When I attempt to start a plasma wayland session via lightdm, after login I get a black screen at the time the plasma splash screen is supposed to appear. The X11 session works fine. I have tried with the compositor turn off on startup, but that does not seem to have an effect. All I can do is disconnect the power to reboot.
Should a wayland session work with llvmpipe? If I switch to v3d it works fine.
