inxi --full --admin --filter --width --repos
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = "en_US.UTF-8",
LC_NUMERIC = "en_DE.UTF-8",
LC_COLLATE = (unset),
LC_TIME = "en_DE.UTF-8",
LC_MESSAGES = (unset),
LC_MONETARY = "en_DE.UTF-8",
LC_ADDRESS = "fi_FI.UTF-8",
LC_IDENTIFICATION = "fi_FI.UTF-8",
LC_MEASUREMENT = "en_DE.UTF-8",
LC_PAPER = "fi_FI.UTF-8",
LC_TELEPHONE = "fi_FI.UTF-8",
LC_NAME = "fi_FI.UTF-8",
LANG = "en_DE.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=db45313e-b2a1-40d2-83e0-d23cc323b07f rw quiet apparmor=1
security=apparmor resume=UUID=cc497015-307a-42aa-ae93-1c2adcef6c85
udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK (MS-7C91) v: 2.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: A.B0 date: 08/25/2022
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102D
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3597 min/max: 550/4951 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3597 2: 3597 3: 3597
4: 3597 5: 3597 6: 3597 7: 3597 8: 3597 9: 3597 10: 3597 11: 3597 12: 3597
13: 3597 14: 3597 15: 3597 16: 3597 17: 3597 18: 3597 19: 3597 20: 3597
21: 3597 22: 3597 23: 3597 24: 3597 bogomips: 177669
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT /
6900 XT] vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-2,HDMI-A-1
empty: DP-1,DP-3,Writeback-1 bus-ID: 2d:00.0 chip-ID: 1002:73bf
class-ID: 0300
Device-2: Microsoft Microsoft LifeCam Studio
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 045e:0811 class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: amdgpu
unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1221 s-dpi: 96 s-size: 1013x322mm (39.88x12.68")
s-diag: 1063mm (41.85")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,bottom-r
model: Acer S240HL serial: <filter> built: 2016 res: mode: 1920x1080 hz: 60
scale: 100% (1) dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77")
diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: top-left model: VA249
serial: <filter> built: 2018 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 XT (radeonsi
navi21 LLVM 19.1.7 DRM 3.61 6.12.19-1-MANJARO) device-ID: 1002:73bf
memory: 15.62 GiB unified: no
API: Vulkan v: 1.4.304 layers: 6 device: 0 type: discrete-gpu name: AMD
Radeon RX 6800 XT (RADV NAVI21) driver: N/A device-ID: 1002:73bf
surfaces: xcb,xlib
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 2d:00.1 chip-ID: 1002:ab28 class-ID: 0403
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Microsoft Microsoft LifeCam Studio
API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 2a:00.0
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, nfsd, sshd, systemd-timesyncd
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3:2
chip-ID: 0a12:0001 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 3.64 TiB used: 1.46 TiB (40.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: WDC WDS200T2B0C-00PXH0 size: 1.82 TiB block-size: physical: 512 B
fw-rev: 21705000 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.76 TiB (98.37%) used: 740.49 GiB (41.2%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-1: swap-1 type: partition size: 34 GiB used: 19.1 MiB (0.1%)
priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 51.1 C mobo: 35.0 C gpu: amdgpu temp: 37.0 C
mem: 34.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Packages: 2568 pm: pacman pkgs: 2513 libs: 521 tools: pamac,yay pm: flatpak
pkgs: 53 pm: snap pkgs: 2
1: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
Memory: total: 32 GiB available: 31.26 GiB used: 10.66 GiB (34.1%)
Processes: 560 Power: uptime: 4h 31m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,upowerd
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: fish v: 4.0.0 default: Bash
v: 5.2.37 running-in: terminator inxi: 3.3.37
I’ll try that.
