As discovered previously with the help of Fabby, that after last update plasma-firewall
started blocking my KDE Connect from connecting and the PC being discoverable.
How do I make my KDE Connect work properly again?
Best regards,
Marko
Best regards,
Marko
Unlock ports 1714-1764.
I am a novice. Can you please explain in more detail what would need to do?
Based on
My outputs:
sudo netstat -tunelp | grep -i kdeconnect
tcp6 0 0 :::1716 :::* LISTEN 1000 25622 1035/kdeconnectd
udp6 0 0 :::1716 :::* 1000 25621 1035/kdeconnec
netcat -z -v 192.168.0.13 1714-1764
latitux.local [192.168.0.13] 1716 (xmsg) open
KDE Connect listens to 1716 and it seems to be open.
Is it or is it not?
If it is, what Tomek is trying to tell you is:
open all ports from 1714 up to and including 1764.
If it is not or you don’t know, please read the documentation of plasma-firewall
as neither of us is running that, so we cannot tell you what to do exactly; we can just point you in the right direction…
You can do it via GUI, just go to system settings or via terminal - exact command depends on what firewall backend you use, ufw
or firewald
Via GUI it seems I need to do it manually. All the 50 ports one by one. That’s why I tried to identify which port KDE Connect uses. But yeah - it seems not enough to verify that 1716 is open.
Along the way I tried to see if I find the docs for plasma-firewall
. Only managed to find the git-hub page for the package and some generic KDE pages. Probs my google-fu on duckduck go needs to be a bit better.
I’ll try again a more focused (as in ‘less narrowing’ probably) search, when I can.
EDIT:
In KDE Docs didn’t manage to find anything on plasma-firewall
My backend is ufw
. "OP on opening port ranges in ufw
" (https://askubuntu.com/questions/7099/how-can-i-open-a-range-of-ports-in-ubuntu-using-gufw)
sudo ufw allow 1716:1764/udp
That command solved the issue.
Thanks guys!!
Only strange thing is that plasma-firewall
doesn’t let to add port ranges in the rule creation dialog.
It shows the rule as an image but doesn’t let type : in the port field. Might be that it just shows what backend tells it.
