Plasma X11 no longer works after installed a game
Hello, i’ve installegod Gothic 2 game and wendt into setings to chrnge some setdings, after display resolution changed, screen went blank, so i restarted.
After the login screen went blank again, i tought it was because of the game, so i logged in with wayland to chage setings in the game. Problem persisted, so i uninstalled the game in wayland and still not solved.
I am thinking to reinstall x11 but i’m don’t know how, i’m a relatively new user of linux, i’ll atach specs and other PICTURES caz i’m lost in Wayland AND KEYBOARD LAYOUT IS DIFFERENT AND INTERNET DOESNT WORK, please help get x11 back, is the most friendly enviorment.
  Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=c20dff3c-e986-40d4-b505-599dcf961483 rw quiet splash
    udev.log_priority=3
  Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: SDDM
  Type: Laptop System: LENOVO product: 82EY v: IdeaPad Gaming 3 15ARH05
    serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15ARH05
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    UEFI: LENOVO v: FCCN13WW date: 06/29/2020
  ID-1: BAT0 charge: 24.3 Wh (58.7%) condition: 41.4/45.5 Wh (90.9%)
    volts: 11.7 min: 11.4 model: Sunwoda L19D3PF4 type: Li-poly serial: <filter>
    status: not charging cycles: 251
  System RAM: available: 7.14 GiB used: 1.91 GiB (26.8%)
  Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x8600104
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1531 high: 3000 min/max: 1400/3000 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
    3: 3000 4: 1397 5: 1400 6: 1400 7: 1397 8: 1397 9: 1397 10: 1400 11: 1400
    12: 1397 bogomips: 71880
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
    sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
    tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
Moderator edit: Remove useless screenshots.
Installing a game shouldn’t do any damage to the system, at least if you install them correctly, that is by Steam or some game app like Lutris or Heroic. Please, tell us how you installed them, because if you tried some manual shenanigans, it can explain the issues.
Also, can you log in into tty? If you don’t know what tty is and how to log into it, do some research. If tty works, you can fix your system from there. If not, you need to familiarize yourself with chrooting Manjaro. Another important topic to learn to fix the system. Unless you have a backup, then I would suggest restring backup from tty or from live system.
By the way, why do you have Gnome and SDDM which is a DM for Plasma? This shows that you were installing different DEs so this can be the cause of conflicts and your problems. I would suggest to re-install your system again. It is possible to clean such install, but it takes a lot of time, and you need some knowledge to do that. Usually it’s just too bothersome, hence reinstalling is the easiest thing.
Besides, you have too many issues and I assume, you messed with your system too much. Figuring this out could be very tedious and time-consuming.
You sound like a newbie, and you need to accept that you will brake Manjaro once or twice till you learn it. This is part of the experience and part of the learning curve. We’ve all been there.
I just used the default instalation, only bothored with password and username, everuthing was installed as it is, didnt chose the DMs at that point, i didnt know much.
Im trying to get in tty, now i’m in the bios
I cant get into tty
Moderator edit: Remove useless screenshot.
Is there a way to just reinstall x11?
Found a strange thing, connecting to an external display works, can you help me from here?
I noticed that the game changes the whole system resolution, and desabled the built-in screen, i saw this while trying to find out why on the second screen.
i went in sittings and checked why the resolution had changed overall and saw that built in screen is desabled.
i hope this stays here fore any other fools like me who installed a game from unknown sources and freaked the computer
Wow! Never heard that the game can disable the in-built screen. That’s crazy!
Good you were able to solve it yourself.
As to tty, you need to boot the system and only then try to log in to tty. Basically, tty works only if the system works.
