu
fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs lahf_lm lbrv lm lwp mca mce
misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nodeid_msr nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse pse36 ptsc
rdtscp rep_good sep skinit smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 svm
svm_lock syscall tbm tce tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xop xsave xsaveopt
disabled, RSB filling
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Lenovo
driver: amdgpu v: kernel bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
Device-2: IMC Networks EasyCamera type: USB driver: uvcvideo bus-ID: 1-1.3:4
chip-ID: 13d3:5a02 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.1 compositor: picom v: git-dac85 driver:
loaded: modesetting display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD STONEY (DRM 3.42.0 5.14.18-1-MANJARO LLVM 13.0.0)
v: 4.5 Mesa 21.2.5 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:01.1
chip-ID: 1002:15b3 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
Sound Server-1: ALSA v: k5.14.18-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 2000
bus-ID: 01:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 1000 bus-ID: 02:00.0 chip-ID: 10ec:8136
class-ID: 0200
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-1.2:3 chip-ID: 0bda:c024 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 3 state: up address: <filter>
Local Storage: total: 931.51 GiB used: 103.35 GiB (11.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: LCM2 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE0N rev: T.02
dev-links: cdrom
ID-1: / raw-size: 315.05 GiB size: 309.11 GiB (98.11%)
used: 103.24 GiB (33.4%) fs: ext4 dev: /dev/sda9 maj-min: 8:9 label: N/A
uuid: 3d92a08e-ec54-419d-a9ac-5513127177cd
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 114 MiB (11.4%) fs: vfat dev: /dev/sda14 maj-min: 8:14 label: N/A
uuid: 9604-07C2
ID-1: swap-1 type: partition size: 2.93 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: b6b04b23-0477-4459-a870-9c714febfac2
ID-1: /dev/sda1 maj-min: 8:1 size: 260 MiB fs: vfat label: SYSTEM_DRV
uuid: 6C8C-D247
ID-2: /dev/sda10 maj-min: 8:10 size: 195.31 GiB fs: ntfs label: New Volume
uuid: EEFE8A31FE89F25F
ID-3: /dev/sda11 maj-min: 8:11 size: 19.29 GiB fs: ntfs label: New Volume
uuid: 00AC900EAC8FFC7A
ID-4: /dev/sda12 maj-min: 8:12 size: 2.93 GiB fs: swap label: N/A
uuid: d491e39d-bb42-43fe-82ab-39fa21701fe8
ID-5: /dev/sda13 maj-min: 8:13 size: 25 GiB fs: ntfs label: LENOVO
uuid: 4244764544763C2B
ID-6: /dev/sda15 maj-min: 8:15 size: 173.09 GiB fs: btrfs label: N/A
uuid: e7a21b7a-3f64-4fad-89ff-71f881ab13c1
ID-7: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-8: /dev/sda3 maj-min: 8:3 size: 172.84 GiB fs: ntfs label: Windows
uuid: 02A48FFDA48FF209
ID-9: /dev/sda4 maj-min: 8:4 size: 1024 KiB fs: <superuser required>
ID-10: /dev/sda5 maj-min: 8:5 size: 1.5 GiB fs: ntfs label: New Volume
uuid: 9EFA3429FA33FBD9
ID-11: /dev/sda6 maj-min: 8:6 size: 954 MiB fs: vfat label: N/A
uuid: 2D1E-B69F
ID-12: /dev/sda7 maj-min: 8:7 size: 500 MiB fs: vfat label: N/A
uuid: 361C-712A
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0438:7900 class-ID: 0900
Device-1: 1-1.2:3 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
plz help me fix this
