Every time i try to login into ‘henrique’ it just goes into a black screen for ~2 seconds then it goes back to the login screen, this is one of the users that i had created on Linux Mint, the other one works fine but for some reason this one doesn’t.
I used ‘ls’ on /home/henrique and this is what shows up:
community-patches Downloads Public Templates wine-tkg-git
Desktop Music settings Videos
Documents Pictures Steam winehq.key
i tried deleting and recreating the user but keeping the home directory, but that didnt work so i guess the problem is with the home/henrique folder
I solved the problem by renaming the home folder to ‘henri’, creating a new ‘home/henrique’ for my user with the terminal, login into my user, and then copying most files from ‘henri’ to ‘henrique’ (i only copied some files from .config and .local)
