Plasmashell keeps crashing with nvidia-575xxx
Hi,
After last update, I installed linux618-nvidia-575xx-575.64.05-30 but plasmashell keeps crashing.
~inxi -zv8
  Kernel: 6.18.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=9b5af405-c72f-4456-a7f5-1f96aa139354 rw rootflags=subvol=@
    udev.log_priority=3 sysrq_always_enabled=1 ibt=off
    resume=UUID=9b5af405-c72f-4456-a7f5-1f96aa139354 resume_offset=23732262
  Desktop: KDE Plasma v: 6.6.4 tk: Qt v: N/A info: frameworks v: 6.25.0
    wm: kwin_wayland vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 82H9 v: IdeaPad 3 17ITL6
    serial: <superuser required> Chassis: type: 10 v: IdeaPad 3 17ITL6
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    part-nu: LENOVO_MT_82H9_BU_idea_FM_IdeaPad 3 17ITL6
    uuid: <superuser required> Firmware: UEFI vendor: LENOVO v: GGCN61WW
    date: 11/28/2024
  ID-1: BAT0 charge: 18.4 Wh (56.5%) condition: 32.6/38 Wh (85.7%) volts: 7.67
    min: 7.7 model: Celxpert L20C2PF0 type: Li-poly serial: <filter> charging:
    status: not charging type: long_life avail: long_life,standard cycles: 500
  System RAM: total: 20 GiB available: 19.32 GiB used: 3.44 GiB (17.8%)
  Array-1: capacity: 32 GiB note: est. slots: 2 modules: 2 EC: None
  Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 16 GiB speed: 3200 MT/s volts: curr: 1 width (bits): data: 64
    total: 64 manufacturer: Crucial Technology part-no: CT16G4SFRA32A-C8PE
    serial: <filter>
  Device-2: Controller1-ChannelA type: DDR4 detail: synchronous size: 4 GiB
    speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: Micron Technology part-no: 4ATF51264HZ-3G2J1 serial: N/A
  Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xBE
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
    desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 1400 min/max: 400/4700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 1400 2: 1400 3: 1400 4: 1400 5: 1400 6: 1400
    7: 1400 8: 1400 bogomips: 44851
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
    rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Type: vmscape status: Not affected
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0
    chip-ID: 8086:9a49 class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce MX350] vendor: Lenovo driver: nvidia
    v: 575.64.05 alternate: nouveau,nova_core,nvidia_drm non-free: 550-580.xx+
    status: current (as of 2025-11; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 4
    link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c94 class-ID: 0302
  Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:4 chip-ID: 04f2:b6ee
    alternate: fbdev,vesa dri: iris gpu: i915 d-rect: 3840x1080 display-ID: 0
  Monitor-1: HDMI-A-1 pos: right model: Samsung LS24C36x serial: <filter>
    built: 2023 res: mode: 1920x1080 hz: 75 scale: 100% (1) dpi: 82 gamma: 1.2
    chroma: red: x: 0.647 y: 0.333 green: x: 0.325 y: 0.612 blue: x: 0.153
    y: 0.051 white: x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23")
    diag: 686mm (27") ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 832x624,
    800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: eDP-1 pos: primary,left model: BOE Display 0x09c1 built: 2020
    res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 128 gamma: 1.2 chroma: red:
    x: 0.639 y: 0.341 green: x: 0.322 y: 0.624 blue: x: 0.157 y: 0.055 white:
    x: 0.314 y: 0.329 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
    drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 26.0.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
    GT2) device-ID: 8086:9a49 memory: 18.86 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.4.341 layers: 2 device: 0 type: discrete-gpu
    name: NVIDIA GeForce MX350 driver: nvidia v: 575.64.05 device-ID: 10de:1c94
    surfaces: N/A
    wl: wayland-info x11: xdpyinfo,xprop
  Device-1: Intel 500 Series Family On-Package High Definition Audio
    vendor: Lenovo driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
    snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:a0c8
    class-ID: 0401
  API: ALSA v: k6.18.26-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:8
  Local Storage: total: 2.27 TiB used: 1.08 TiB (47.4%)
    model: WD Green SN3000 500GB size: 465.76 GiB block-size: physical: 512 B
    fw-rev: 123000WD temp: 41.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
    spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter> scheme: GPT
  ID-1: / raw-size: 219.73 GiB size: 219.73 GiB (100.00%)
    used: 197.26 GiB (89.8%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
    label: manjaro uuid: 9b5af405-c72f-4456-a7f5-1f96aa139354
