I have a problem running Plasma from lightdm on Manjaro.
This issue has been around for a few updates, but I couldn’t pin it down exactly when it happened. I know that I switched from SDDM to lightdm after I discovered the problem.
The problem is reproducible each time I restart and always follows the same pattern. After a proper launch of Plasma, no other unusual symptoms have been observed.
Scenario
I launch the computer from cold boot, I log in via lightdm.
First launch
- A qt-based application I have in autostart uses the wrong theme different theme (keepassxc)
- KDE’s application launcher which I have in a bar doesn’t respond to the “meta” shortcut
- Overall sluggish experience
- If I kept this session, over time I’d notice some keyboard shortcuts not responding, and some applications spawning but not showing their window
Second launch
- An Xorg native(?) window says that plasma failed to launch, desktop is not shown, upon clicking okay I return to lightdm
Third launch
- Desktop is responsive and as expected
Reports
List of all services enabled
atd.service enabled disabled
bluetooth.service enabled disabled
cronie.service enabled disabled
duplicati.service enabled disabled
getty@.service enabled enabled
haveged.service enabled disabled
lightdm.service enabled disabled
lm_sensors.service enabled disabled
ModemManager.service enabled disabled
NetworkManager-dispatcher.service enabled disabled
NetworkManager-wait-online.service enabled disabled
NetworkManager.service enabled disabled
privoxy.service enabled disabled
rpc-statd.service enabled-runtime disabled
sshd.service enabled disabled
suspend-usb-fix.service enabled disabled
systemd-boot-update.service disabled enabled
systemd-fsck-root.service enabled-runtime disabled
systemd-homed.service disabled enabled
systemd-network-generator.service disabled enabled
systemd-networkd-wait-online.service disabled enabled
systemd-networkd.service disabled enabled
systemd-pstore.service disabled enabled
systemd-remount-fs.service enabled-runtime disabled
systemd-resolved.service disabled enabled
systemd-timesyncd.service enabled enabled
systemd-journald-audit.socket disabled enabled
systemd-userdbd.socket disabled enabled
machines.target disabled enabled
reboot.target disabled enabled
remote-cryptsetup.target disabled enabled
remote-fs.target enabled enabled
pamac-cleancache.timer enabled disabled
pamac-mirrorlist.timer enabled disabled
pkgfile-update.timer enabled disabled
uname
Linux desktop 6.5.11-1-MANJARO #1 SMP PREEMPT_DYNAMIC Thu Nov 9 02:34:53 UTC 2023 x86_64 GNU/Linux
inxi
Kernel: 6.5.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=241227a5-8577-4d5e-8e22-a7a71811402d rw acpi_osi=!
"acpi_osi=Windows 2015" quiet splash
resume=UUID=1b3384a0-ba34-41af-86aa-c7969bda3901 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 7 dm:
1: GDM v: 45.0.1 note: stopped 2: LightDM v: 1.32.0 3: SDDM note: stopped
Type: Desktop Mobo: ASRock model: B660M-ITX/ac serial: <superuser required>
UEFI: American Megatrends LLC. v: 5.03 date: 09/06/2022
Device-1: hidpp_battery_0 model: Logitech Performance MX serial: <filter>
charge: 10% (should be ignored) rechargeable: yes status: discharging
System RAM: total: 16 GiB note: est. available: 15.39 GiB
used: 12.22 GiB (79.4%)
Info: model: 12th Gen Intel Core i5-12600K bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x32
Topology: cpus: 1x cores: 10 mt: 6 tpc: 2 st: 4 threads: 16 smt: enabled
cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32 KiB, 4x64 KiB
L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 938 high: 1466 min/max: 800/4900:3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 948 2: 800 3: 783 4: 1004
5: 812 6: 1362 7: 800 8: 875 9: 1466 10: 1272 11: 801 12: 800 13: 901
14: 799 15: 800 16: 800 bogomips: 118000
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pconfig pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 535.129.03
alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of
2023-11; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 122 s-size: 533x302mm (20.98x11.89")
s-diag: 613mm (24.12")
Monitor-1: Unknown-1 mapped: HDMI-0 res: 2560x1440 hz: 60 dpi: 124
size: 526x296mm (20.71x11.65") modes: 800x600
API: EGL Message: No EGL data available.
