Heya, have an issue with my Manjaro KDE Edition. It boots SUPER slow currently and has this error message (it shows the same error message for all my mount points, so not only / but also /boot/efi, home and so on). I have searched the internet for a solution or a reason, but couldn’t find one yet. I often found the question for the boot sequence via systemd-analyze;systemd-analyze blame --no-pager, so here we go:
Startup finished in 25.232s (firmware) + 5.466s (loader) + 1.857s (kernel) + 8.345s (userspace) = 40.901s
graphical.target reached after 1.433s in userspace.
6.910s tlp.service
463ms udisks2.service
276ms dev-nvme0n1p1.device
188ms cups.service
187ms systemd-binfmt.service
187ms misc.mount
176ms lm_sensors.service
175ms systemd-timesyncd.service
171ms backup.mount
139ms stuff.mount
128ms lvm2-monitor.service
123ms ModemManager.service
107ms user@1000.service
107ms libvirtd.service
97ms systemd-journal-flush.service
66ms upower.service
66ms boot-efi.mount
57ms systemd-fsck@dev-disk-by\x2duuid-6e5bb07a\x2df0af\x2d41f4\x2dbab2\x2d648a80faefe6.service
52ms systemd-fsck@dev-disk-by\x2duuid-ABD5\x2dEF9B.service
50ms systemd-udevd.service
49ms systemd-modules-load.service
48ms systemd-udev-trigger.service
47ms systemd-tmpfiles-clean.service
36ms NetworkManager.service
31ms systemd-journald.service
29ms polkit.service
29ms avahi-daemon.service
29ms systemd-fsck@dev-disk-by\x2duuid-fc6a43bb\x2dec9a\x2d4f23\x2d94e9\x2deff7cf5f250c.service
27ms dbus.service
26ms systemd-logind.service
26ms systemd-machined.service
25ms colord.service
25ms systemd-fsck@dev-disk-by\x2duuid-c2f96969\x2dea60\x2d4b02\x2d95bd\x2d9daad2ac2f0e.service
22ms virtual.mount
21ms systemd-tmpfiles-setup.service
19ms home.mount
19ms systemd-fsck-root.service
17ms systemd-tmpfiles-setup-dev.service
12ms bluetooth.service
7ms dev-hugepages.mount
6ms dev-mqueue.mount
6ms modprobe@fuse.service
5ms systemd-random-seed.service
5ms sys-kernel-debug.mount
5ms data.mount
5ms sys-kernel-tracing.mount
4ms tmp.mount
4ms kmod-static-nodes.service
4ms user-runtime-dir@1000.service
3ms alsa-restore.service
3ms modprobe@configfs.service
3ms systemd-remount-fs.service
3ms modprobe@drm.service
3ms systemd-rfkill.service
2ms systemd-update-utmp.service
2ms systemd-sysctl.service
1ms rtkit-daemon.service
1ms systemd-user-sessions.service
1ms proc-sys-fs-binfmt_misc.mount
722us sys-fs-fuse-connections.mount
694us sys-kernel-config.mount
I also found often some hints towards “too much IO on the filesystem” or problems with harddisks, so I also performed SMART tests - without any issue. No bad sectors, reallocated stuff or similar. SSDs are two NVME (2TB Seagate Firecuda 530) and one Samsung 870 pro, and there is a Seagate Exos x16 16TB also available.
dmesg shows no real help - at least for the nub that I am:
[ 0.000000] Linux version 6.0.2-2-MANJARO (builduser@fv-az628-669) (gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0) #1 SMP PREEMPT_DYNAMIC Sat Oct 15 13:31:58 UTC 2022
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64 root=UUID=f8b3941a-e541-4f5d-b8d9-be01fa0cf445 ro quiet udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[9]: 832, xstate_sizes[9]: 8
[ 0.000000] x86/fpu: Enabled xstate features 0x207, context size is 840 bytes, using 'compacted' format.
[ 0.000000] signal: max sigframe size: 3376
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000009d81fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009d82000-0x0000000009ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000a200000-0x000000000a20dfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000000a20e000-0x00000000cb452fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000cb453000-0x00000000cb453fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000cb454000-0x00000000cb4a1fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000cb4a2000-0x00000000cb4a2fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000cb4a3000-0x00000000db0a6fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000db0a7000-0x00000000db4a3fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000db4a4000-0x00000000db507fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000db508000-0x00000000dcc06fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000dcc07000-0x00000000ddb56fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ddb57000-0x00000000ddbfefff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000ddbff000-0x00000000deffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000df000000-0x00000000dfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fd100000-0x00000000fd1fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fd300000-0x00000000fd4fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fea00000-0x00000000fea0ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000101f2fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000101f300000-0x000000101fffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI=0xdcbee000 ACPI 2.0=0xdcbee014 SMBIOS=0xdda05000 MEMATTR=0xd8ff9698 ESRT=0xd99ec198
[ 0.000000] SMBIOS 2.8 present.
[ 0.000000] DMI: Micro-Star International Co., Ltd. MS-7C84/MAG X570 TOMAHAWK WIFI (MS-7C84), BIOS 1.70 06/23/2021
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3400.228 MHz processor
[ 0.000113] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000115] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000120] last_pfn = 0x101f300 max_arch_pfn = 0x400000000
[ 0.000553] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000705] total RAM covered: 3583M
[ 0.000780] Found optimal setting for mtrr clean up
[ 0.000780] gran_size: 64K chunk_size: 64M num_reg: 4 lose cover RAM: 0G
[ 0.000852] e820: update [mem 0xdc9b0000-0xdc9bffff] usable ==> reserved
[ 0.000855] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[ 0.000857] last_pfn = 0xdf000 max_arch_pfn = 0x400000000
[ 0.003365] esrt: Reserving ESRT space from 0x00000000d99ec198 to 0x00000000d99ec1f8.
[ 0.003371] e820: update [mem 0xd99ec000-0xd99ecfff] usable ==> reserved
[ 0.003397] Using GB pages for direct mapping
[ 0.003695] Secure boot disabled
[ 0.003696] RAMDISK: [mem 0x37025000-0x37809fff]
[ 0.003699] ACPI: Early table checksum verification disabled
[ 0.003701] ACPI: RSDP 0x00000000DCBEE014 000024 (v02 ALASKA)
[ 0.003704] ACPI: XSDT 0x00000000DCBED728 0000D4 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.003707] ACPI: FACP 0x00000000DB4F9000 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.003710] ACPI: DSDT 0x00000000DB4F2000 006FD3 (v02 ALASKA A M I 01072009 INTL 20120913)
[ 0.003712] ACPI: FACS 0x00000000DCBE8000 000040
[ 0.003713] ACPI: SSDT 0x00000000DB4FF000 008C98 (v02 AMD AmdTable 00000002 MSFT 04000000)
[ 0.003715] ACPI: SSDT 0x00000000DB4FB000 003B1B (v01 AMD AMD AOD 00000001 INTL 20120913)
[ 0.003716] ACPI: SSDT 0x00000000DB4FA000 0001CC (v02 ALASKA CPUSSDT 01072009 AMI 01072009)
[ 0.003718] ACPI: FIDT 0x00000000DB4F1000 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.003719] ACPI: MCFG 0x00000000DB4F0000 00003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.003721] ACPI: HPET 0x00000000DB4EF000 000038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.003722] ACPI: SSDT 0x00000000DB4EE000 000024 (v01 AMD BIXBY 00001000 INTL 20120913)
[ 0.003723] ACPI: IVRS 0x00000000DB4ED000 0000D0 (v02 AMD AmdTable 00000001 AMD 00000001)
[ 0.003725] ACPI: VFCT 0x00000000DB4E2000 00AC84 (v01 ALASKA A M I 00000001 AMD 31504F47)
[ 0.003726] ACPI: PCCT 0x00000000DB4E1000 00006E (v02 AMD AmdTable 00000001 AMD 00000001)
[ 0.003728] ACPI: SSDT 0x00000000DB4D9000 007E89 (v02 AMD AmdTable 00000001 AMD 00000001)
[ 0.003729] ACPI: CRAT 0x00000000DB4D7000 001698 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.003730] ACPI: CDIT 0x00000000DB4D6000 000029 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.003732] ACPI: SSDT 0x00000000DB4D5000 000293 (v01 AMD QOGIRDGP 00000001 INTL 20120913)
[ 0.003733] ACPI: SSDT 0x00000000DB4D3000 0010B4 (v01 AMD QOGIRTPX 00000001 INTL 20120913)
[ 0.003735] ACPI: SSDT 0x00000000DB4D2000 00052C (v01 AMD QOGIRNOI 00000001 INTL 20120913)
[ 0.003736] ACPI: SSDT 0x00000000DB4CE000 00381A (v01 AMD QOGIRN 00000001 INTL 20120913)
[ 0.003737] ACPI: WSMT 0x00000000DB4CD000 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.003739] ACPI: APIC 0x00000000DB4CC000 00015E (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.003740] ACPI: SSDT 0x00000000DB4CA000 0010AF (v01 AMD QOGIRC 00000001 INTL 20120913)
[ 0.003741] ACPI: FPDT 0x00000000DB4C9000 000044 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.003743] ACPI: Reserving FACP table memory at [mem 0xdb4f9000-0xdb4f9113]
[ 0.003743] ACPI: Reserving DSDT table memory at [mem 0xdb4f2000-0xdb4f8fd2]
[ 0.003744] ACPI: Reserving FACS table memory at [mem 0xdcbe8000-0xdcbe803f]
[ 0.003744] ACPI: Reserving SSDT table memory at [mem 0xdb4ff000-0xdb507c97]
[ 0.003745] ACPI: Reserving SSDT table memory at [mem 0xdb4fb000-0xdb4feb1a]
[ 0.003745] ACPI: Reserving SSDT table memory at [mem 0xdb4fa000-0xdb4fa1cb]
[ 0.003745] ACPI: Reserving FIDT table memory at [mem 0xdb4f1000-0xdb4f109b]
[ 0.003746] ACPI: Reserving MCFG table memory at [mem 0xdb4f0000-0xdb4f003b]
[ 0.003746] ACPI: Reserving HPET table memory at [mem 0xdb4ef000-0xdb4ef037]
