Please Add moby-engine
Hi,
Can you please add moby-engine this engine fix some issues from docker-engine.
Actually Fedora & Void Linux use Moby Engine.
https://src.fedoraproject.org/rpms/moby-engine
https://pkgs.org/download/moby-engine
Best Regards
Arch Linux - and by inheritance - Manjaro makes no - or at least minimal - changes to upstream packages.
Please explaiin
  • What would be the advantege?
  • Why is patching docker to moby of any advantage to the community?
  • Why would Manjaro deviate from upstream Arch Linux in this case?
Hi,
I understand perfectly.
But I’m just talking about adding the packages, not replacing the default engine.
It seems to me that this respects the upstream because you do not delete or modify anything.
Adding an option one can as when you added Discord before Arch Linux.
Best Regards
Won’t implement.