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.129.03 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.3.269 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 6GB driver: nvidia v: 535.129.03 device-ID: 10de:1c03
surfaces: xcb,xlib
Device-1: Intel Alder Lake-S HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7ad0
class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10f1 class-ID: 0403
Device-3: GYROCOM C&C NuForce µDAC 2
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-1.2:13 chip-ID: 1852:db96 class-ID: 0102
API: ALSA v: k6.5.11-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.85 status: active with: 1: pipewire-pulse
Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7af0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1d class-ID: 0200
IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7
Local Storage: total: 1.37 TiB used: 399.74 GiB (28.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 66C5 scheme: GPT
ID-1: / raw-size: 429.9 GiB size: 422.08 GiB (98.18%) used: 391.8 GiB (92.8%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 241227a5-8577-4d5e-8e22-a7a71811402d
used: 316 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 03F7-33DD
ID-3: /media/shibe-music raw-size: N/A size: 4.47 TiB
used: 1.77 TiB (39.7%) fs: nfs4 remote: 192.168.88.251:/volume1/music
ID-4: /media/shibe-video raw-size: N/A size: 4.47 TiB
used: 1.77 TiB (39.7%) fs: nfs4 remote: 192.168.88.251:/volume1/video
ID-1: swap-1 type: partition size: 16.93 GiB used: 7.93 GiB (46.8%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: 1b3384a0-ba34-41af-86aa-c7969bda3901
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: E897-5FA0
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 487.64 GiB fs: ntfs label: N/A
uuid: 38E8B2CAE8B285A2
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 537 MiB fs: ntfs label: N/A
uuid: 30401CCE401C9D22
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 465.59 GiB fs: ntfs label: Games
uuid: 9AC4223FC4221E4F
Hub-2: 1-1:12 info: Microchip (formerly SMSC) Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0424:2744
Device-1: 1-1.2:13 info: GYROCOM C&C NuForce µDAC 2 type: HID,audio
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Hub-3: 1-5:14 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-5.3:15 info: Microdia TEMPer Temperature Sensor type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 0c45:7401 class-ID: 0301
Device-2: 1-5.4:16 info: Holtek USB-HID Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 04d9:0114 class-ID: 0300
Device-3: 1-6:3 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-4: 1-9:5 info: ASRock LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a2 class-ID: 0300
serial: <filter>
Device-5: 1-14:7 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-4: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
Hub-5: 2-3:4 info: Microchip (formerly SMSC) Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0424:5744
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (rpm): fan-1: 878 fan-2: 405 fan-3: 0 fan-4: 0 fan-5: 0 fan-7: 0
gpu: nvidia fan: 38%
Processes: 420 Uptime: 1d 12h 5m wakeups: 1 Init: systemd v: 254
Packages: pm: pacman pkgs: 3018 libs: 532
tools: gnome-software,octopi,pamac,yay,yup pm: flatpak pkgs: 0 Shell: Zsh
v: 5.9 running-in: kitty inxi: 3.3.31
journalctl --boot=-1 --priority=3 --catalog --no-pager
lis 19 11:59:50 desktop kernel: hid-generic 0003:1852:DB96.000A: No inputs registered, leaving
lis 19 11:59:51 desktop (udev-worker)[408]: vhba_ctl: /usr/lib/udev/rules.d/60-linux65-vhba.rules:1 Only network interfaces can be renamed, ignoring NAME="vhba_ctl".
lis 19 11:59:51 desktop (udev-worker)[449]: vhba_ctl: /usr/lib/udev/rules.d/60-linux65-vhba.rules:1 Only network interfaces can be renamed, ignoring NAME="vhba_ctl".