[ 0.003747] ACPI: Reserving SSDT table memory at [mem 0xdb4ee000-0xdb4ee023]
[ 0.003747] ACPI: Reserving IVRS table memory at [mem 0xdb4ed000-0xdb4ed0cf]
[ 0.003747] ACPI: Reserving VFCT table memory at [mem 0xdb4e2000-0xdb4ecc83]
[ 0.003748] ACPI: Reserving PCCT table memory at [mem 0xdb4e1000-0xdb4e106d]
[ 0.003748] ACPI: Reserving SSDT table memory at [mem 0xdb4d9000-0xdb4e0e88]
[ 0.003749] ACPI: Reserving CRAT table memory at [mem 0xdb4d7000-0xdb4d8697]
[ 0.003749] ACPI: Reserving CDIT table memory at [mem 0xdb4d6000-0xdb4d6028]
[ 0.003750] ACPI: Reserving SSDT table memory at [mem 0xdb4d5000-0xdb4d5292]
[ 0.003750] ACPI: Reserving SSDT table memory at [mem 0xdb4d3000-0xdb4d40b3]
[ 0.003750] ACPI: Reserving SSDT table memory at [mem 0xdb4d2000-0xdb4d252b]
[ 0.003751] ACPI: Reserving SSDT table memory at [mem 0xdb4ce000-0xdb4d1819]
[ 0.003751] ACPI: Reserving WSMT table memory at [mem 0xdb4cd000-0xdb4cd027]
[ 0.003752] ACPI: Reserving APIC table memory at [mem 0xdb4cc000-0xdb4cc15d]
[ 0.003752] ACPI: Reserving SSDT table memory at [mem 0xdb4ca000-0xdb4cb0ae]
[ 0.003752] ACPI: Reserving FPDT table memory at [mem 0xdb4c9000-0xdb4c9043]
[ 0.003790] No NUMA configuration found
[ 0.003790] Faking a node at [mem 0x0000000000000000-0x000000101f2fffff]
[ 0.003792] NODE_DATA(0) allocated [mem 0x101f2fc000-0x101f2fffff]
[ 0.003834] Zone ranges:
[ 0.003834] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.003835] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.003836] Normal [mem 0x0000000100000000-0x000000101f2fffff]
[ 0.003837] Device empty
[ 0.003837] Movable zone start for each node
[ 0.003838] Early memory node ranges
[ 0.003838] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.003839] node 0: [mem 0x0000000000100000-0x0000000009d81fff]
[ 0.003839] node 0: [mem 0x000000000a000000-0x000000000a1fffff]
[ 0.003840] node 0: [mem 0x000000000a20e000-0x00000000cb452fff]
[ 0.003840] node 0: [mem 0x00000000cb454000-0x00000000cb4a1fff]
[ 0.003841] node 0: [mem 0x00000000cb4a3000-0x00000000db0a6fff]
[ 0.003841] node 0: [mem 0x00000000ddbff000-0x00000000deffffff]
[ 0.003841] node 0: [mem 0x0000000100000000-0x000000101f2fffff]
[ 0.003844] Initmem setup node 0 [mem 0x0000000000001000-0x000000101f2fffff]
[ 0.003847] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.003856] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.003927] On node 0, zone DMA32: 638 pages in unavailable ranges
[ 0.005804] On node 0, zone DMA32: 14 pages in unavailable ranges
[ 0.005805] On node 0, zone DMA32: 1 pages in unavailable ranges
[ 0.006016] On node 0, zone DMA32: 1 pages in unavailable ranges
[ 0.006080] On node 0, zone DMA32: 11096 pages in unavailable ranges
[ 0.056428] On node 0, zone Normal: 4096 pages in unavailable ranges
[ 0.056444] On node 0, zone Normal: 3328 pages in unavailable ranges
[ 0.057129] ACPI: PM-Timer IO Port: 0x808
[ 0.057135] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.057143] IOAPIC[0]: apic_id 33, version 33, address 0xfec00000, GSI 0-23
[ 0.057147] IOAPIC[1]: apic_id 34, version 33, address 0xfec01000, GSI 24-55
[ 0.057148] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.057150] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.057152] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.057153] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.057156] smpboot: Allowing 32 CPUs, 0 hotplug CPUs
[ 0.057258] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.057259] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.057260] PM: hibernation: Registered nosave memory: [mem 0x09d82000-0x09ffffff]
[ 0.057261] PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a20dfff]
[ 0.057262] PM: hibernation: Registered nosave memory: [mem 0xcb453000-0xcb453fff]
[ 0.057263] PM: hibernation: Registered nosave memory: [mem 0xcb4a2000-0xcb4a2fff]
[ 0.057264] PM: hibernation: Registered nosave memory: [mem 0xd99ec000-0xd99ecfff]
[ 0.057264] PM: hibernation: Registered nosave memory: [mem 0xdb0a7000-0xdb4a3fff]
[ 0.057265] PM: hibernation: Registered nosave memory: [mem 0xdb4a4000-0xdb507fff]
[ 0.057265] PM: hibernation: Registered nosave memory: [mem 0xdb508000-0xdcc06fff]
[ 0.057265] PM: hibernation: Registered nosave memory: [mem 0xdcc07000-0xddb56fff]
[ 0.057266] PM: hibernation: Registered nosave memory: [mem 0xddb57000-0xddbfefff]
[ 0.057267] PM: hibernation: Registered nosave memory: [mem 0xdf000000-0xdfffffff]
[ 0.057267] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.057267] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xf7ffffff]
[ 0.057268] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfd0fffff]
[ 0.057268] PM: hibernation: Registered nosave memory: [mem 0xfd100000-0xfd1fffff]
[ 0.057268] PM: hibernation: Registered nosave memory: [mem 0xfd200000-0xfd2fffff]
[ 0.057269] PM: hibernation: Registered nosave memory: [mem 0xfd300000-0xfd4fffff]
[ 0.057269] PM: hibernation: Registered nosave memory: [mem 0xfd500000-0xfe9fffff]
[ 0.057269] PM: hibernation: Registered nosave memory: [mem 0xfea00000-0xfea0ffff]
[ 0.057270] PM: hibernation: Registered nosave memory: [mem 0xfea10000-0xfeb7ffff]
[ 0.057270] PM: hibernation: Registered nosave memory: [mem 0xfeb80000-0xfec01fff]
[ 0.057270] PM: hibernation: Registered nosave memory: [mem 0xfec02000-0xfec0ffff]
[ 0.057271] PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[ 0.057271] PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfecfffff]
[ 0.057271] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ 0.057272] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed3ffff]
[ 0.057272] PM: hibernation: Registered nosave memory: [mem 0xfed40000-0xfed44fff]
[ 0.057272] PM: hibernation: Registered nosave memory: [mem 0xfed45000-0xfed7ffff]
[ 0.057273] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[ 0.057273] PM: hibernation: Registered nosave memory: [mem 0xfed90000-0xfedc1fff]
[ 0.057273] PM: hibernation: Registered nosave memory: [mem 0xfedc2000-0xfedcffff]
[ 0.057273] PM: hibernation: Registered nosave memory: [mem 0xfedd0000-0xfedd3fff]
[ 0.057274] PM: hibernation: Registered nosave memory: [mem 0xfedd4000-0xfedd5fff]
[ 0.057274] PM: hibernation: Registered nosave memory: [mem 0xfedd6000-0xfeffffff]
[ 0.057274] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.057275] [mem 0xe0000000-0xefffffff] available for PCI devices
[ 0.057277] Booting paravirtualized kernel on bare hardware
[ 0.057279] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.059895] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:32 nr_node_ids:1
[ 0.060533] percpu: Embedded 63 pages/cpu s221184 r8192 d28672 u262144
[ 0.060539] pcpu-alloc: s221184 r8192 d28672 u262144 alloc=1*2097152
[ 0.060540] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.060545] pcpu-alloc: [0] 16 17 18 19 20 21 22 23 [0] 24 25 26 27 28 29 30 31
[ 0.060563] Fallback order for Node 0: 0
[ 0.060568] Built 1 zonelists, mobility grouping on. Total pages: 16495941
[ 0.060568] Policy zone: Normal
[ 0.060569] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64 root=UUID=f8b3941a-e541-4f5d-b8d9-be01fa0cf445 ro quiet udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
[ 0.060617] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64", will be passed to user space.
[ 0.060620] printk: log_buf_len individual max cpu contribution: 4096 bytes
[ 0.060620] printk: log_buf_len total cpu_extra contributions: 126976 bytes
[ 0.060621] printk: log_buf_len min size: 131072 bytes
[ 0.060715] printk: log_buf_len: 262144 bytes
[ 0.060716] printk: early log buf free: 115848(88%)
[ 0.063050] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.064218] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.064357] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.064383] software IO TLB: area num 32.
[ 0.131079] Memory: 65682204K/67031780K available (16391K kernel code, 2096K rwdata, 11360K rodata, 2128K init, 3464K bss, 1349316K reserved, 0K cma-reserved)
[ 0.131521] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=1
[ 0.131538] ftrace: allocating 45936 entries in 180 pages
[ 0.137761] ftrace: allocated 180 pages with 4 groups
[ 0.137824] Dynamic Preempt: full
[ 0.137885] rcu: Preemptible hierarchical RCU implementation.
[ 0.137886] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=32.
[ 0.137886] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.137887] Trampoline variant of Tasks RCU enabled.
[ 0.137887] Rude variant of Tasks RCU enabled.
[ 0.137888] Tracing variant of Tasks RCU enabled.
[ 0.137888] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.137888] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=32
[ 0.140107] NR_IRQS: 20736, nr_irqs: 1224, preallocated irqs: 16
[ 0.140280] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.140340] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.140359] random: crng init done
[ 0.140383] Console: colour dummy device 80x25
[ 0.140393] printk: console [tty0] enabled
[ 0.140411] ACPI: Core revision 20220331
[ 0.140507] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.140521] APIC: Switch to symmetric I/O mode setup
[ 0.141137] AMD-Vi: Using global IVHD EFR:0x0, EFR2:0x0
[ 0.306796] Switched APIC routing to physical flat.
