Hello everybody.
Since i migrated to wayland i sometimes get this error:
[ 4550.576222] plasmashel:gl0[2124]: segfault at 3f1 ip 00007fd117ea3997 sp 00007fd02e7fb050 error 4 in ld-linux-x86-64.so.2[b997,7fd117e99000+2a000] likely on CPU 11 (core 5, socket 0)
[ 4550.576252] Code: 66 0f ef c0 48 83 05 1f ce 02 00 01 48 89 45 98 0f 29 45 a0 4d 85 e4 74 0a f6 45 10 02 0f 85 ad 5a ff ff 48 8b 85 68 ff ff ff <4c> 8b 08 48 83 7d 18 00 0f 85 fb 01 00 00 31 d2 4d 85 c9 0f 84 20
$ journalctl -b -p err | grep -i plasmashell
Mai 11 08:29:45 rich-pc systemd-coredump[14481]: Process 1504 (plasmashell) of user 1000 dumped core.
#36 0x000055f78c7f42d9 n/a (/usr/bin/plasmashell + 0x282d9)
#39 0x000055f78c7f4875 n/a (/usr/bin/plasmashell + 0x28875)
My System:
Host: rich-pc Kernel: 6.18.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 15.2.1 clocksource: hpet
Desktop: KDE Plasma v: 6.5.6 tk: Qt v: N/A wm: kwin_wayland vt: 2 dm: N/A
Type: Desktop System: Gigabyte product: N/A v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Gigabyte model: X79-UD3 serial: <superuser required>
uuid: <superuser required> Firmware: BIOS vendor: American Megatrends v: F20
date: 03/19/2014
Device-1: hidpp_battery_0 model: Logitech MK700 serial: b9-e4-c8-7d
charge: 70% (should be ignored) rechargeable: yes status: discharging
Device-2: hidpp_battery_1 model: Logitech Marathon Mouse/Performance Plus
M705 serial: 76-a6-79-0f charge: 55% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 32 GiB available: 31.26 GiB used: 2.99 GiB (9.6%)
Array-1: capacity: 96 GiB slots: 4 modules: 4 EC: None
max-module-size: 24 GiB note: est.
Device-1: Node0_Dimm0 type: DDR3 detail: unbuffered (unregistered)
size: 8 GiB speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: N/A part-no: F3-1600C10-8G serial: N/A
Device-2: Node0_Dimm1 type: DDR3 detail: unbuffered (unregistered)
Device-3: Node0_Dimm2 type: DDR3 detail: unbuffered (unregistered)
Device-4: Node0_Dimm3 type: DDR3 detail: unbuffered (unregistered)
Info: 6-core model: Intel Core i7-3930K bits: 64 type: MT MCP smt: enabled
arch: Sandy Bridge rev: 7 cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB
Speed (MHz): avg: 2139 min/max: 1200/3800 cores: 1: 2139 2: 2139 3: 2139
4: 2139 5: 2139 6: 2139 7: 2139 8: 2139 9: 2139 10: 2139 11: 2139 12: 2139
bogomips: 76798
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 dca de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdtscp
rep_good sep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
Device-1: NVIDIA GK107 [GeForce GT 640] vendor: ASUSTeK driver: N/A
arch: Kepler-2 pcie: speed: 2.5 GT/s lanes: 8 bus-ID: 01:00.0
chip-ID: 10de:0fc1 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Cape Verde PRO [Radeon HD
7750/8740 / R7 250E] vendor: PC Partner / Sapphire driver: radeon
v: kernel arch: GCN-1 pcie: speed: 8 GT/s lanes: 16 ports: active: DVI-I-1
empty: DP-1,HDMI-A-1 bus-ID: 02:00.0 chip-ID: 1002:683f class-ID: 0300
temp: 50.0 C
compositor: kwin_wayland driver: X: loaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi,nouveau gpu: radeon display-ID: 0
Monitor-1: DVI-I-1 model: Samsung S23B550 serial: 808596016 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96 size: 510x287mm (20.08x11.3")
