I have returned to Manjaro after playing with several linux distributions. After a successful installation I wanted to instal Wayland. However “plasma-wayland-session” cannot be found.
How can I install Wayland?
inxi -Fxxxz ✔
Kernel: 6.9.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X515EA_X515EA
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X515EA v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: X515EA.309
date: 05/16/2022
ID-1: BAT0 charge: 28.5 Wh (80.1%) condition: 35.6/37.1 Wh (96.0%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 35
Info: quad core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
smt: enabled arch: Tiger Lake rev: 1 cache: L1: 320 KiB L2: 5 MiB L3: 8 MiB
Speed (MHz): avg: 915 high: 1300 min/max: 400/4200 cores: 1: 400 2: 1300
3: 738 4: 861 5: 1048 6: 1032 7: 930 8: 1011 bogomips: 38720
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 1-3:2 chip-ID: 322e:2103 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: AU Optronics 0x61ed res: 1920x1080 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") modes: 1920x1080
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.6-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8
class-ID: 0403
API: ALSA v: k6.9.0-1-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel bus-ID: 0000:02:00.0 chip-ID: 8086:2725 class-ID: 0280
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 bus-ID: 1-10:3 chip-ID: 8087:0032 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 931.51 GiB used: 89.4 GiB (9.6%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
size: 931.51 GiB speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: 2B2QEXM7 temp: 33.9 C scheme: GPT
ID-1: / size: 921.97 GiB used: 89.4 GiB (9.7%) fs: xfs dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 8.8 GiB used: 3.5 MiB (0.0%) priority: -2
dev: /dev/nvme0n1p3
System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB note: est. available: 15.32 GiB used: 3.07 GiB (20.1%)
Processes: 252 Power: uptime: 15h 34m states: freeze,mem,disk
suspend: s2idle wakeups: 2 hibernate: platform Init: systemd v: 255
default: graphical
Packages: pm: pacman pkgs: 1402 Compilers: gcc: 13.2.1 Shell: Zsh v: 5.9
default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.34