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: timeout waiting for FW reset ACK (inta_hw=0x0)
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: Loaded firmware version: 77.f92b5fed.0 so-a0-jf-b0-77.ucode
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x000082F0 | trm_hw_status0
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x004D2A06 | branchlink2
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x004C92BE | interruptlink1
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x004C92BE | interruptlink2
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00011F5A | data1
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x01000000 | data2
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | data3
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | beacon time
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00015D23 | tsf low
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | time gp1
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x000209F6 | time gp2
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x0000004D | uCode version major
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0xF92B5FED | uCode version minor
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000430 | hw version
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00480002 | board version
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x8030FF00 | hcmd
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x20020000 | isr0
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr1
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x58F00002 | isr2
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00C0000C | isr3
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr4
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | last cmd Id
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00011F5A | wait_event
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | timestamp
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000028 | flow_handler
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | ADVANCED_SYSASSERT
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink2
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink1
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink2
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data1
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data2
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data3
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac major
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac minor
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | frame pointer
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | stack pointer
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | last host cmd
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: IML/ROM dump:
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000B03 | IML/ROM error/state
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00004BC2 | IML/ROM data1
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: Fseq Registers:
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x20000000 | FSEQ_ERROR_CODE
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x80320000 | FSEQ_TOP_INIT_VERSION
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00010009 | FSEQ_CNVIO_INIT_VERSION
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x7E9EFE8F | FSEQ_TOP_CONTENT_VERSION
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00080401 | FSEQ_CNVI_ID
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000201 | FSEQ_CNVR_ID
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00080401 | CNVI_AUX_MISC_CHIP
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000201 | CNVR_AUX_MISC_CHIP
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x0BADCAFE | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00000000 | FSEQ_PREV_CNVIO_INIT_VERSION
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x00320000 | FSEQ_WIFI_FSEQ_VERSION
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x7F79B74C | FSEQ_BT_FSEQ_VERSION
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: 0x000000FA | FSEQ_CLASS_TP_VERSION
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: UMAC CURRENT PC: 0x8047e450
lis 19 11:59:51 desktop kernel: iwlwifi 0000:00:14.3: LMAC1 CURRENT PC: 0xd0
lis 19 11:59:53 desktop kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
lis 19 12:00:08 desktop systemd[1]: Failed to mount /media/shibe-lan.
░░ Subject: A start job for unit media-shibe\x2dlan.mount has failed
░░ Defined-By: systemd
░░ A start job for unit media-shibe\x2dlan.mount has finished with a failure.
░░ The job identifier is 124 and the job result is failed.
lis 19 12:00:52 desktop lightdm[1115]: gkr-pam: unable to locate daemon control file
lis 19 12:00:57 desktop libddcutil[1464]: i2c_check_businfo_connector() failed for bus 5
lis 19 12:00:57 desktop libddcutil[1464]: busno=5, sleep-multiplier = 1,30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
lis 19 12:01:34 desktop systemd[1132]: Failed to start KDE Window Manager.
░░ Subject: A start job for unit UNIT has failed
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 242 and the job result is failed.
lis 19 12:01:34 desktop kwin_x11[2011]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, webgl, xcb.
lis 19 12:01:34 desktop systemd-coredump[2018]: Process 2011 (kwin_x11) of user 1000 dumped core.
Stack trace of thread 2011:
#0 0x00007f13f01bf83c n/a (libc.so.6 + 0x8e83c)
#1 0x00007f13f016f668 raise (libc.so.6 + 0x3e668)
#2 0x00007f13f01574b8 abort (libc.so.6 + 0x264b8)
#3 0x00007f13f10a00c2 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0xa00c2)
#4 0x00007f13f173f402 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x13f402)
#5 0x00007f13f173fa79 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x13fa79)
#6 0x00007f13f129bc05 _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x29bc05)
#7 0x00007f13f173fb26 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13fb26)
#8 0x00007f13f0975b9e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x175b9e)
#9 0x00007f13f2c47f35 _ZN4KWin11ApplicationC2ENS0_13OperationModeERiPPc (libkwin.so.5 + 0x247f35)
#10 0x0000559bbb218971 n/a (kwin_x11 + 0x3e971)
#11 0x00007f13f0158cd0 n/a (libc.so.6 + 0x27cd0)
#12 0x00007f13f0158d8a __libc_start_main (libc.so.6 + 0x27d8a)
#13 0x0000559bbb21a425 n/a (kwin_x11 + 0x40425)
Stack trace of thread 2013:
#0 0x00007f13f0233f6f __poll (libc.so.6 + 0x102f6f)
#1 0x00007f13eed6c276 n/a (libglib-2.0.so.0 + 0xb8276)
#2 0x00007f13eed0c162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
#3 0x00007f13f12eaf7c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2eaf7c)
#4 0x00007f13f129ae74 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x29ae74)
#5 0x00007f13f10f74f6 _ZN7QThread4execEv (libQt5Core.so.5 + 0xf74f6)
#6 0x00007f13f0736a9a n/a (libQt5DBus.so.5 + 0x18a9a)
#7 0x00007f13f10f371a n/a (libQt5Core.so.5 + 0xf371a)
#8 0x00007f13f01bd9eb n/a (libc.so.6 + 0x8c9eb)
#9 0x00007f13f02417cc n/a (libc.so.6 + 0x1107cc)
░░ Subject: Process 2011 (kwin_x11) dumped core
░░ Documentation: man:core(5)
░░ Process 2011 (kwin_x11) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
░░ The job identifier is 409 and the job result is failed.
