So. I am fully updated and now i am getting all sorts of crashes and I need some help. So when I lock my computer and come back to it the Screen is black. i got a pointer. so CTRL+ALT+F2 log in and reboot or kill and restart plasmashell. So I have a video background. It goes black and freezes. I right click and go to change it and the background preferences opens and its frozen and when I go to close it it informs me plasmashell is Frozen, So I terminate it and it goes black and comes back. I check the logs and got a lot of errors for widgits. Uninstalled all the problem widgets. Error still persists.
Running Manjaro. with 5.15.102-1-MANJARO
[blank@chaos ~]$ journalctl --system --boot=-1 --priority=3 | tail --lines=50
Mar 17 18:27:56 chaos kernel: mpt2sas_cm0: overriding NVDATA EEDPTagMode setting
Mar 17 18:27:56 chaos kernel: sd 10:0:0:0: [sde] No Caching mode page found
Mar 17 18:27:56 chaos kernel: sd 10:0:0:0: [sde] Assuming drive cache: write through
Mar 17 18:27:56 chaos kernel: scsi 10:0:0:1: Wrong diagnostic page; asked for 1 got 8
Mar 17 18:27:56 chaos kernel: scsi 10:0:0:1: Failed to get diagnostic page 0x1
Mar 17 18:27:56 chaos kernel: scsi 10:0:0:1: Failed to bind enclosure -19
Mar 17 18:27:56 chaos systemd-udevd[665]: /etc/udev/rules.d/10-mblockhid.rules:2 Invalid key 'SYSFS'
Mar 17 18:27:57 chaos kernel:
Mar 17 18:28:00 chaos systemd[1]: Failed to start PostgreSQL database server.
Mar 17 18:28:03 chaos systemd[1490]: Failed to start Update XDG user dir configuration.
Mar 18 02:04:44 chaos systemd-coredump[7348]: Process 7324 (Plex Media Scan) of user 0 dumped core.
Module /snap/plexmediaserver/362/lib/libgcompat.so.0 without build-id.
Module /snap/plexmediaserver/362/lib/libc++.so.2 without build-id.
Module /snap/plexmediaserver/362/lib/ld-musl-x86_64.so.1 without build-id.
Stack trace of thread 7328:
#0 0x00007f876c89e7ca n/a (/snap/plexmediaserver/362/lib/ld-musl-x86_64.so.1 + 0x5b7ca)
#1 0x00007f876caca473 n/a (/snap/plexmediaserver/362/Plex Media Scanner + 0x1e4473)
#2 0x00007f876caca407 n/a (/snap/plexmediaserver/362/Plex Media Scanner + 0x1e4407)
#3 0x00007f876cbb7037 n/a (/snap/plexmediaserver/362/Plex Media Scanner + 0x2d1037)
#4 0x00007f876cbd9d4b n/a (/snap/plexmediaserver/362/Plex Media Scanner + 0x2f3d4b)
#5 0x00007f876cacbc83 n/a (/snap/plexmediaserver/362/Plex Media Scanner + 0x1e5c83)
#6 0x00007f876ca88e92 n/a (/snap/plexmediaserver/362/Plex Media Scanner + 0x1a2e92)
#7 0x00007f876cca8ab5 n/a (/snap/plexmediaserver/362/Plex Media Scanner + 0x3c2ab5)
#8 0x00007f876cca9d26 n/a (/snap/plexmediaserver/362/Plex Media Scanner + 0x3c3d26)
#9 0x00007f876cca9e5b n/a (/snap/plexmediaserver/362/Plex Media Scanner + 0x3c3e5b)
#10 0x00007f876cca9716 n/a (/snap/plexmediaserver/362/Plex Media Scanner + 0x3c3716)
#11 0x00007f876c74c8ed n/a (/snap/plexmediaserver/362/lib/libboost_thread.so + 0xf8ed)
#12 0x00007f876c8d5751 n/a (/snap/plexmediaserver/362/lib/ld-musl-x86_64.so.1 + 0x92751)
Mar 18 10:26:05 chaos login[9007]: pam_systemd(login:session): Failed to release session: Interrupted system call
Mar 18 10:26:05 chaos systemd-coredump[9130]: Failed to connect to coredump service: Connection refused
Mar 18 10:26:06 chaos systemd-logind[1177]: Failed to start autovt@tty2.service: Transaction for getty@tty2.service/start is destructive (sysinit.target has 'stop' job queued, but 'start' is included in transaction).
Any help is appreciated.