[ 0.307283] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.323842] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x3103268fa90, max_idle_ns: 440795354048 ns
[ 0.323844] Calibrating delay loop (skipped), value calculated using timer frequency.. 6803.80 BogoMIPS (lpj=11334093)
[ 0.323846] pid_max: default: 32768 minimum: 301
[ 0.325327] LSM: Security Framework initializing
[ 0.325332] landlock: Up and running.
[ 0.325333] Yama: becoming mindful.
[ 0.325338] LSM support for eBPF active
[ 0.325400] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.325454] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.325599] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.325643] LVT offset 1 assigned for vector 0xf9
[ 0.325753] LVT offset 2 assigned for vector 0xf4
[ 0.325782] process: using mwait in idle threads
[ 0.325783] Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
[ 0.325784] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
[ 0.325786] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.325787] Spectre V2 : Mitigation: Retpolines
[ 0.325787] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.325788] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[ 0.325788] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.325789] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.325790] Spectre V2 : User space: Mitigation: STIBP always-on protection
[ 0.325790] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.338074] Freeing SMP alternatives memory: 36K
[ 0.448003] smpboot: CPU0: AMD Ryzen 9 5950X 16-Core Processor (family: 0x19, model: 0x21, stepping: 0x0)
[ 0.448078] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.448080] cblist_init_generic: Setting shift to 5 and lim to 1.
[ 0.448088] cblist_init_generic: Setting shift to 5 and lim to 1.
[ 0.448097] cblist_init_generic: Setting shift to 5 and lim to 1.
[ 0.448104] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[ 0.448107] ... version: 0
[ 0.448107] ... bit width: 48
[ 0.448107] ... generic registers: 6
[ 0.448108] ... value mask: 0000ffffffffffff
[ 0.448108] ... max period: 00007fffffffffff
[ 0.448109] ... fixed-purpose events: 0
[ 0.448109] ... event mask: 000000000000003f
[ 0.448146] rcu: Hierarchical SRCU implementation.
[ 0.448147] rcu: Max phase no-delay instances is 1000.
[ 0.448381] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.448506] smp: Bringing up secondary CPUs ...
[ 0.448554] x86: Booting SMP configuration:
[ 0.448554] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15 #16
[ 0.482738] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[ 0.483860] #17 #18 #19 #20 #21 #22 #23 #24 #25 #26 #27 #28 #29 #30 #31
[ 0.516003] smp: Brought up 1 node, 32 CPUs
[ 0.516003] smpboot: Max logical packages: 1
[ 0.516003] smpboot: Total of 32 processors activated (217701.86 BogoMIPS)
[ 0.517829] devtmpfs: initialized
[ 0.517829] x86/mm: Memory block size: 2048MB
[ 0.517829] ACPI: PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20dfff] (57344 bytes)
[ 0.517829] ACPI: PM: Registering ACPI NVS region [mem 0xdb508000-0xdcc06fff] (24113152 bytes)
[ 0.517829] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.517829] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[ 0.517829] pinctrl core: initialized pinctrl subsystem
[ 0.517829] PM: RTC time: 20:28:26, date: 2022-10-25
[ 0.517829] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.517985] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.518110] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.518235] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.518241] audit: initializing netlink subsys (disabled)
[ 0.518247] audit: type=2000 audit(1666729705.213:1): state=initialized audit_enabled=0 res=1
[ 0.518247] thermal_sys: Registered thermal governor 'fair_share'
[ 0.518247] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.518247] thermal_sys: Registered thermal governor 'step_wise'
[ 0.518247] thermal_sys: Registered thermal governor 'user_space'
[ 0.518247] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.518247] cpuidle: using governor ladder
[ 0.518247] cpuidle: using governor menu
[ 0.518247] Detected 1 PCC Subspaces
[ 0.518247] Registering PCC driver as Mailbox controller
[ 0.518247] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.518247] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.518247] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[ 0.518247] PCI: Using configuration type 1 for base access
[ 0.521290] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.523884] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.523884] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.523884] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.523884] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.523918] ACPI: Added _OSI(Module Device)
[ 0.523918] ACPI: Added _OSI(Processor Device)
[ 0.523919] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.523919] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.523920] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.523921] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.523922] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.531893] ACPI: 11 ACPI AML tables successfully acquired and loaded
[ 0.532955] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.534578] ACPI: Interpreter enabled
[ 0.534578] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.534578] ACPI: Using IOAPIC for interrupt routing
[ 0.534659] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.534660] PCI: Using E820 reservations for host bridge windows
[ 0.534913] ACPI: Enabled 2 GPEs in block 00 to 1F
[ 0.542965] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.542969] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.543025] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug PME LTR DPC]
[ 0.543123] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug AER PCIeCapability]
[ 0.543130] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-7f] only partially covers this bridge
[ 0.543372] PCI host bridge to bus 0000:00
[ 0.543373] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.543375] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.543375] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.543376] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.543377] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
[ 0.543377] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfcffffff window]
[ 0.543378] pci_bus 0000:00: root bus resource [mem 0x1020000000-0x7fffffffff window]
[ 0.543379] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.543388] pci 0000:00:00.0: [1022:1480] type 00 class 0x060000
[ 0.543446] pci 0000:00:00.2: [1022:1481] type 00 class 0x080600
[ 0.543503] pci 0000:00:01.0: [1022:1482] type 00 class 0x060000
[ 0.543537] pci 0000:00:01.1: [1022:1483] type 01 class 0x060400
[ 0.543594] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[ 0.543661] pci 0000:00:01.2: [1022:1483] type 01 class 0x060400
[ 0.543682] pci 0000:00:01.2: enabling Extended Tags
[ 0.543718] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[ 0.543795] pci 0000:00:02.0: [1022:1482] type 00 class 0x060000
[ 0.543831] pci 0000:00:03.0: [1022:1482] type 00 class 0x060000
[ 0.543866] pci 0000:00:03.1: [1022:1483] type 01 class 0x060400
[ 0.543921] pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
[ 0.543988] pci 0000:00:04.0: [1022:1482] type 00 class 0x060000
[ 0.544024] pci 0000:00:05.0: [1022:1482] type 00 class 0x060000
[ 0.544061] pci 0000:00:07.0: [1022:1482] type 00 class 0x060000
[ 0.544093] pci 0000:00:07.1: [1022:1484] type 01 class 0x060400
[ 0.544110] pci 0000:00:07.1: enabling Extended Tags
[ 0.544136] pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
[ 0.544188] pci 0000:00:08.0: [1022:1482] type 00 class 0x060000
[ 0.544221] pci 0000:00:08.1: [1022:1484] type 01 class 0x060400
[ 0.544240] pci 0000:00:08.1: enabling Extended Tags
[ 0.544270] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.544342] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 0.544421] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 0.544508] pci 0000:00:18.0: [1022:1440] type 00 class 0x060000
[ 0.544526] pci 0000:00:18.1: [1022:1441] type 00 class 0x060000
[ 0.544544] pci 0000:00:18.2: [1022:1442] type 00 class 0x060000
[ 0.544561] pci 0000:00:18.3: [1022:1443] type 00 class 0x060000
[ 0.544579] pci 0000:00:18.4: [1022:1444] type 00 class 0x060000
[ 0.544596] pci 0000:00:18.5: [1022:1445] type 00 class 0x060000
[ 0.544614] pci 0000:00:18.6: [1022:1446] type 00 class 0x060000
