When we post code blocks, we can use ``` or ~~~
to open and to close that block.
We can also use programming language to highlight function definition, variables, values, operators:
```java
# ...and to compute them together we use
fn foo(bar, baz) {
let myVar = 123;
let myVar2 = 'out of range';
return computeddValue;
While it is useful for programming code block and usually needs to note exact language, our forum users usually posts log excerpts and shell commands, which could look weird with no language provided.
If not to use text
as programming language, than code blocks will looks like plain text perhaps usually more readable.
You can try it by yourself in the next wiki post (start to edit it and check result you have on the right panel).
saved copy (backup) of source code of initial wiki post below made by OP
~/.mozilla
~/.cache/mozilla
~/.pulse
with `text` specified:
```text
~/.mozilla
~/.cache/mozilla
~/.pulse
Dec 03 15:32:39 pc kernel: audit: type=1130 audit(1638534759.261:596): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 03 15:32:39 pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 03 15:32:39 pc systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 03 15:32:39 pc dbus-daemon[515]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Dec 03 15:32:39 pc systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 03 15:32:39 pc dbus-daemon[515]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=516 comm="/usr/bin/NetworkManager --no-daemon ")
```text
Section "ServerFlags"
Option "IgnoreABI" "1"
EndSection
```text
EndSection
systemctl --user enable pipewire-media-session
which on black forum theme looks like:
and now with `text` specified:
```text
And only sometimes some current default helps to make it more readable:
# Remove NVIDIA USB xHCI Host Controller devices, if present
#ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c0330", ATTR{remove}="1"
# Remove NVIDIA USB Type-C UCSI devices, if present
#ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c8000", ATTR{remove}="1"
# Remove NVIDIA Audio devices, if present
#ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x040300", ATTR{remove}="1"
and with `text` specified:
```text
So, may be to make code block have the programming language config of text
by default in forum engine as most cases it looks more readable without default highlighting?
