Following the 2024-11-30 Stable Update: When using alt-tab to switch to a window on another virtual desktop, the window being switched to does not indicate focus correctly.
Example:
2x windows (e.g. dolphin + konsole) on different virtual desktops.
If konsole window has full focus, the cursor is solid. If dolphin has full focus, select item is solid colour.
Type something in konsole.
alt-tab (task switcher) to dolphin. Selected item is “weak” colour. Press any key and selected item indicates full focus.
alt-tab (task switcher) to konsole. Cursor is not solid. Type anything. Cursor becomes solid.
Previous behaviour was that the window being switched to would immediately gain the “full focus” without a key being pressed. This is still the behaviour today if the two windows above are on the same virtual desktop. I am using Plasma Wayland session. I have all window borders/decorations disabled. I tried deleting all plasma-related caches. This corrected another issue I had after this update, but not this issue.
It’s a weird one, and slightly difficult to explain. Hope this is clear …
I’m not sure if I understand the issue here, but I did notice some weird alt-tab behaviors lately on Plasma. Namely, usually when I alt-tabbed, the previous window was focused. So for alt-tab it matters the current and previous window. However, lately it instead of raising previous window, it did with different one. As if the order of the windows (that we see when pressing and not releasing alt after tab) was fixed somehow and independent of the previously focused window.
I’m not sure if the issue is still there, because I started more relaying on clicking on windows in a taskbar or using overwiew effect instead alt-tab.
Anyway, something weird was happening. However, since I’m on unstable branch, there were some KDE updates lately, so I’m not sure if that wasn’t already fixed.
It does seem that the usage of Alt-Tab is less these days (e.g. there have only been 2 3rd-party Plasma6 Task Switcher styles released). This, coupled with the fact that the default settings in Plasma for Alt-Tab only switches between windows on the same virtual desktop could explain why this doesn’t affect too many people.
In my case, I have all title-bar and window borders removed and panel hidden. Windows are maximised or tiled half/quarter screen via keyboard shortcuts across 4 virtual desktops and I almost always switch between windows using Alt-Tab. Therefore, I almost immediately noticed this weirdness after the recent upgrade and it is quite off-putting - it feels like I don’t know for sure which window has focus until I type something …
OK, figured out the problem on my side, and it has nothing to do with your issue.
Basically, the problem was with multimonitor setup, so alt-tab was always switching to the window focused on another monitor and never on the previously active window on the current monitor. This can be changed in settings to filter alt-tab order to windows in the current monitor, which fixes my problem.
Also, if someone is using virtual desktops, there can be a filter for that too.
You are correct that this is a possible workaround. However, in my case, I specifically want to switch between windows across different virtual desktops using Alt-Tab, so I have this filter disabled.
Issue remains after latest stable update to Plasma 6.2.5. It seems to be resolved in Plasma 6.2.5 on an EndeavourOS install. Any ideas what I can do to my Manjaro environment to fix this? (I just tried with a clean user and issue remains.)
Again to clarify reproducing this issue in simplest case:
Single monitor, multiple plasma virtual desktops
Dolphin window on virtual desktop 1, Konsole window on virtual desktop 2.
Focus on Dolphin.
Alt-tab switch to konsole. Konsole window does not have correct focus (in my case indicated by hollow box cursor.
Press any key: Keypress is registered and konsole window gains correct focus (solid box cursor)
I’ve done further investigation today and I think I’ve found a workaround and can explain why it’s not seen by everyone (though I still think it’s an upstream bug).
Regarding the EndeavourOS installation, I forgot that I was running an X11 session (old hardware). Issue does not seem to occur at all on X11. Sorry for this “red herring”.
Symptoms of my particular issue on Manjaro Wayland can be avoided by disabling (in Plasma settings) “Apps & Windows” - “Window Management” - “Virtual Desktops” - “Show on-screen display when switching”. I’m positive I tried this before starting this thread (since it’s so clearly related), so maybe the recent update has changed something.