[ 0.544632] pci 0000:00:18.7: [1022:1447] type 00 class 0x060000
[ 0.544707] pci 0000:01:00.0: [1bb1:5018] type 00 class 0x010802
[ 0.544750] pci 0000:01:00.0: reg 0x10: [mem 0xfcf00000-0xfcf03fff 64bit]
[ 0.545269] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.545273] pci 0000:00:01.1: bridge window [mem 0xfcf00000-0xfcffffff]
[ 0.545312] pci 0000:20:00.0: [1022:57ad] type 01 class 0x060400
[ 0.545360] pci 0000:20:00.0: enabling Extended Tags
[ 0.545432] pci 0000:20:00.0: PME# supported from D0 D3hot D3cold
[ 0.545520] pci 0000:20:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 126.024 Gb/s with 16.0 GT/s PCIe x8 link)
[ 0.545574] pci 0000:00:01.2: PCI bridge to [bus 20-2c]
[ 0.545578] pci 0000:00:01.2: bridge window [mem 0xfc100000-0xfc7fffff]
[ 0.545580] pci 0000:00:01.2: bridge window [mem 0x7c10800000-0x7c10ffffff 64bit pref]
[ 0.545781] pci 0000:21:01.0: [1022:57a3] type 01 class 0x060400
[ 0.545844] pci 0000:21:01.0: enabling Extended Tags
[ 0.546064] pci 0000:21:01.0: PME# supported from D0 D3hot D3cold
[ 0.546471] pci 0000:21:02.0: [1022:57a3] type 01 class 0x060400
[ 0.546534] pci 0000:21:02.0: enabling Extended Tags
[ 0.546752] pci 0000:21:02.0: PME# supported from D0 D3hot D3cold
[ 0.547178] pci 0000:21:08.0: [1022:57a4] type 01 class 0x060400
[ 0.547241] pci 0000:21:08.0: enabling Extended Tags
[ 0.547386] pci 0000:21:08.0: PME# supported from D0 D3hot D3cold
[ 0.547555] pci 0000:21:09.0: [1022:57a4] type 01 class 0x060400
[ 0.547617] pci 0000:21:09.0: enabling Extended Tags
[ 0.547762] pci 0000:21:09.0: PME# supported from D0 D3hot D3cold
[ 0.547915] pci 0000:21:0a.0: [1022:57a4] type 01 class 0x060400
[ 0.547977] pci 0000:21:0a.0: enabling Extended Tags
[ 0.548122] pci 0000:21:0a.0: PME# supported from D0 D3hot D3cold
[ 0.548284] pci 0000:20:00.0: PCI bridge to [bus 21-2c]
[ 0.548292] pci 0000:20:00.0: bridge window [mem 0xfc100000-0xfc7fffff]
[ 0.548297] pci 0000:20:00.0: bridge window [mem 0x7c10800000-0x7c10ffffff 64bit pref]
[ 0.548402] pci 0000:23:00.0: [1bb1:5018] type 00 class 0x010802
[ 0.548459] pci 0000:23:00.0: reg 0x10: [mem 0xfc700000-0xfc703fff 64bit]
[ 0.548585] pci 0000:23:00.0: enabling Extended Tags
[ 0.549174] pci 0000:21:01.0: PCI bridge to [bus 23]
[ 0.549182] pci 0000:21:01.0: bridge window [mem 0xfc700000-0xfc7fffff]
[ 0.549577] pci 0000:24:00.0: [15b3:1003] type 00 class 0x020000
[ 0.549950] pci 0000:24:00.0: reg 0x10: [mem 0xfc400000-0xfc4fffff 64bit]
[ 0.550157] pci 0000:24:00.0: reg 0x18: [mem 0x7c10800000-0x7c10ffffff 64bit pref]
[ 0.550510] pci 0000:24:00.0: reg 0x30: [mem 0xfc300000-0xfc3fffff pref]
[ 0.553029] pci 0000:21:02.0: PCI bridge to [bus 24]
[ 0.553037] pci 0000:21:02.0: bridge window [mem 0xfc300000-0xfc4fffff]
[ 0.553042] pci 0000:21:02.0: bridge window [mem 0x7c10800000-0x7c10ffffff 64bit pref]
[ 0.553141] pci 0000:2a:00.0: [1022:1485] type 00 class 0x130000
[ 0.553201] pci 0000:2a:00.0: enabling Extended Tags
[ 0.553342] pci 0000:2a:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.553499] pci 0000:2a:00.1: [1022:149c] type 00 class 0x0c0330
[ 0.553905] pci 0000:2a:00.1: reg 0x10: [mem 0xfc200000-0xfc2fffff 64bit]
[ 0.554754] pci 0000:2a:00.1: enabling Extended Tags
[ 0.555280] pci 0000:2a:00.1: PME# supported from D0 D3hot D3cold
[ 0.555583] pci 0000:2a:00.3: [1022:149c] type 00 class 0x0c0330
[ 0.555606] pci 0000:2a:00.3: reg 0x10: [mem 0xfc100000-0xfc1fffff 64bit]
[ 0.555659] pci 0000:2a:00.3: enabling Extended Tags
[ 0.555722] pci 0000:2a:00.3: PME# supported from D0 D3hot D3cold
[ 0.555836] pci 0000:21:08.0: PCI bridge to [bus 2a]
[ 0.555844] pci 0000:21:08.0: bridge window [mem 0xfc100000-0xfc2fffff]
[ 0.555930] pci 0000:2b:00.0: [1022:7901] type 00 class 0x010601
[ 0.555992] pci 0000:2b:00.0: reg 0x24: [mem 0xfc600000-0xfc6007ff]
[ 0.556009] pci 0000:2b:00.0: enabling Extended Tags
[ 0.556094] pci 0000:2b:00.0: PME# supported from D3hot D3cold
[ 0.556165] pci 0000:2b:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.556205] pci 0000:21:09.0: PCI bridge to [bus 2b]
[ 0.556212] pci 0000:21:09.0: bridge window [mem 0xfc600000-0xfc6fffff]
[ 0.556298] pci 0000:2c:00.0: [1022:7901] type 00 class 0x010601
[ 0.556360] pci 0000:2c:00.0: reg 0x24: [mem 0xfc500000-0xfc5007ff]
[ 0.556377] pci 0000:2c:00.0: enabling Extended Tags
[ 0.556462] pci 0000:2c:00.0: PME# supported from D3hot D3cold
[ 0.556533] pci 0000:2c:00.0: 63.012 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x4 link at 0000:00:01.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.556572] pci 0000:21:0a.0: PCI bridge to [bus 2c]
[ 0.556579] pci 0000:21:0a.0: bridge window [mem 0xfc500000-0xfc5fffff]
[ 0.556650] pci 0000:2d:00.0: [1002:1478] type 01 class 0x060400
[ 0.556662] pci 0000:2d:00.0: reg 0x10: [mem 0xfcb00000-0xfcb03fff]
[ 0.556746] pci 0000:2d:00.0: PME# supported from D0 D3hot D3cold
[ 0.556843] pci 0000:00:03.1: PCI bridge to [bus 2d-2f]
[ 0.556846] pci 0000:00:03.1: bridge window [io 0xf000-0xffff]
[ 0.556847] pci 0000:00:03.1: bridge window [mem 0xfc800000-0xfcbfffff]
[ 0.556850] pci 0000:00:03.1: bridge window [mem 0x7800000000-0x7c0fffffff 64bit pref]
[ 0.556890] pci 0000:2e:00.0: [1002:1479] type 01 class 0x060400
[ 0.556983] pci 0000:2e:00.0: PME# supported from D0 D3hot D3cold
[ 0.557362] pci 0000:2d:00.0: PCI bridge to [bus 2e-2f]
[ 0.557367] pci 0000:2d:00.0: bridge window [io 0xf000-0xffff]
[ 0.557369] pci 0000:2d:00.0: bridge window [mem 0xfc800000-0xfcafffff]
[ 0.557373] pci 0000:2d:00.0: bridge window [mem 0x7800000000-0x7c0fffffff 64bit pref]
[ 0.557419] pci 0000:2f:00.0: [1002:73bf] type 00 class 0x030000
[ 0.557434] pci 0000:2f:00.0: reg 0x10: [mem 0x7800000000-0x7bffffffff 64bit pref]
[ 0.557443] pci 0000:2f:00.0: reg 0x18: [mem 0x7c00000000-0x7c0fffffff 64bit pref]
[ 0.557450] pci 0000:2f:00.0: reg 0x20: [io 0xf000-0xf0ff]
[ 0.557456] pci 0000:2f:00.0: reg 0x24: [mem 0xfc900000-0xfc9fffff]
[ 0.557462] pci 0000:2f:00.0: reg 0x30: [mem 0xfca00000-0xfca1ffff pref]
[ 0.557482] pci 0000:2f:00.0: BAR 0: assigned to efifb
[ 0.557536] pci 0000:2f:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.557637] pci 0000:2f:00.1: [1002:ab28] type 00 class 0x040300
[ 0.557647] pci 0000:2f:00.1: reg 0x10: [mem 0xfca24000-0xfca27fff]
[ 0.557719] pci 0000:2f:00.1: PME# supported from D1 D2 D3hot D3cold
[ 0.557783] pci 0000:2f:00.2: [1002:73a6] type 00 class 0x0c0330
[ 0.557798] pci 0000:2f:00.2: reg 0x10: [mem 0xfc800000-0xfc8fffff 64bit]
[ 0.557877] pci 0000:2f:00.2: PME# supported from D0 D3hot D3cold
[ 0.557932] pci 0000:2f:00.3: [1002:73a4] type 00 class 0x0c8000
[ 0.557946] pci 0000:2f:00.3: reg 0x10: [mem 0xfca20000-0xfca23fff 64bit]
[ 0.558013] pci 0000:2f:00.3: PME# supported from D0 D3hot
[ 0.558093] pci 0000:2e:00.0: PCI bridge to [bus 2f]
[ 0.558097] pci 0000:2e:00.0: bridge window [io 0xf000-0xffff]
[ 0.558099] pci 0000:2e:00.0: bridge window [mem 0xfc800000-0xfcafffff]
[ 0.558103] pci 0000:2e:00.0: bridge window [mem 0x7800000000-0x7c0fffffff 64bit pref]
[ 0.558136] pci 0000:30:00.0: [1022:148a] type 00 class 0x130000
[ 0.558156] pci 0000:30:00.0: enabling Extended Tags
[ 0.558229] pci 0000:00:07.1: PCI bridge to [bus 30]
[ 0.558263] pci 0000:31:00.0: [1022:1485] type 00 class 0x130000
[ 0.558286] pci 0000:31:00.0: enabling Extended Tags
[ 0.558359] pci 0000:31:00.1: [1022:1486] type 00 class 0x108000
[ 0.558370] pci 0000:31:00.1: reg 0x18: [mem 0xfcd00000-0xfcdfffff]
[ 0.558378] pci 0000:31:00.1: reg 0x24: [mem 0xfce00000-0xfce01fff]
[ 0.558383] pci 0000:31:00.1: enabling Extended Tags
[ 0.558448] pci 0000:31:00.3: [1022:149c] type 00 class 0x0c0330
[ 0.558457] pci 0000:31:00.3: reg 0x10: [mem 0xfcc00000-0xfccfffff 64bit]
[ 0.558477] pci 0000:31:00.3: enabling Extended Tags
[ 0.558507] pci 0000:31:00.3: PME# supported from D0 D3hot D3cold
[ 0.558564] pci 0000:00:08.1: PCI bridge to [bus 31]
[ 0.558567] pci 0000:00:08.1: bridge window [mem 0xfcc00000-0xfcefffff]
[ 0.558827] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.558862] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.558890] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.558925] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.558956] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.558982] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.559008] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.559034] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.559410] iommu: Default domain type: Translated
[ 0.559412] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.559494] SCSI subsystem initialized
[ 0.560520] libata version 3.00 loaded.