    used: 57.9 MiB (60.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: SYSTEM uuid: 1263-8A1B
  ID-3: /home raw-size: 219.73 GiB size: 219.73 GiB (100.00%)
  ID-4: /run/media/eylem/exfat raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 906.53 GiB (48.7%) fs: exfat dev: /dev/sda1 maj-min: 8:1 label: exfat
    uuid: 6D6F-765A
  ID-5: /var/cache raw-size: 219.73 GiB size: 219.73 GiB (100.00%)
  ID-6: /var/log raw-size: 219.73 GiB size: 219.73 GiB (100.00%)
  ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
    file: /@swap/swapfile
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 243.91 GiB fs: ntfs
    label: Windows uuid: 308E64EF8E64AF52
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.05 GiB fs: ntfs label: N/A
    uuid: 702A76DE2A76A0B0
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-1:2 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E ASM1153
    3Gb/s ASM1153E bridge type: mass storage driver: uas interfaces: 1
    rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    chip-ID: 174c:55aa class-ID: 0806 serial: <filter>
  Hub-4: 3-4:3 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 3-4.1:5 info: Logitech Logi Bolt Receiver
    type: keyboard,mouse,HID driver: hid-generic,hid-multitouch,usbhid
    interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 98mA chip-ID: 046d:c548 class-ID: 0300
  Device-2: 3-4.2:7 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Device-3: 3-4.3:9 info: HP DeskJet 2800 series type: printer driver: usblp
    interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 2mA chip-ID: 03f0:031b class-ID: 0701 serial: <filter>
  Device-4: 3-5:4 info: Chicony Integrated Camera type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b6ee class-ID: 0e02
    serial: <filter>
  Device-5: 3-7:6 info: Shenzhen Goodix FingerPrint Device
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 27c6:5503 class-ID: ef00
  Device-6: 3-10:8 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 4-1:2 info: Genesys Logic Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  System Temperatures: cpu: 47.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1920 pm: dpkg pkgs: 0 pm: pacman pkgs: 1873 libs: 403 tools: pamac
    pm: flatpak pkgs: 47
  Active pacman repo servers in: /etc/pacman.conf
    1: https://mega.nz/linux/repo/Arch_Extra/$arch
    1: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    2: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    5: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    6: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    7: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    8: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 334
  1: cpu: 107% command: plasmashell pid: 5051 mem: 571.0 MiB (2.8%)
  2: cpu: 8.7% command: solaar started-by: python pid: 1656
    mem: 118.6 MiB (0.5%)
  3: cpu: 7.7% command: NodeRadioTray pid: 1616 mem: 225.4 MiB (1.1%)
  4: cpu: 7.2% command: kwin_wayland pid: 1165 mem: 249.3 MiB (1.2%)
  5: cpu: 5.7% command: konsole pid: 4793 mem: 180.1 MiB (0.9%)
  Memory top: 5 of 334
  1: mem: 571.0 MiB (2.8%) command: plasmashell pid: 5051 cpu: 107%
  2: mem: 249.3 MiB (1.2%) command: kwin_wayland pid: 1165 cpu: 7.2%
  3: mem: 245.7 MiB (1.2%) command: easyeffects pid: 1621 cpu: 4.9%
  4: mem: 225.4 MiB (1.1%) command: NodeRadioTray pid: 1616 cpu: 7.7%
  5: mem: 180.1 MiB (0.9%) command: konsole pid: 4793 cpu: 5.7%
  Processes: 334 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
    image: 7.65 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 260 default: graphical tool: systemctl
  Compilers: clang: 22.1.3 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.40
pacman -Ss nvidia | grep installed         ✔
core/linux-firmware-nvidia 20260410-1 [installed]
extra/egl-gbm 1.1.3-1 [installed]
extra/egl-wayland 4:1.1.21-1 [installed]
extra/egl-x11 1.0.5-1 [installed]
extra/libvdpau 1.5-4 [installed]
extra/linux612-nvidia-575xx 575.64.05-38 (linux612-extramodules) [installed]
extra/linux618-nvidia-575xx 575.64.05-30 (linux618-extramodules) [installed]
extra/mhwd-nvidia 595.71.05-1 [installed]
extra/mhwd-nvidia-390xx 390.157-24 [installed]
extra/mhwd-nvidia-470xx 470.256.02-17 [installed]
extra/mhwd-nvidia-580xx 580.159.03-1 [installed]
extra/nvidia-575xx-settings 575.64.05-3 [installed]
extra/nvidia-575xx-utils 575.64.05-3 [installed]
extra/nvidia-driver-assistant 0.23.48.01-6 [installed]
extra/opencl-nvidia-575xx 575.64.05-3 [installed]
journalctl log: https://paste.c-net.org/FleshPesky
I tried to follow NVIDIA - ArchWiki and add ibt=off kernel parameter without success. I also tried to install 580xxx driver but it was the same.