diag: 585mm (23") modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.5 vendor: amd mesa v: 26.0.2-arch1.1 glx-v: 1.4
direct-render: yes renderer: (radeonsi verde ACO DRM 2.51 6.18.18-1-MANJARO)
device-ID: 1002:683f display-ID: :0.0
x11: xdpyinfo, xprop, xrandr
Device-1: Intel C600/X79 series High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1d20
class-ID: 0403
Device-2: NVIDIA GK107 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: speed: 2.5 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:0e1b
class-ID: 0403
Device-3: Advanced Micro Devices [AMD/ATI] Oland/Hainan/Cape
Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series]
vendor: PC Partner / Sapphire driver: snd_hda_intel v: kernel pcie:
speed: 8 GT/s lanes: 16 bus-ID: 02:00.1 chip-ID: 1002:aab0 class-ID: 0403
API: ALSA v: k6.18.18-1-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: sndiod v: N/A status: off
Server-2: JACK v: 1.9.22 status: off
Server-3: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
Device-1: Intel 82579V Gigabit Network vendor: Gigabyte driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503 class-ID: 0200
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: 90:2b:34:57:9e:d5
IP v4: 192.?? type: dynamic noprefixroute scope: global
broadcast: 192.??
IP v6: 2003:??
IP v6: fda9:?? type: dynamic noprefixroute
scope: global
IP v6: fe80:?? type: noprefixroute scope: link
IF-ID-1: virbr0 state: down mac: 52:??
IP v4: 192.?? scope: global broadcast: 192.??
WAN IP: 87.??
Local Storage: total: 3.87 TiB used: 426.7 GiB (10.8%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 PRO 256GB size: 238.47 GiB
speed: 6.0 Gb/s tech: SSD serial: S39KNX0J711905L fw-rev: 4B6Q scheme: MBR
ID-2: /dev/sdb vendor: Crucial model: CT4000BX500SSD1 size: 3.64 TiB
speed: 6.0 Gb/s tech: SSD serial: 2549E9CEA42A fw-rev: 091 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH16NS40 rev: 1.00
dev-links: cdrom
ID-1: / size: 238.47 GiB used: 26.2 GiB (11.0%) fs: btrfs dev: /dev/sda1
label: N/A uuid: 2a46e35e-??
ID-2: /home size: 3.58 TiB used: 400.51 GiB (10.9%) fs: ext4
dev: /dev/sdb1 label: N/A uuid: 3cd12a9d-??
ID-3: /var/cache size: 238.47 GiB used: 26.2 GiB (11.0%) fs: btrfs
dev: /dev/sda1 label: N/A uuid: 2a46e35e-??
ID-4: /var/log size: 238.47 GiB used: 26.2 GiB (11.0%) fs: btrfs
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
speed: 480 Mb/s lanes: 1 chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-3: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s lanes: 1 chip-ID: 8087:0024 class-ID: 0900
Device-1: 2-1.2:3 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s lanes: 1 power: 98mA chip-ID: 046d:c52b
class-ID: 0300
Hub-4: 3-0:1 info: super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
lanes: 1 chip-ID: 1d6b:0003 class-ID: 0900
Hub-5: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-6: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 35.0 C mobo: N/A gpu: radeon temp: 50.0 C
Fan Speeds (rpm): N/A
Processes: 298 Power: uptime: 1h 23m states: freeze,mem,disk suspend: deep
wakeups: 0 hibernate: platform Init: systemd v: 259 default: graphical
Packages: 1732 pm: pacman pkgs: 1705 pm: flatpak pkgs: 27 Compilers:
clang: 22.1.1 gcc: 15.2.1 Shell: Bash v: 5.3.9 running-in: konsole
inxi: 3.3.40
If you need more information i will deliver.
Best regards
CC