lis 19 12:01:35 desktop kwin_x11[2034]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
lis 19 12:01:36 desktop systemd-coredump[2047]: Process 2034 (kwin_x11) of user 1000 dumped core.
Stack trace of thread 2034:
#0 0x00007f82c4cac83c n/a (libc.so.6 + 0x8e83c)
#1 0x00007f82c4c5c668 raise (libc.so.6 + 0x3e668)
#2 0x00007f82c4c444b8 abort (libc.so.6 + 0x264b8)
#3 0x00007f82c5aa00c2 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0xa00c2)
#4 0x00007f82c613f402 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x13f402)
#5 0x00007f82c613fa79 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x13fa79)
#6 0x00007f82c5c9bc05 _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x29bc05)
#7 0x00007f82c613fb26 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13fb26)
#8 0x00007f82c5375b9e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x175b9e)
#9 0x00007f82c7647f35 _ZN4KWin11ApplicationC2ENS0_13OperationModeERiPPc (libkwin.so.5 + 0x247f35)
#10 0x0000558249b49971 n/a (kwin_x11 + 0x3e971)
#11 0x00007f82c4c45cd0 n/a (libc.so.6 + 0x27cd0)
#12 0x00007f82c4c45d8a __libc_start_main (libc.so.6 + 0x27d8a)
#13 0x0000558249b4b425 n/a (kwin_x11 + 0x40425)
Stack trace of thread 2036:
#0 0x00007f82c4d20f6f __poll (libc.so.6 + 0x102f6f)
#1 0x00007f82c3b6c276 n/a (libglib-2.0.so.0 + 0xb8276)
#2 0x00007f82c3b0c162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
#3 0x00007f82c5ceaf7c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2eaf7c)
#4 0x00007f82c5c9ae74 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x29ae74)
#5 0x00007f82c5af74f6 _ZN7QThread4execEv (libQt5Core.so.5 + 0xf74f6)
#6 0x00007f82c5197a9a n/a (libQt5DBus.so.5 + 0x18a9a)
#7 0x00007f82c5af371a n/a (libQt5Core.so.5 + 0xf371a)
#8 0x00007f82c4caa9eb n/a (libc.so.6 + 0x8c9eb)
#9 0x00007f82c4d2e7cc n/a (libc.so.6 + 0x1107cc)
░░ Subject: Process 2034 (kwin_x11) dumped core
░░ Process 2034 (kwin_x11) crashed and dumped core.
lis 19 12:01:36 desktop systemd[1132]: Failed to start KDE Window Manager.
░░ The job identifier is 430 and the job result is failed.
lis 19 12:01:36 desktop kwin_x11[2066]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
lis 19 12:01:36 desktop systemd-coredump[2079]: Process 2066 (kwin_x11) of user 1000 dumped core.