[ 0.560520] ACPI: bus type USB registered
[ 0.560523] usbcore: registered new interface driver usbfs
[ 0.560526] usbcore: registered new interface driver hub
[ 0.560530] usbcore: registered new device driver usb
[ 0.560538] pps_core: LinuxPPS API ver. 1 registered
[ 0.560539] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.560540] PTP clock support registered
[ 0.560544] EDAC MC: Ver: 3.0.0
[ 0.560692] Registered efivars operations
[ 0.560692] NetLabel: Initializing
[ 0.560692] NetLabel: domain hash size = 128
[ 0.560692] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.560692] NetLabel: unlabeled traffic allowed by default
[ 0.560692] mctp: management component transport protocol core
[ 0.560692] NET: Registered PF_MCTP protocol family
[ 0.560692] PCI: Using ACPI for IRQ routing
[ 0.562896] PCI: pci_cache_line_size set to 64 bytes
[ 0.563026] e820: reserve RAM buffer [mem 0x09d82000-0x0bffffff]
[ 0.563027] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[ 0.563027] e820: reserve RAM buffer [mem 0xcb453000-0xcbffffff]
[ 0.563028] e820: reserve RAM buffer [mem 0xcb4a2000-0xcbffffff]
[ 0.563028] e820: reserve RAM buffer [mem 0xd99ec000-0xdbffffff]
[ 0.563029] e820: reserve RAM buffer [mem 0xdb0a7000-0xdbffffff]
[ 0.563029] e820: reserve RAM buffer [mem 0xdf000000-0xdfffffff]
[ 0.563030] e820: reserve RAM buffer [mem 0x101f300000-0x101fffffff]
[ 0.563854] pci 0000:2f:00.0: vgaarb: setting as boot VGA device
[ 0.563854] pci 0000:2f:00.0: vgaarb: bridge control possible
[ 0.563854] pci 0000:2f:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.563854] vgaarb: loaded
[ 0.563873] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.563875] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.564889] clocksource: Switched to clocksource tsc-early
[ 0.564950] VFS: Disk quotas dquot_6.6.0
[ 0.564959] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.564995] pnp: PnP ACPI init
[ 0.565049] system 00:00: [mem 0xf0000000-0xf7ffffff] has been reserved
[ 0.565110] system 00:01: [mem 0xfd100000-0xfd1fffff] has been reserved
[ 0.565246] system 00:03: [io 0x0a00-0x0a0f] has been reserved
[ 0.565247] system 00:03: [io 0x0a10-0x0a1f] has been reserved
[ 0.565248] system 00:03: [io 0x0a20-0x0a2f] has been reserved
[ 0.565249] system 00:03: [io 0x0a30-0x0a3f] has been reserved
[ 0.565460] system 00:04: [io 0x04d0-0x04d1] has been reserved
[ 0.565461] system 00:04: [io 0x040b] has been reserved
[ 0.565461] system 00:04: [io 0x04d6] has been reserved
[ 0.565462] system 00:04: [io 0x0c00-0x0c01] has been reserved
[ 0.565463] system 00:04: [io 0x0c14] has been reserved
[ 0.565463] system 00:04: [io 0x0c50-0x0c51] has been reserved
[ 0.565464] system 00:04: [io 0x0c52] has been reserved
[ 0.565464] system 00:04: [io 0x0c6c] has been reserved
[ 0.565465] system 00:04: [io 0x0c6f] has been reserved
[ 0.565466] system 00:04: [io 0x0cd8-0x0cdf] has been reserved
[ 0.565466] system 00:04: [io 0x0800-0x089f] has been reserved
[ 0.565467] system 00:04: [io 0x0b00-0x0b0f] has been reserved
[ 0.565467] system 00:04: [io 0x0b20-0x0b3f] has been reserved
[ 0.565468] system 00:04: [io 0x0900-0x090f] has been reserved
[ 0.565468] system 00:04: [io 0x0910-0x091f] has been reserved
[ 0.565469] system 00:04: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.565470] system 00:04: [mem 0xfec01000-0xfec01fff] could not be reserved
[ 0.565471] system 00:04: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 0.565472] system 00:04: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.565473] system 00:04: [mem 0xfed80000-0xfed8ffff] could not be reserved
[ 0.565473] system 00:04: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.565474] system 00:04: [mem 0xff000000-0xffffffff] has been reserved
[ 0.565787] pnp: PnP ACPI: found 5 devices
[ 0.569774] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.569814] NET: Registered PF_INET protocol family
[ 0.569901] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.571592] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.571622] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.571749] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.572012] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.572054] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.572148] MPTCP token hash table entries: 65536 (order: 8, 1572864 bytes, linear)
[ 0.572219] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.572308] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.572388] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.572391] NET: Registered PF_XDP protocol family
[ 0.572397] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.572399] pci 0000:00:01.1: bridge window [mem 0xfcf00000-0xfcffffff]
[ 0.572403] pci 0000:21:01.0: PCI bridge to [bus 23]
[ 0.572407] pci 0000:21:01.0: bridge window [mem 0xfc700000-0xfc7fffff]
[ 0.572415] pci 0000:21:02.0: PCI bridge to [bus 24]
[ 0.572419] pci 0000:21:02.0: bridge window [mem 0xfc300000-0xfc4fffff]
[ 0.572422] pci 0000:21:02.0: bridge window [mem 0x7c10800000-0x7c10ffffff 64bit pref]
[ 0.572428] pci 0000:21:08.0: PCI bridge to [bus 2a]
[ 0.572432] pci 0000:21:08.0: bridge window [mem 0xfc100000-0xfc2fffff]
[ 0.572439] pci 0000:21:09.0: PCI bridge to [bus 2b]
[ 0.572443] pci 0000:21:09.0: bridge window [mem 0xfc600000-0xfc6fffff]
[ 0.572450] pci 0000:21:0a.0: PCI bridge to [bus 2c]
[ 0.572454] pci 0000:21:0a.0: bridge window [mem 0xfc500000-0xfc5fffff]
[ 0.572462] pci 0000:20:00.0: PCI bridge to [bus 21-2c]
[ 0.572466] pci 0000:20:00.0: bridge window [mem 0xfc100000-0xfc7fffff]
[ 0.572469] pci 0000:20:00.0: bridge window [mem 0x7c10800000-0x7c10ffffff 64bit pref]
[ 0.572474] pci 0000:00:01.2: PCI bridge to [bus 20-2c]
[ 0.572476] pci 0000:00:01.2: bridge window [mem 0xfc100000-0xfc7fffff]
[ 0.572477] pci 0000:00:01.2: bridge window [mem 0x7c10800000-0x7c10ffffff 64bit pref]
[ 0.572480] pci 0000:2e:00.0: PCI bridge to [bus 2f]
[ 0.572481] pci 0000:2e:00.0: bridge window [io 0xf000-0xffff]
[ 0.572484] pci 0000:2e:00.0: bridge window [mem 0xfc800000-0xfcafffff]
[ 0.572487] pci 0000:2e:00.0: bridge window [mem 0x7800000000-0x7c0fffffff 64bit pref]
[ 0.572490] pci 0000:2d:00.0: PCI bridge to [bus 2e-2f]
[ 0.572492] pci 0000:2d:00.0: bridge window [io 0xf000-0xffff]
[ 0.572494] pci 0000:2d:00.0: bridge window [mem 0xfc800000-0xfcafffff]
[ 0.572497] pci 0000:2d:00.0: bridge window [mem 0x7800000000-0x7c0fffffff 64bit pref]
[ 0.572500] pci 0000:00:03.1: PCI bridge to [bus 2d-2f]
[ 0.572501] pci 0000:00:03.1: bridge window [io 0xf000-0xffff]
[ 0.572503] pci 0000:00:03.1: bridge window [mem 0xfc800000-0xfcbfffff]
[ 0.572504] pci 0000:00:03.1: bridge window [mem 0x7800000000-0x7c0fffffff 64bit pref]
[ 0.572507] pci 0000:00:07.1: PCI bridge to [bus 30]
[ 0.572511] pci 0000:00:08.1: PCI bridge to [bus 31]
[ 0.572513] pci 0000:00:08.1: bridge window [mem 0xfcc00000-0xfcefffff]
[ 0.572516] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.572517] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.572518] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.572518] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.572519] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
[ 0.572519] pci_bus 0000:00: resource 9 [mem 0xe0000000-0xfcffffff window]
[ 0.572520] pci_bus 0000:00: resource 10 [mem 0x1020000000-0x7fffffffff window]
[ 0.572521] pci_bus 0000:01: resource 1 [mem 0xfcf00000-0xfcffffff]
[ 0.572521] pci_bus 0000:20: resource 1 [mem 0xfc100000-0xfc7fffff]
[ 0.572522] pci_bus 0000:20: resource 2 [mem 0x7c10800000-0x7c10ffffff 64bit pref]
[ 0.572523] pci_bus 0000:21: resource 1 [mem 0xfc100000-0xfc7fffff]
[ 0.572523] pci_bus 0000:21: resource 2 [mem 0x7c10800000-0x7c10ffffff 64bit pref]
[ 0.572524] pci_bus 0000:23: resource 1 [mem 0xfc700000-0xfc7fffff]
[ 0.572524] pci_bus 0000:24: resource 1 [mem 0xfc300000-0xfc4fffff]
[ 0.572525] pci_bus 0000:24: resource 2 [mem 0x7c10800000-0x7c10ffffff 64bit pref]
[ 0.572525] pci_bus 0000:2a: resource 1 [mem 0xfc100000-0xfc2fffff]
[ 0.572526] pci_bus 0000:2b: resource 1 [mem 0xfc600000-0xfc6fffff]
[ 0.572526] pci_bus 0000:2c: resource 1 [mem 0xfc500000-0xfc5fffff]
[ 0.572527] pci_bus 0000:2d: resource 0 [io 0xf000-0xffff]
[ 0.572528] pci_bus 0000:2d: resource 1 [mem 0xfc800000-0xfcbfffff]
[ 0.572528] pci_bus 0000:2d: resource 2 [mem 0x7800000000-0x7c0fffffff 64bit pref]
[ 0.572529] pci_bus 0000:2e: resource 0 [io 0xf000-0xffff]
[ 0.572529] pci_bus 0000:2e: resource 1 [mem 0xfc800000-0xfcafffff]
[ 0.572530] pci_bus 0000:2e: resource 2 [mem 0x7800000000-0x7c0fffffff 64bit pref]
[ 0.572530] pci_bus 0000:2f: resource 0 [io 0xf000-0xffff]
[ 0.572531] pci_bus 0000:2f: resource 1 [mem 0xfc800000-0xfcafffff]
[ 0.572531] pci_bus 0000:2f: resource 2 [mem 0x7800000000-0x7c0fffffff 64bit pref]
[ 0.572532] pci_bus 0000:31: resource 1 [mem 0xfcc00000-0xfcefffff]
[ 0.572884] pci 0000:2f:00.1: D0 power state depends on 0000:2f:00.0
[ 0.572930] pci 0000:2f:00.2: D0 power state depends on 0000:2f:00.0
[ 0.573051] pci 0000:2f:00.3: D0 power state depends on 0000:2f:00.0
[ 0.573151] PCI: CLS 64 bytes, default 64
[ 0.573156] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.573174] pci 0000:00:01.0: Adding to iommu group 0
[ 0.573179] pci 0000:00:01.1: Adding to iommu group 1
[ 0.573184] pci 0000:00:01.2: Adding to iommu group 2
[ 0.573184] Trying to unpack rootfs image as initramfs...
