Plasma freezes often
Hello,
I have problem with KDE Plasma environment. I’m using stable branch and problems started to appear relatively recently (being using KDE for more than 2 years, problem started about 1 month ago).
During normal use of the laptop plasmashell will freeze completely (I can’t use any panels, alt+f2 doesn’t work), but previously started applications working fine, I can switch between virtual desktops and use Yakuyake with no problem.
It occurs in different periods of time, from 1 hour to like few minutes between freezes.
I tried to check journalctl but haven’t found anything suspicious. Usually I resolve this problem with restarting plasmashell from terminal.
Did someone have something similar?
What kind of logs I can provide to make it easier to investigate?
Hi,
Yes, i have the same problem too, even it can freeze all my screen for awhile, mouse can be moved, the response is slow, especially if i use a second screen.
I use default settings/theme from the beginning of the installation.
Similar problem was reported on KDE forum, but no solution yet available:
Hi,
Can I ask which kernel you using?
It seems that for my problem I cann’t reproduce it if I switch back to the 4.19 series kernel.
Hello, i have the same problem.
I’m on lenovo thinkpad x260 with manjaro kde freshly installed less than a week ago. The problem has always been persistent from the beginning. :unamused:
Recently I switched from kernel 5.7 to kernel 5.4 LTS with no luck, obviously.
I tried the Timeshift fix as mentioned in a different thread, but the problem is still present.
I may suggest you to try to switch to 4.19 kernel - for me it seems problem was resolved.
Have the same.
Have you tried to Ctrl+Alt+F7 and then Ctrl+Alt+F1? For me it makes plasma alive. But unfortunately, no solution…
I also noticed that functionality is alive, but drawing freezes.
Happens to me too. Kernel 4.19 doesn’t help, switching tty also. I have to restart Plasma to unfreeze.
i used 5.9, 5.8, 5.7, 5.4. All got the issue
Have you tried 4.14?
Here’s journalctl -f a few minutes after the freeze happened (clock stopped at 15:06). I don’t know if that’s helpful.
Sep 16 15:12:15 user-pc kwin_x11[490]: Could not attach Keys property to: PlasmaQuick::Dialog(0x555f95e82b40) is not an Item
Sep 16 15:12:15 user-pc kwin_x11[490]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/windowswitcher/WindowSwitcher.qml:62:17: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { … }
Sep 16 15:12:15 user-pc kwin_x11[490]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:60:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { … }
Sep 16 15:12:15 user-pc kwin_x11[490]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Sep 16 15:12:15 user-pc kwin_x11[490]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:47:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { … }
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48146, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48147, resource id: 12583118, major code: 55 (CreateGC), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48148, resource id: 12583118, major code: 72 (PutImage), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48149, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48150, resource id: 12583120, major code: 55 (CreateGC), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48151, resource id: 12583120, major code: 72 (PutImage), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48152, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48153, resource id: 12583122, major code: 55 (CreateGC), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48154, resource id: 12583122, major code: 72 (PutImage), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48155, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48156, resource id: 12583124, major code: 55 (CreateGC), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48157, resource id: 12583124, major code: 72 (PutImage), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48158, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48159, resource id: 12583126, major code: 55 (CreateGC), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48160, resource id: 12583126, major code: 72 (PutImage), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48161, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48162, resource id: 12583128, major code: 55 (CreateGC), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48163, resource id: 12583128, major code: 72 (PutImage), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48164, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48165, resource id: 12583130, major code: 55 (CreateGC), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48166, resource id: 12583130, major code: 72 (PutImage), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 48167, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48168, resource id: 12583132, major code: 55 (CreateGC), minor code: 0
Sep 16 15:12:15 user-pc kwin_x11[490]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 48169, resource id: 12583132, major code: 72 (PutImage), minor code: 0
Sep 16 15:12:16 user-pc kwin_x11[490]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Sep 16 15:12:16 user-pc kwin_x11[490]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:47:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { … }
A few minutes later another freeze (15:23):
Sep 16 15:24:34 user-pc kwin_x11[490]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Sep 16 15:24:34 user-pc kwin_x11[490]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:47:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { … }
Sep 16 15:24:36 user-pc kwin_x11[490]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
I have a similar issue when using nVidia GPU on 450.66 driver and with external screen. But for me freezes never happen randomly: the desktop seems to freeze when the automatic screen lock due to inactivity is supposed to be engaged, or also right after waking up from suspend (in which case I have a black screen with working mouse). Sometimes this does not happen and expected behavior occurs instead.
In all cases the workaround which I use is to kill kscreenlocker_greet process. It helps, but it would be good to eliminate the issue completely.
With me it is exactly the same. Everything except the curser freezes and always when the automatic lock should happen.
Latest update didn’t help.
I’m part of this club now having same issue, hope it get resolve
Hey there,
I have the same issue since I reinstalled my Laptop. (with manjaro-architect (+zfs on root, + luks) kernel is linux57).
However I figured if I don´ t open certain applications (such as spotify (from AUR)), everything works fine for me. (Spotify in Firefox does work ;D)
(at least firefox, konsole, teamspeak, telegram, intellij, rocketchat, chromium do work without the problem occuring in my case.)
Can anyone confirm this behavior ?
Recently, I had some freezes in plasmashell, so i had to killall and restart plasmashell. I’ll try to switch to kernel 5.9. Also, i found out a possible solution in my specific case (Thinkpad x260, intel core i3, 16gb ram) → ThinkPad X260 screen freezes for a few seconds / Newbie Corner / Arch Linux Forums
I don’t think this solution will work, but I’ll try anyway :confused:
I am having the same problem and my journalctl looks similar, with lots of stuff like this:
Oct 31 01:23:13 workstation plasmashell[3350]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml:78:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 31 01:23:18 workstation kwin_x11[3256]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59170, resource id: 31458007, major code: 20 (GetProperty), minor code: 0
Oct 31 01:23:18 workstation kwin_x11[3256]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 59171, resource id: 31458007, major code: 15 (QueryTree), minor code: 0
Oct 31 01:24:39 workstation msm_kde_notifier[3610]: "qt5-translations"
Oct 31 01:32:21 workstation systemd[1]: Started Getty on tty2.
Oct 31 01:32:21 workstation audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 31 01:32:21 workstation kernel: audit: type=1130 audit(1604122341.298:96): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 31 01:32:21 workstation org_kde_powerdevil[4107]: powerdevil: ACTIVE SESSION PATH CHANGED: "/"
I am using a GTX1060 with Nouveau drivers, with three monitors.
yeah, i got same issue, sometimes i am just even browsing and it freezes for no reason; kernel : linux 58 by the way,
but after a few minutes it just goes back working
I had a manjaro kde with same problem some months ago and I fixed mine by not doing opengl compositing! I think nvidia drives does not like open gl on kde?
