I was about to create a Post about this, then i found your posting… and you nailed it.
There are more and more user’s running into this problem.
Stability first and fancy boot should be the last option, its just not worth it for a default install… people should only add this feature optionally, if they want a fancy bootup and with a clear warning that this lead to compatibility issue.
This default settings just scares new people off who are new to Manjaro.
Possible they choose another distro or reject Linux because of this bug.
Welcome new Linux User’s with a blackscreen who wants to run away from Windows… and this is your response to them?
This sounds more like a gatekeeper move, to make it for Windows user’s who owns a nvidia card, for the first contact hard as possible for them?
I wondering if this the new goal from Manjaro to create this additional hurdles to join the Manjaro community, specially on a fresh and new install. Which normally should have his full focus to run flawless as possible and evade all possible incompatibilitys.
Maybe you can tell us, how this fits to the advertising from Manjaro.org?
This user-friendly OS is an excellent choice for those who seek a fresh computing experience, as it can be seamlessly installed on a diverse array of devices.
I think this advertising doesn’t really fits together right now.
Exactly, the worst is if this new user’s going back to Windows and Manjaro should be the first Distro for Linux Gamer’s which mostly use nvidia cards.
1,5 month later, maybe its worth to let the maintainer’s be aware about this issue? When no one told them about this situation right now, for what is this Feedback/Feature Request area good then?
Let them decide if they’re are willing to put time into this issue.