[ 0.573189] pci 0000:00:02.0: Adding to iommu group 3
[ 0.573195] pci 0000:00:03.0: Adding to iommu group 4
[ 0.573199] pci 0000:00:03.1: Adding to iommu group 5
[ 0.573204] pci 0000:00:04.0: Adding to iommu group 6
[ 0.573209] pci 0000:00:05.0: Adding to iommu group 7
[ 0.573216] pci 0000:00:07.0: Adding to iommu group 8
[ 0.573220] pci 0000:00:07.1: Adding to iommu group 9
[ 0.573225] pci 0000:00:08.0: Adding to iommu group 10
[ 0.573230] pci 0000:00:08.1: Adding to iommu group 11
[ 0.573237] pci 0000:00:14.0: Adding to iommu group 12
[ 0.573240] pci 0000:00:14.3: Adding to iommu group 12
[ 0.573255] pci 0000:00:18.0: Adding to iommu group 13
[ 0.573259] pci 0000:00:18.1: Adding to iommu group 13
[ 0.573262] pci 0000:00:18.2: Adding to iommu group 13
[ 0.573266] pci 0000:00:18.3: Adding to iommu group 13
[ 0.573270] pci 0000:00:18.4: Adding to iommu group 13
[ 0.573273] pci 0000:00:18.5: Adding to iommu group 13
[ 0.573277] pci 0000:00:18.6: Adding to iommu group 13
[ 0.573280] pci 0000:00:18.7: Adding to iommu group 13
[ 0.573285] pci 0000:01:00.0: Adding to iommu group 14
[ 0.573290] pci 0000:20:00.0: Adding to iommu group 15
[ 0.573317] pci 0000:21:01.0: Adding to iommu group 16
[ 0.573344] pci 0000:21:02.0: Adding to iommu group 17
[ 0.573350] pci 0000:21:08.0: Adding to iommu group 18
[ 0.573356] pci 0000:21:09.0: Adding to iommu group 19
[ 0.573362] pci 0000:21:0a.0: Adding to iommu group 20
[ 0.573389] pci 0000:23:00.0: Adding to iommu group 21
[ 0.573416] pci 0000:24:00.0: Adding to iommu group 22
[ 0.573418] pci 0000:2a:00.0: Adding to iommu group 18
[ 0.573419] pci 0000:2a:00.1: Adding to iommu group 18
[ 0.573421] pci 0000:2a:00.3: Adding to iommu group 18
[ 0.573423] pci 0000:2b:00.0: Adding to iommu group 19
[ 0.573424] pci 0000:2c:00.0: Adding to iommu group 20
[ 0.573429] pci 0000:2d:00.0: Adding to iommu group 23
[ 0.573434] pci 0000:2e:00.0: Adding to iommu group 24
[ 0.573441] pci 0000:2f:00.0: Adding to iommu group 25
[ 0.573449] pci 0000:2f:00.1: Adding to iommu group 26
[ 0.573456] pci 0000:2f:00.2: Adding to iommu group 27
[ 0.573463] pci 0000:2f:00.3: Adding to iommu group 28
[ 0.573468] pci 0000:30:00.0: Adding to iommu group 29
[ 0.573473] pci 0000:31:00.0: Adding to iommu group 30
[ 0.573478] pci 0000:31:00.1: Adding to iommu group 31
[ 0.573483] pci 0000:31:00.3: Adding to iommu group 32
[ 0.576091] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 0.576093] AMD-Vi: Extended features (0x58f77ef22294a5a, 0x0): PPR NX GT IA PC GA_vAPIC
[ 0.576096] AMD-Vi: Interrupt remapping enabled
[ 0.576145] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.576146] software IO TLB: mapped [mem 0x00000000d3706000-0x00000000d7706000] (64MB)
[ 0.576169] LVT offset 0 assigned for vector 0x400
[ 0.581356] perf: AMD IBS detected (0x000003ff)
[ 0.581360] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 0.583006] Initialise system trusted keyrings
[ 0.583013] Key type blacklist registered
[ 0.583030] workingset: timestamp_bits=41 max_order=24 bucket_order=0
[ 0.583504] zbud: loaded
[ 0.583592] integrity: Platform Keyring initialized
[ 0.583593] integrity: Machine keyring initialized
[ 0.585845] Key type asymmetric registered
[ 0.585846] Asymmetric key parser 'x509' registered
[ 0.625895] Freeing initrd memory: 8084K
[ 0.627161] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.627169] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.627194] io scheduler mq-deadline registered
[ 0.627194] io scheduler kyber registered
[ 0.627206] io scheduler bfq registered
[ 0.627487] amd_gpio AMDI0030:00: failed to get iomux index
[ 0.628195] pcieport 0000:00:01.1: AER: enabled with IRQ 28
[ 0.628311] pcieport 0000:00:01.2: AER: enabled with IRQ 29
[ 0.628413] pcieport 0000:00:03.1: AER: enabled with IRQ 30
[ 0.628570] pcieport 0000:00:07.1: AER: enabled with IRQ 32
[ 0.628656] pcieport 0000:00:08.1: AER: enabled with IRQ 33
[ 0.629939] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.630004] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.630013] ACPI: button: Power Button [PWRB]
[ 0.630026] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.630056] ACPI: button: Power Button [PWRF]
[ 0.631788] Estimated ratio of average max frequency by base frequency (times 1024): 1277
[ 0.631796] Monitor-Mwait will be used to enter C-1 state
[ 0.631799] ACPI: \_PR_.C000: Found 2 idle states
[ 0.631847] ACPI: \_PR_.C002: Found 2 idle states
[ 0.631907] ACPI: \_PR_.C004: Found 2 idle states
[ 0.631978] ACPI: \_PR_.C006: Found 2 idle states
[ 0.632044] ACPI: \_PR_.C008: Found 2 idle states
[ 0.632113] ACPI: \_PR_.C00A: Found 2 idle states
[ 0.632182] ACPI: \_PR_.C00C: Found 2 idle states
[ 0.632252] ACPI: \_PR_.C00E: Found 2 idle states
[ 0.632303] ACPI: \_PR_.C010: Found 2 idle states
[ 0.632358] ACPI: \_PR_.C012: Found 2 idle states
[ 0.632432] ACPI: \_PR_.C014: Found 2 idle states
[ 0.632506] ACPI: \_PR_.C016: Found 2 idle states
[ 0.632579] ACPI: \_PR_.C018: Found 2 idle states
[ 0.632651] ACPI: \_PR_.C01A: Found 2 idle states
[ 0.632725] ACPI: \_PR_.C01C: Found 2 idle states
[ 0.632797] ACPI: \_PR_.C01E: Found 2 idle states
[ 0.632852] ACPI: \_PR_.C001: Found 2 idle states
[ 0.632918] ACPI: \_PR_.C003: Found 2 idle states
[ 0.633001] ACPI: \_PR_.C005: Found 2 idle states
[ 0.633077] ACPI: \_PR_.C007: Found 2 idle states
[ 0.633139] ACPI: \_PR_.C009: Found 2 idle states
[ 0.633205] ACPI: \_PR_.C00B: Found 2 idle states
[ 0.633265] ACPI: \_PR_.C00D: Found 2 idle states
[ 0.633317] ACPI: \_PR_.C00F: Found 2 idle states
[ 0.633373] ACPI: \_PR_.C011: Found 2 idle states
[ 0.633430] ACPI: \_PR_.C013: Found 2 idle states
[ 0.633494] ACPI: \_PR_.C015: Found 2 idle states
[ 0.633554] ACPI: \_PR_.C017: Found 2 idle states
[ 0.633612] ACPI: \_PR_.C019: Found 2 idle states
[ 0.633675] ACPI: \_PR_.C01B: Found 2 idle states
[ 0.633733] ACPI: \_PR_.C01D: Found 2 idle states
[ 0.633793] ACPI: \_PR_.C01F: Found 2 idle states
[ 0.633927] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.634548] Non-volatile memory driver v1.3
[ 0.634548] Linux agpgart interface v0.103
[ 0.634566] AMD-Vi: AMD IOMMUv2 loaded and initialized
[ 0.634579] ACPI: bus type drm_connector registered
[ 0.635558] ahci 0000:2b:00.0: version 3.0
[ 0.635762] ahci 0000:2b:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x8 impl SATA mode
[ 0.635764] ahci 0000:2b:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.635898] scsi host0: ahci
[ 0.635957] scsi host1: ahci
[ 0.635998] scsi host2: ahci
[ 0.636053] scsi host3: ahci
[ 0.636069] ata1: DUMMY
[ 0.636069] ata2: DUMMY
[ 0.636070] ata3: DUMMY
[ 0.636071] ata4: SATA max UDMA/133 abar m2048@0xfc600000 port 0xfc600280 irq 46
[ 0.636186] ahci 0000:2c:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.636188] ahci 0000:2c:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.636272] scsi host4: ahci
[ 0.636289] ata5: SATA max UDMA/133 abar m2048@0xfc500000 port 0xfc500100 irq 59
[ 0.636308] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.636309] ehci-pci: EHCI PCI platform driver
[ 0.636313] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.636315] ohci-pci: OHCI PCI platform driver
[ 0.636318] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.636332] usbcore: registered new interface driver usbserial_generic
[ 0.636334] usbserial: USB Serial support registered for generic
[ 0.636368] rtc_cmos 00:02: RTC can wake from S4
[ 0.636508] rtc_cmos 00:02: registered as rtc0
[ 0.636529] rtc_cmos 00:02: setting system clock to 2022-10-25T20:28:26 UTC (1666729706)
[ 0.636536] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.636593] i2c-designware-pci 0000:2f:00.3: enabling device (0000 -> 0002)
[ 0.636818] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.636907] efifb: probing for efifb
[ 0.636916] efifb: No BGRT, not showing boot graphics
[ 0.636917] efifb: framebuffer at 0x7800000000, using 3072k, total 3072k
[ 0.636918] efifb: mode is 1024x768x32, linelength=4096, pages=1
[ 0.636919] efifb: scrolling: redraw
[ 0.636919] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.636939] fbcon: Deferring console take-over
[ 0.636939] fb0: EFI VGA frame buffer device
[ 0.636953] hid: raw HID events driver (C) Jiri Kosina
[ 0.636994] drop_monitor: Initializing network drop monitor service
[ 0.642797] Initializing XFRM netlink socket
[ 0.642839] NET: Registered PF_INET6 protocol family
[ 0.643906] Segment Routing with IPv6
[ 0.643907] RPL Segment Routing with IPv6
[ 0.643910] In-situ OAM (IOAM) with IPv6
[ 0.643920] NET: Registered PF_PACKET protocol family
[ 0.644804] microcode: CPU0: patch_level=0x0a201016
[ 0.644806] microcode: CPU1: patch_level=0x0a201016
[ 0.644808] microcode: CPU2: patch_level=0x0a201016
[ 0.644812] microcode: CPU3: patch_level=0x0a201016
[ 0.644816] microcode: CPU4: patch_level=0x0a201016
[ 0.644820] microcode: CPU5: patch_level=0x0a201016
[ 0.644823] microcode: CPU6: patch_level=0x0a201016
[ 0.644827] microcode: CPU7: patch_level=0x0a201016
[ 0.644832] microcode: CPU8: patch_level=0x0a201016
[ 0.644837] microcode: CPU9: patch_level=0x0a201016
[ 0.644841] microcode: CPU10: patch_level=0x0a201016
[ 0.644846] microcode: CPU11: patch_level=0x0a201016
[ 0.644851] microcode: CPU12: patch_level=0x0a201016
[ 0.644856] microcode: CPU13: patch_level=0x0a201016
[ 0.644861] microcode: CPU14: patch_level=0x0a201016
[ 0.644866] microcode: CPU15: patch_level=0x0a201016
[ 0.644870] microcode: CPU16: patch_level=0x0a201016
[ 0.644873] microcode: CPU17: patch_level=0x0a201016
[ 0.644876] microcode: CPU18: patch_level=0x0a201016
[ 0.644879] microcode: CPU19: patch_level=0x0a201016
[ 0.644882] microcode: CPU20: patch_level=0x0a201016
[ 0.644885] microcode: CPU21: patch_level=0x0a201016
[ 0.644888] microcode: CPU22: patch_level=0x0a201016
[ 0.644890] microcode: CPU23: patch_level=0x0a201016
[ 0.644894] microcode: CPU24: patch_level=0x0a201016
[ 0.644898] microcode: CPU25: patch_level=0x0a201016
[ 0.644902] microcode: CPU26: patch_level=0x0a201016
[ 0.644906] microcode: CPU27: patch_level=0x0a201016
[ 0.644910] microcode: CPU28: patch_level=0x0a201016
[ 0.644914] microcode: CPU29: patch_level=0x0a201016
[ 0.644917] microcode: CPU30: patch_level=0x0a201016
[ 0.644921] microcode: CPU31: patch_level=0x0a201016
[ 0.644923] microcode: Microcode Update Driver: v2.2.
