Plasmashell crashes, after some analysis I discovered that the system tray is to blame. I have deactivated programs at startup such as insync and nextcloud, but it still crashes if I add the system tray.
Also kickoff gives me this error:
file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:69:9: Cannot assign to non-existent property “highlightNewlyInstalledApps”
Does anyone experience the same problem? Suggestions?
you can try the following to test if it’s a problem from plasma or your individual config.
create a new user in your system and login as this test-user. it will start with a “fresh” configuration. check if the problem is still occuring or if it disappeared.
Asking in two¨ three different forums for help with problems which were caused by a partial update is rather embarrassing.
Asking the same question in multiple forums (and without linking them) is also quite the waste of community-helper resources and considered bad manners.
