And how can I find which app is GTK or QT? (I don’t know much about these)
That can be a problem, if you do everything from the GUI stores.
But you can always check the dependencies, which often contains the toolkit it uses, with:
pacman -Qi <packagename>
Thanks (I really appreciate your time and patience with linux n00bs like me),
I don’t do everything in GUI but you are right. I for example couldn’t uninstall Telegram (because it is purpose’s voluntary dependence), and it didn’t work in discover, didn’t work in pacman and it all solved pamac
- and that’s one of the reasons I still use GUI (I know, pamac can run in terminal, too - but then It loses it’s point of being a GUI for pacman)