[ 0.645079] resctrl: L3 allocation detected
[ 0.645080] resctrl: MB allocation detected
[ 0.645080] resctrl: L3 monitoring detected
[ 0.645082] IPI shorthand broadcast: enabled
[ 0.645092] sched_clock: Marking stable (481527894, 163547242)->(654998947, -9923811)
[ 0.645525] registered taskstats version 1
[ 0.645792] Loading compiled-in X.509 certificates
[ 0.647558] Loaded X.509 cert 'Build time autogenerated kernel key: 421032e57915b1e8efbd619e90c6ce7afb11b4c4'
[ 0.650609] zswap: loaded using pool zstd/z3fold
[ 0.650698] Key type ._fscrypt registered
[ 0.650699] Key type .fscrypt registered
[ 0.650700] Key type fscrypt-provisioning registered
[ 0.651546] PM: Magic number: 10:951:498
[ 0.651670] RAS: Correctable Errors collector initialized.
[ 1.114524] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.116141] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.116430] ata4.00: supports DRM functions and may not be fully accessible
[ 1.116431] ata4.00: ATA-11: Samsung SSD 860 PRO 512GB, RVM01B6Q, max UDMA/133
[ 1.116774] ata5.00: ATA-11: ST16000NM001G-2KK103, SN03, max UDMA/133
[ 1.117248] ata4.00: 1000215216 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 1.120690] ata4.00: Features: Trust Dev-Sleep NCQ-sndrcv
[ 1.121109] ata4.00: supports DRM functions and may not be fully accessible
[ 1.125490] ata4.00: configured for UDMA/133
[ 1.137946] scsi 3:0:0:0: Direct-Access ATA Samsung SSD 860 1B6Q PQ: 0 ANSI: 5
[ 1.138124] ata4.00: Enabling discard_zeroes_data
[ 1.138136] sd 3:0:0:0: [sda] 1000215216 512-byte logical blocks: (512 GB/477 GiB)
[ 1.138146] sd 3:0:0:0: [sda] Write Protect is off
[ 1.138147] sd 3:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.138159] sd 3:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.138182] sd 3:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[ 1.138359] ata4.00: Enabling discard_zeroes_data
[ 1.155476] ata5.00: 31251759104 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.156019] ata5.00: Features: NCQ-sndrcv
[ 1.160095] sda: sda1
[ 1.161111] sd 3:0:0:0: [sda] supports TCG Opal
[ 1.161112] sd 3:0:0:0: [sda] Attached SCSI disk
[ 1.180939] ata5.00: configured for UDMA/133
[ 1.217693] scsi 4:0:0:0: Direct-Access ATA ST16000NM001G-2K SN03 PQ: 0 ANSI: 5
[ 1.217800] sd 4:0:0:0: [sdb] 31251759104 512-byte logical blocks: (16.0 TB/14.6 TiB)
[ 1.217801] sd 4:0:0:0: [sdb] 4096-byte physical blocks
[ 1.217808] sd 4:0:0:0: [sdb] Write Protect is off
[ 1.217809] sd 4:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.217820] sd 4:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.217833] sd 4:0:0:0: [sdb] Preferred minimum I/O size 4096 bytes
[ 1.281506] sdb: sdb1 sdb2 sdb3
[ 1.281573] sd 4:0:0:0: [sdb] Attached SCSI disk
[ 1.282178] Freeing unused decrypted memory: 2036K
[ 1.282372] Freeing unused kernel image (initmem) memory: 2128K
[ 1.302544] Write protecting the kernel read-only data: 30720k
[ 1.302804] Freeing unused kernel image (text/rodata gap) memory: 2040K
[ 1.302889] Freeing unused kernel image (rodata/data gap) memory: 928K
[ 1.321798] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.321801] rodata_test: all tests were successful
[ 1.321804] Run /init as init process
[ 1.321804] with arguments:
[ 1.321805] /init
[ 1.321806] with environment:
[ 1.321806] HOME=/
[ 1.321806] TERM=linux
[ 1.321807] BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
[ 1.372647] xhci_hcd 0000:2a:00.1: xHCI Host Controller
[ 1.372654] xhci_hcd 0000:2a:00.1: new USB bus registered, assigned bus number 1
[ 1.372817] xhci_hcd 0000:2a:00.1: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ 1.373325] xhci_hcd 0000:2a:00.1: xHCI Host Controller
[ 1.373327] xhci_hcd 0000:2a:00.1: new USB bus registered, assigned bus number 2
[ 1.373329] xhci_hcd 0000:2a:00.1: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.373361] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.00
[ 1.373363] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.373364] usb usb1: Product: xHCI Host Controller
[ 1.373365] usb usb1: Manufacturer: Linux 6.0.2-2-MANJARO xhci-hcd
[ 1.373366] usb usb1: SerialNumber: 0000:2a:00.1
[ 1.373451] hub 1-0:1.0: USB hub found
[ 1.373462] hub 1-0:1.0: 6 ports detected
[ 1.373670] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.373685] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.00
[ 1.373686] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.373687] usb usb2: Product: xHCI Host Controller
[ 1.373688] usb usb2: Manufacturer: Linux 6.0.2-2-MANJARO xhci-hcd
[ 1.373689] usb usb2: SerialNumber: 0000:2a:00.1
[ 1.373758] hub 2-0:1.0: USB hub found
[ 1.373766] hub 2-0:1.0: 4 ports detected
[ 1.373869] usb: port power management may be unreliable
[ 1.373978] xhci_hcd 0000:2a:00.3: xHCI Host Controller
[ 1.373983] xhci_hcd 0000:2a:00.3: new USB bus registered, assigned bus number 3
[ 1.374147] xhci_hcd 0000:2a:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ 1.374511] xhci_hcd 0000:2a:00.3: xHCI Host Controller
[ 1.374513] xhci_hcd 0000:2a:00.3: new USB bus registered, assigned bus number 4
[ 1.374515] xhci_hcd 0000:2a:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.374543] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.00
[ 1.374545] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.374546] usb usb3: Product: xHCI Host Controller
[ 1.374547] usb usb3: Manufacturer: Linux 6.0.2-2-MANJARO xhci-hcd
[ 1.374548] usb usb3: SerialNumber: 0000:2a:00.3
[ 1.374619] hub 3-0:1.0: USB hub found
[ 1.374631] hub 3-0:1.0: 6 ports detected
[ 1.374829] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.374844] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.00
[ 1.374845] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.374847] usb usb4: Product: xHCI Host Controller
[ 1.374848] usb usb4: Manufacturer: Linux 6.0.2-2-MANJARO xhci-hcd
[ 1.374849] usb usb4: SerialNumber: 0000:2a:00.3
[ 1.374903] hub 4-0:1.0: USB hub found
[ 1.374912] hub 4-0:1.0: 4 ports detected
[ 1.375189] xhci_hcd 0000:2f:00.2: xHCI Host Controller
[ 1.375193] xhci_hcd 0000:2f:00.2: new USB bus registered, assigned bus number 5
[ 1.375293] xhci_hcd 0000:2f:00.2: hcc params 0x0260ffe5 hci version 0x110 quirks 0x0000000000000010
[ 1.375598] xhci_hcd 0000:2f:00.2: xHCI Host Controller
[ 1.375601] xhci_hcd 0000:2f:00.2: new USB bus registered, assigned bus number 6
[ 1.375603] xhci_hcd 0000:2f:00.2: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.375624] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.00
[ 1.375626] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.375626] usb usb5: Product: xHCI Host Controller
[ 1.375627] usb usb5: Manufacturer: Linux 6.0.2-2-MANJARO xhci-hcd
[ 1.375628] usb usb5: SerialNumber: 0000:2f:00.2
[ 1.375683] nvme nvme0: pci function 0000:01:00.0
[ 1.375745] nvme nvme1: pci function 0000:23:00.0
[ 1.375760] hub 5-0:1.0: USB hub found
[ 1.375769] hub 5-0:1.0: 2 ports detected
[ 1.375900] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.375916] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.00
[ 1.375918] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.375920] usb usb6: Product: xHCI Host Controller
[ 1.375921] usb usb6: Manufacturer: Linux 6.0.2-2-MANJARO xhci-hcd
[ 1.375922] usb usb6: SerialNumber: 0000:2f:00.2
[ 1.375982] hub 6-0:1.0: USB hub found
[ 1.375997] hub 6-0:1.0: 1 port detected
[ 1.376163] xhci_hcd 0000:31:00.3: xHCI Host Controller
[ 1.376166] xhci_hcd 0000:31:00.3: new USB bus registered, assigned bus number 7
[ 1.376355] xhci_hcd 0000:31:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ 1.376603] xhci_hcd 0000:31:00.3: xHCI Host Controller
[ 1.376605] xhci_hcd 0000:31:00.3: new USB bus registered, assigned bus number 8
[ 1.376608] xhci_hcd 0000:31:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.376631] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.00
[ 1.376633] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.376635] usb usb7: Product: xHCI Host Controller
[ 1.376636] usb usb7: Manufacturer: Linux 6.0.2-2-MANJARO xhci-hcd
[ 1.376637] usb usb7: SerialNumber: 0000:31:00.3
[ 1.376709] hub 7-0:1.0: USB hub found
[ 1.376716] hub 7-0:1.0: 4 ports detected
[ 1.376884] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.376901] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.00
[ 1.376902] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.376904] usb usb8: Product: xHCI Host Controller
[ 1.376905] usb usb8: Manufacturer: Linux 6.0.2-2-MANJARO xhci-hcd
[ 1.376906] usb usb8: SerialNumber: 0000:31:00.3
[ 1.376973] hub 8-0:1.0: USB hub found
[ 1.376977] hub 8-0:1.0: 4 ports detected
[ 1.380361] nvme nvme0: missing or invalid SUBNQN field.