Stack trace of thread 2066:
#0 0x00007f97936ac83c n/a (libc.so.6 + 0x8e83c)
#1 0x00007f979365c668 raise (libc.so.6 + 0x3e668)
#2 0x00007f97936444b8 abort (libc.so.6 + 0x264b8)
#3 0x00007f97946a00c2 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0xa00c2)
#4 0x00007f9794d3f402 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x13f402)
#5 0x00007f9794d3fa79 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x13fa79)
#6 0x00007f979489bc05 _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x29bc05)
#7 0x00007f9794d3fb26 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13fb26)
#8 0x00007f9793d75b9e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x175b9e)
#9 0x00007f9796247f35 _ZN4KWin11ApplicationC2ENS0_13OperationModeERiPPc (libkwin.so.5 + 0x247f35)
#10 0x000055dd46be1971 n/a (kwin_x11 + 0x3e971)
#11 0x00007f9793645cd0 n/a (libc.so.6 + 0x27cd0)
#12 0x00007f9793645d8a __libc_start_main (libc.so.6 + 0x27d8a)
#13 0x000055dd46be3425 n/a (kwin_x11 + 0x40425)
Stack trace of thread 2074:
#0 0x00007f9793720f6f __poll (libc.so.6 + 0x102f6f)
#1 0x00007f979236c276 n/a (libglib-2.0.so.0 + 0xb8276)
#2 0x00007f979230c162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
#3 0x00007f97948eaf7c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2eaf7c)
#4 0x00007f979489ae74 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x29ae74)
#5 0x00007f97946f74f6 _ZN7QThread4execEv (libQt5Core.so.5 + 0xf74f6)
#6 0x00007f979439fa9a n/a (libQt5DBus.so.5 + 0x18a9a)
#7 0x00007f97946f371a n/a (libQt5Core.so.5 + 0xf371a)
#8 0x00007f97936aa9eb n/a (libc.so.6 + 0x8c9eb)
#9 0x00007f979372e7cc n/a (libc.so.6 + 0x1107cc)
░░ Subject: Process 2066 (kwin_x11) dumped core
░░ Process 2066 (kwin_x11) crashed and dumped core.
░░ The job identifier is 451 and the job result is failed.
lis 19 12:01:36 desktop kwin_x11[2131]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
lis 19 12:01:36 desktop systemd-coredump[2136]: Process 2131 (kwin_x11) of user 1000 dumped core.
Stack trace of thread 2131:
#0 0x00007f67f98ac83c n/a (libc.so.6 + 0x8e83c)
#1 0x00007f67f985c668 raise (libc.so.6 + 0x3e668)
#2 0x00007f67f98444b8 abort (libc.so.6 + 0x264b8)
#3 0x00007f67fa6a00c2 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0xa00c2)
#4 0x00007f67fad3f402 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x13f402)
#5 0x00007f67fad3fa79 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x13fa79)
#6 0x00007f67fa89bc05 _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x29bc05)
#7 0x00007f67fad3fb26 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13fb26)
#8 0x00007f67f9f75b9e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x175b9e)
#9 0x00007f67fc247f35 _ZN4KWin11ApplicationC2ENS0_13OperationModeERiPPc (libkwin.so.5 + 0x247f35)
#10 0x0000563708aa7971 n/a (kwin_x11 + 0x3e971)
#11 0x00007f67f9845cd0 n/a (libc.so.6 + 0x27cd0)
#12 0x00007f67f9845d8a __libc_start_main (libc.so.6 + 0x27d8a)
#13 0x0000563708aa9425 n/a (kwin_x11 + 0x40425)
Stack trace of thread 2132:
#0 0x00007f67f9920f6f __poll (libc.so.6 + 0x102f6f)
#1 0x00007f67f876c276 n/a (libglib-2.0.so.0 + 0xb8276)
#2 0x00007f67f870c162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
#3 0x00007f67fa8eaf7c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2eaf7c)
#4 0x00007f67fa89ae74 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x29ae74)
#5 0x00007f67fa6f74f6 _ZN7QThread4execEv (libQt5Core.so.5 + 0xf74f6)
#6 0x00007f67fab97a9a n/a (libQt5DBus.so.5 + 0x18a9a)
#7 0x00007f67fa6f371a n/a (libQt5Core.so.5 + 0xf371a)
#8 0x00007f67f98aa9eb n/a (libc.so.6 + 0x8c9eb)
#9 0x00007f67f992e7cc n/a (libc.so.6 + 0x1107cc)
░░ Subject: Process 2131 (kwin_x11) dumped core
░░ Process 2131 (kwin_x11) crashed and dumped core.
