Maybe we can make pulseaudio an optional dependency of plasma-pa so that it is unnecessary to uninstall and install plasma-pa
The plasma-pa package is maintained by Arch Linux, so the suggestion should be directed at them.
However, as the package name suggests, it’s an applet to control audio via Pulseaudio.
Is there a reason that sudo pacman -S pipewire-pulse does not work for you?
Arch Linux does not care about Manjaro’s pipewire meta package, so they won’t make changes, just to make a Manjaro meta package work.
And as @Yochanan mentioned:
So when you switch from one audio server to the next, you are expected to put some work into it.
As far as I can read in the thread you mentioned, the meta-package would have worked, if you had uninstalled pulseaudio-jack first. Not everyone has that installed and it has likely not gotten installed by default, so it’s a package you installed, probably to try out jack audio.
My customized version of Plasma uses pipewire and plama-pa - works flawless ![]()
