If I login to SDDM with the display manager set to Wayland, I get a black screen with a mouse cursor. Background services such as bluetooth, audio etc. do start. Alt+F2 brings up krunner, but attempting to launch any programs will usually result in them opening, displaying a few frames, then freezing, which also freezes krunner.
The strangest thing about this is it seems to start two wayland sessions - trying to Ctrl+Alt+F2 to get into a tty doesn’t work, because tty2 is the one I’m already on. Switching to tty1 shows much the same, but there is no krunner, and the mouse is reset to the default theme (or SDDM’s theme, i think)
Checking journalctl, plasmashell aborts due to KActivityManager, but from what I can tell this isn’t the root cause and is just indicative of some other problem?:
Jun 11 21:56:25 riko dbus-daemon[1103]: [session uid=1000 pid=1103] Successfully activated service 'org.kde.ActivityManager'
Jun 11 21:56:25 riko systemd[1083]: Started KActivityManager Activity manager Service.
Jun 11 21:56:25 riko plasmashell[1229]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jun 11 21:56:25 riko plasmashell[1229]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
(Full log here: Jun 11 21:56:10 riko kernel: Linux version 6.3.5-2-MANJARO (builduser@fv-az619-3 - Pastebin.com)
Things I have tried - it’s worth noting that this issue appeared seemingly out of nowhere, as far as i can tell, and not as a result of changing or upgrading any packages, but I could be wrong:
- Swapping mesa, vulkan-radeon etc. for their
-gitversions (from themesa-gitrepository) and back. - Kernels 6.1, 6.2, 6.3 show no difference
- Using X11 works fine. (both via
startxand by selecting it in SDDM) - Uninstalling SDDM and manually running
startplasma-waylandto the same effect.
Unfortunately this is about as far as my linux knowledge can take me
any tips on what else I could try would be greatly appreciated!