░░ The job identifier is 472 and the job result is failed.
lis 19 12:01:37 desktop kwin_x11[2145]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
lis 19 12:01:37 desktop systemd-coredump[2150]: Process 2145 (kwin_x11) of user 1000 dumped core.
Stack trace of thread 2145:
#0 0x00007f415ccac83c n/a (libc.so.6 + 0x8e83c)
#1 0x00007f415cc5c668 raise (libc.so.6 + 0x3e668)
#2 0x00007f415cc444b8 abort (libc.so.6 + 0x264b8)
#3 0x00007f415daa00c2 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0xa00c2)
#4 0x00007f415e13f402 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x13f402)
#5 0x00007f415e13fa79 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x13fa79)
#6 0x00007f415dc9bc05 _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x29bc05)
#7 0x00007f415e13fb26 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13fb26)
#8 0x00007f415d375b9e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x175b9e)
#9 0x00007f415f647f35 _ZN4KWin11ApplicationC2ENS0_13OperationModeERiPPc (libkwin.so.5 + 0x247f35)
#10 0x0000564194ea5971 n/a (kwin_x11 + 0x3e971)
#11 0x00007f415cc45cd0 n/a (libc.so.6 + 0x27cd0)
#12 0x00007f415cc45d8a __libc_start_main (libc.so.6 + 0x27d8a)
#13 0x0000564194ea7425 n/a (kwin_x11 + 0x40425)
Stack trace of thread 2146:
#0 0x00007f415cd20f6f __poll (libc.so.6 + 0x102f6f)
#1 0x00007f415b76c276 n/a (libglib-2.0.so.0 + 0xb8276)
#2 0x00007f415b70c162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
#3 0x00007f415dceaf7c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2eaf7c)
#4 0x00007f415dc9ae74 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x29ae74)
#5 0x00007f415daf74f6 _ZN7QThread4execEv (libQt5Core.so.5 + 0xf74f6)
#6 0x00007f415d197a9a n/a (libQt5DBus.so.5 + 0x18a9a)
#7 0x00007f415daf371a n/a (libQt5Core.so.5 + 0xf371a)
#8 0x00007f415ccaa9eb n/a (libc.so.6 + 0x8c9eb)
#9 0x00007f415cd2e7cc n/a (libc.so.6 + 0x1107cc)
░░ Subject: Process 2145 (kwin_x11) dumped core
░░ Process 2145 (kwin_x11) crashed and dumped core.
lis 19 12:01:37 desktop systemd[1132]: Failed to start KDE Window Manager.
░░ The job identifier is 493 and the job result is failed.
░░ The job identifier is 514 and the job result is failed.
lis 19 12:01:38 desktop lightdm[2118]: gkr-pam: unable to locate daemon control file
lis 19 12:01:39 desktop libddcutil[2286]: i2c_check_businfo_connector() failed for bus 5
lis 19 12:01:40 desktop libddcutil[2286]: busno=5, sleep-multiplier = 1,30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
lis 19 12:03:49 desktop systemd[1]: lightdm-plymouth.service: Two services allocated for the same bus name org.freedesktop.DisplayManager, refusing operation.
lis 19 12:03:55 desktop lightdm[2948]: gkr-pam: unable to locate daemon control file
lis 19 12:03:57 desktop libddcutil[3129]: i2c_check_businfo_connector() failed for bus 5
lis 19 12:03:57 desktop libddcutil[3129]: busno=5, sleep-multiplier = 1,30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
lis 19 12:03:58 desktop systemd[1132]: Failed to start picom.
░░ The job identifier is 863 and the job result is failed.
lis 19 12:50:17 desktop systemd[1132]: Failed to start Emacs (Client) - Text Editor.
