hello, today the manager has been updated, and the restart with or without mobile-data works
but if mobile-data is on and the phone is inactive, you have to do a sudo systemctl restart ofonoctl
so if you do not need or no longer need mobile-data, consider switching it off
Still problems with ofonoctl because after inactivity it is impossible to send a text or a text message without rearming
Well, by dint of touching, retouching, I ended up redoing everything and I re-installed “Manjaro-ARM-plasma-mobile-pinephone-20210423” and made an update … following the next issue
bonjour,
Positive test, I took the motorbike bmw scrambler, went shopping, came back with such, ofonoctl hold on tight and the wifi hangs up correctly,
excellent experience
