Greetings to the community, I recently noticed that the keyboard layouts in other languages reset to English and the settings that except through the same plasma settings manager are not being saved correctly, I tried several times logging out to test but it actually restarts .
What caught my attention was a plasma notice about using fcitx 5 for a better experience in Wayland by going to the settings on the virtual keyboard and choosing it but it made no difference to the error.
I thought it could be due to plasma but I opened a session in X11 but it didn’t work, I will leave screenshots and system information for further guidance.
I will also include the configuration that I included manually to avoid the problem of automatically waking up when trying to suspend. I don’t know if I have much connection but it may be useful to know about this.
https://bbs.archlinux.org/viewtopic.php?id=297684
Kernel: 6.6.63-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=c460cb48-27b4-4049-883a-342dc5e27df1 rw quiet splash
udev.log_priority=3 acpi_sleep=nonvs
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: Acer product: Aspire A315-56 v: V1.27 serial: <filter>
Mobo: IL model: Sleepy_IL v: V1.27 serial: <filter>
part-nu: 0000000000000000 uuid: e44d833b-ba16-ec11-80e1-088fc31a4f02
UEFI: Insyde v: 1.27 date: 07/07/2022
ID-1: BAT1 charge: 22.1 Wh (100.0%) condition: 22.1/41.6 Wh (53.1%)
volts: 12.6 min: 11.2 model: LGC AP19B8K type: Li-ion serial: N/A
status: full
System RAM: total: 12 GiB available: 11.48 GiB used: 4.28 GiB (37.3%)
igpu: 64 MiB
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
speed: 2667 MT/s volts: curr: 1.2 min: 1.25 max: 1.35 width (bits): data: 64
total: 64 manufacturer: Crucial part-no: CB8GS2666.C8PT serial: <filter>
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 4 GiB
speed: 2667 MT/s volts: curr: 1.2 min: 1.25 max: 1.5 width (bits): data: 64
total: 64 manufacturer: Kingston part-no: N/A serial: N/A
Info: model: Intel Core i3-1005G1 socket: UC1 bits: 64 type: MT MCP
arch: Ice Lake gen: core 10 level: v4 note: check built: 2019-21
process: Intel 10nm family: 6 model-id: 0x7E (126) stepping: 5
microcode: 0xC6
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB
desc: 2x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1028 min/max: 400/3400 base/boost: 1200/8300 scaling:
driver: intel_pstate governor: powersave volts: 0.7 V ext-clock: 100 MHz
cores: 1: 1028 2: 1028 3: 1028 4: 1028 bogomips: 9524
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good sdbg
sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56
class-ID: 0300
Device-2: Quanta VGA WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 0408:a031
Display: unspecified server: X.Org v: 24.1.4 with: Xwayland v: 24.1.4
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
s-diag: 583mm (22.95")
Monitor-1: eDP-1 model: AU Optronics 0x61ed built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ICL GT1)
device-ID: 8086:8a56 memory: 5.6 GiB unified: yes
API: Vulkan v: 1.3.295 layers: 1 device: 0 type: integrated-gpu name: Intel
UHD Graphics (ICL GT1) driver: mesa intel v: 24.2.7-arch1.1
device-ID: 8086:8a56 surfaces: xcb,xlib
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
API: ALSA v: k6.6.63-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.7 status: n/a (root, process) with:
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5
Local Storage: total: 1.36 TiB used: 567.74 GiB (40.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: PNY model: CS1031 500GB SSD
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: CS103C00 temp: 30.9 C
scheme: GPT
SMART: yes health: PASSED on: 58d 8h cycles: 1,203
read-units: 8,683,584 [4.44 TB] written-units: 5,398,658 [2.76 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-21Z10T0
family: Blue Mobile (SMR) size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5400
serial: <filter> fw-rev: 1A02 temp: 31 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 55d 8h cycles: 3403 Old-Age:
g-sense error rate: 2964
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 124.11 GiB (27.2%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: c460cb48-27b4-4049-883a-342dc5e27df1
used: 296 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: D15E-DD70
ID-3: /mnt/Disco raw-size: 466 GiB size: 931.5 GiB (199.89%)
used: 230.72 GiB (24.8%) fs: exfat block-size: 512 B dev: /dev/sda1
maj-min: 8:1 label: Disco uuid: 4413-F04C
ID-4: /mnt/Steam raw-size: 465.51 GiB size: 457.13 GiB (98.20%)
used: 212.91 GiB (46.6%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: Steam uuid: 39acfe99-dc9b-4cb4-863b-b6526150e8bc
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: SiGma Micro Keyboard TRACER Gamma Ivory
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 1c4f:0002 class-ID: 0300
Device-2: 1-4:3 info: Logitech M185 compact wireless mouse type: mouse
lanes: 1 mode: 1.1 power: 50mA chip-ID: 046d:c542 class-ID: 0301
Device-3: 1-7:4 info: Quanta VGA WebCam type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 0408:a031 class-ID: 0e02 serial: <filter>
Device-4: 1-10:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon or
lm-sensors.
Processes: 212 Power: uptime: 1h 13m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 4.58 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: 1657 pm: pacman pkgs: 1622 libs: 435 tools: pamac pm: flatpak
pkgs: 35 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p1
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
Do you need any specific log?
(Consider this kangaroo my signature jsjsjsj).
