I am locked in to using Windows for some of the time.
The kvm switch is a high quality expensive unit an has worked without a glitch all these years.
I change to user B when Plasma is behaving normally
Then, switching to Windows and back does not cause the 1 minute delay problem - ie Plasma responds immediately as it should.
So clearly there is an issue in my Plasma config …
Trying to fix it without having to start with a new user …
Please create a new user account (for diagnostic purposes) and update us as to whether or not any of the issues persist when performing these actions from the new account.
Additionally, please provide system information as described (below).
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
A clear indication that the problem is limited to your account.
There are two ways to remedy this;
A) Clean up your current account and find whatever might be causing the problem. You might learn something about maintaining your system in the process if you take this route; or:
B) Spend the time necessary to create/use a fresh account, and hopefully leave all your troubles behind.
Without knowing what you may have installed, misconfigured, or otherwise done to contribute to the issues you’re experiencing, any specific insights are difficult to magically will into being, and likely to be time intensive; the game of 1000 questions.
The fastest way back to normalcy seems clear.
The KVM
No matter the relative quality of any hardware or how long it might have admirably performed it’s function, I’m afraid that Murphy’s Law always prevails; there may come a time when that hardware fails, or falters.
Off topic;
Many of us are to varying degrees; either by circumstance or necessity (but seldom by choice).
Have you considered multi-booting with Windows and Manjaro on the same computer (but separate disks)?
Some time ago I authored a guide for doing just that;
I hope you find it useful at some point.
Providing it may help members to identify other possible contributors to your problems. It is also the minimum information usually requested in a Support context.
I too run a separate Windows system (Lenovo M75q as tiny as it gets) - not because I am forced to it - but because it is convenient for me and my employment - all work related stuff is on that box - and when the time comes I simply hand over the box to my employer including login credentials - then they can assign whomever they want to continue where I left off.
As I never found the switch solution attractive - I am running the system headless and access it using remmina and remote desktop and that is by any measure better than having to deal with virtual machines loosing network or refuse to load.
As the OP has avoided providing system information and marked a solution with two options given - the latter being to reinstall Manjaro - we can safely presume the latter was chosen, which means this topic is useless to anyone.