░░ The job identifier is 1181 and the job result is failed.
lis 20 08:31:18 desktop kernel: hid-generic 0003:1852:DB96.000D: No inputs registered, leaving
lis 20 13:44:30 desktop kioslave5[140085]: libKExiv2: Cannot load metadata from file (Error # Failed to read input data )
lis 20 21:31:31 desktop kernel: hid-generic 0003:1852:DB96.000E: No inputs registered, leaving
lis 21 09:26:42 desktop systemd[1]: Failed to start pkgfile database update.
░░ Subject: A start job for unit pkgfile-update.service has failed
░░ A start job for unit pkgfile-update.service has finished with a failure.
░░ The job identifier is 35179 and the job result is failed.
lis 21 09:43:13 desktop systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
░░ Subject: A start job for unit archlinux-keyring-wkd-sync.service has failed
░░ A start job for unit archlinux-keyring-wkd-sync.service has finished with a failure.
░░ The job identifier is 36149 and the job result is failed.
lis 21 11:28:08 desktop systemd[1132]: Failed to start qpdf.
░░ The job identifier is 1549 and the job result is failed.
lis 21 20:51:10 desktop kernel: hid-generic 0003:1852:DB96.000F: No inputs registered, leaving
lis 22 08:10:47 desktop kernel: hid-generic 0003:1852:DB96.0010: No inputs registered, leaving
lis 23 09:51:25 desktop systemd[1]: Failed to start pkgfile database update.
░░ The job identifier is 65122 and the job result is failed.
lis 23 10:08:11 desktop kernel: hid-generic 0003:1852:DB96.0011: No inputs registered, leaving
lis 27 10:50:48 desktop systemd[1]: Failed to start pkgfile database update.
░░ The job identifier is 80299 and the job result is failed.
lis 27 10:50:49 desktop kernel: Bluetooth: hci0: FW download error recovery failed (-19)
lis 27 10:50:49 desktop kernel: Bluetooth: hci0: sending frame failed (-19)
lis 27 10:50:49 desktop kernel: Bluetooth: hci0: Reading supported features failed (-19)
lis 27 10:50:49 desktop kernel: Bluetooth: hci0: Failed to read MSFT supported features (-19)
lis 27 10:50:49 desktop kernel: hid-generic 0003:1852:DB96.0013: No inputs registered, leaving
lis 27 10:50:50 desktop kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
lis 27 21:45:38 desktop kernel: hid-generic 0003:1852:DB96.0018: No inputs registered, leaving
lis 27 21:57:26 desktop kernel: e1000e 0000:00:1f.6 enp0s31f6: Detected Hardware Unit Hang:
TDH <0>
TDT <f>
next_to_use <f>
next_to_clean <0>
buffer_info[next_to_clean]:
time_stamp <10441a913>
next_to_watch <0>
jiffies <10441b540>
next_to_watch.status <0>
MAC Status <40000043>
PHY Status <796d>
PHY 1000BASE-T Status <0>
PHY Extended Status <3000>
PCI Status <10>
TDH <0>
TDT <f>
next_to_use <f>
next_to_clean <0>
next_to_watch <0>
jiffies <10441b7c0>
PHY Status <796d>
PCI Status <10>
TDH <0>
TDT <f>
next_to_use <f>
next_to_clean <0>
next_to_watch <0>
jiffies <10441ba00>
PHY Status <796d>
PCI Status <10>
lis 27 21:57:26 desktop kernel: e1000e 0000:00:1f.6 enp0s31f6: Reset adapter unexpectedly
lis 27 21:57:26 desktop kernel: nvidia-modeset: ERROR: GPU:0: Failed detecting connected display devices
lis 27 21:57:26 desktop kernel: nvidia-modeset: ERROR: GPU:0: Failure reading maximum pixel clock value for display device HDMI-0.
lis 27 21:57:24 desktop systemd-sleep[1044273]: Failed to put system to sleep. System resumed again: No space left on device
░░ Subject: System sleep state hibernate left
░░ The system has now left the hibernate sleep state.
lis 27 21:57:26 desktop systemd[1]: Failed to start Hibernate.
░░ Subject: A start job for unit systemd-hibernate.service has failed
░░ A start job for unit systemd-hibernate.service has finished with a failure.
░░ The job identifier is 97336 and the job result is failed.