[ 1.380376] nvme nvme0: Shutdown timeout set to 10 seconds
[ 1.380494] nvme nvme1: missing or invalid SUBNQN field.
[ 1.380515] nvme nvme1: Shutdown timeout set to 10 seconds
[ 1.384147] nvme nvme0: 32/0/0 default/read/poll queues
[ 1.384346] nvme nvme1: 32/0/0 default/read/poll queues
[ 1.387088] nvme1n1: p1
[ 1.387268] nvme0n1: p1 p2 p3
[ 1.580527] tsc: Refined TSC clocksource calibration: 3399.998 MHz
[ 1.580534] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x31024cfe468, max_idle_ns: 440795307017 ns
[ 1.580769] clocksource: Switched to clocksource tsc
[ 1.623861] usb 5-2: new full-speed USB device number 2 using xhci_hcd
[ 1.624387] usb 3-5: new full-speed USB device number 2 using xhci_hcd
[ 1.624394] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.770977] usb 1-1: New USB device found, idVendor=2109, idProduct=2813, bcdDevice=90.11
[ 1.770979] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.770981] usb 1-1: Product: USB2.0 Hub
[ 1.770982] usb 1-1: Manufacturer: VIA Labs, Inc.
[ 1.783551] usb 3-5: New USB device found, idVendor=1462, idProduct=7c84, bcdDevice= 0.01
[ 1.783554] usb 3-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.783555] usb 3-5: Product: MYSTIC LIGHT
[ 1.783556] usb 3-5: Manufacturer: MSI
[ 1.783556] usb 3-5: SerialNumber: A02019122002
[ 1.789538] usb 5-2: New USB device found, idVendor=2516, idProduct=014d, bcdDevice= 1.04
[ 1.789540] usb 5-2: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[ 1.789541] usb 5-2: Product: ARES
[ 1.789542] usb 5-2: Manufacturer: Cooler Master Technology Inc.
[ 1.804653] input: MSI MYSTIC LIGHT as /devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:08.0/0000:2a:00.3/usb3/3-5/3-5:1.0/0003:1462:7C84.0001/input/input2
[ 1.804720] hid-generic 0003:1462:7C84.0001: input,hiddev96,hidraw0: USB HID v1.10 Device [MSI MYSTIC LIGHT ] on usb-0000:2a:00.3-5/input0
[ 1.805611] input: Cooler Master Technology Inc. ARES as /devices/pci0000:00/0000:00:03.1/0000:2d:00.0/0000:2e:00.0/0000:2f:00.2/usb5/5-2/5-2:1.0/0003:2516:014D.0002/input/input3
[ 1.821617] hub 1-1:1.0: USB hub found
[ 1.822589] hub 1-1:1.0: 4 ports detected
[ 1.860804] hid-generic 0003:2516:014D.0002: input,hidraw1: USB HID v1.11 Keyboard [Cooler Master Technology Inc. ARES] on usb-0000:2f:00.2-2/input0
[ 1.864924] hid-generic 0003:2516:014D.0003: hiddev97,hidraw2: USB HID v1.11 Device [Cooler Master Technology Inc. ARES] on usb-0000:2f:00.2-2/input1
[ 1.868602] input: Cooler Master Technology Inc. ARES System Control as /devices/pci0000:00/0000:00:03.1/0000:2d:00.0/0000:2e:00.0/0000:2f:00.2/usb5/5-2/5-2:1.2/0003:2516:014D.0004/input/input4
[ 1.917195] usb 3-6: new high-speed USB device number 3 using xhci_hcd
[ 1.923912] input: Cooler Master Technology Inc. ARES Consumer Control as /devices/pci0000:00/0000:00:03.1/0000:2d:00.0/0000:2e:00.0/0000:2f:00.2/usb5/5-2/5-2:1.2/0003:2516:014D.0004/input/input5
[ 1.923941] hid-generic 0003:2516:014D.0004: input,hidraw3: USB HID v1.11 Device [Cooler Master Technology Inc. ARES] on usb-0000:2f:00.2-2/input2
[ 1.924165] usbcore: registered new interface driver usbhid
[ 1.924167] usbhid: USB HID core driver
[ 1.928546] usb 2-1: new SuperSpeed USB device number 2 using xhci_hcd
[ 1.976777] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.028668] usb 2-1: New USB device found, idVendor=2109, idProduct=0813, bcdDevice=90.11
[ 2.028671] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.028672] usb 2-1: Product: USB3.0 Hub
[ 2.028673] usb 2-1: Manufacturer: VIA Labs, Inc.
[ 2.044816] systemd[1]: systemd 251.5-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 2.044820] systemd[1]: Detected architecture x86-64.
[ 2.045164] systemd[1]: Hostname set to <Neuromancer>.
[ 2.045474] hub 2-1:1.0: USB hub found
[ 2.045712] hub 2-1:1.0: 4 ports detected
[ 2.063638] usb 3-6: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.70
[ 2.063641] usb 3-6: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.063642] usb 3-6: Product: USB2.0 Hub
[ 2.110929] hub 3-6:1.0: USB hub found
[ 2.111535] hub 3-6:1.0: 4 ports detected
[ 2.150517] usb 1-2: new high-speed USB device number 3 using xhci_hcd
[ 2.212625] systemd[1]: Queued start job for default target Graphical Interface.
[ 2.244016] systemd[1]: Created slice Virtual Machine and Container Slice.
[ 2.244285] systemd[1]: Created slice Slice /system/getty.
[ 2.244476] systemd[1]: Created slice Slice /system/modprobe.
[ 2.244635] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 2.244746] systemd[1]: Created slice User and Session Slice.
[ 2.244783] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.244806] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.244883] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.244920] systemd[1]: Reached target Local Encrypted Volumes.
[ 2.244928] systemd[1]: Reached target Login Prompts.
[ 2.244934] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 2.244948] systemd[1]: Reached target Remote File Systems.
[ 2.244953] systemd[1]: Reached target Slice Units.
[ 2.244962] systemd[1]: Reached target Swaps.
[ 2.244972] systemd[1]: Reached target Local Verity Protected Volumes.
[ 2.245008] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 2.245141] systemd[1]: Listening on LVM2 poll daemon socket.
[ 2.245578] systemd[1]: Listening on Process Core Dump Socket.
[ 2.245631] systemd[1]: Listening on Journal Audit Socket.
[ 2.245670] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.245710] systemd[1]: Listening on Journal Socket.
[ 2.245756] systemd[1]: Listening on udev Control Socket.
[ 2.245785] systemd[1]: Listening on udev Kernel Socket.
[ 2.246158] systemd[1]: Mounting Huge Pages File System...
[ 2.246483] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.247308] systemd[1]: Mounting Kernel Debug File System...
[ 2.247632] systemd[1]: Mounting Kernel Trace File System...
[ 2.248462] systemd[1]: Mounting Temporary Directory /tmp...
[ 2.248854] systemd[1]: Starting Create List of Static Device Nodes...
[ 2.249388] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 2.249803] systemd[1]: Starting Load Kernel Module configfs...
[ 2.250179] systemd[1]: Starting Load Kernel Module drm...
[ 2.250561] systemd[1]: Starting Load Kernel Module fuse...
[ 2.250897] systemd[1]: Starting File System Check on Root Device...
[ 2.251592] systemd[1]: Starting Journal Service...
[ 2.252163] systemd[1]: Starting Load Kernel Modules...
[ 2.252269] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[ 2.252627] systemd[1]: Starting Coldplug All udev Devices...
[ 2.253177] systemd[1]: Mounted Huge Pages File System.
[ 2.253218] systemd[1]: Mounted POSIX Message Queue File System.
[ 2.253253] systemd[1]: Mounted Kernel Debug File System.
[ 2.253282] systemd[1]: Mounted Kernel Trace File System.
[ 2.253312] systemd[1]: Mounted Temporary Directory /tmp.
[ 2.253389] systemd[1]: Finished Create List of Static Device Nodes.
[ 2.253501] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 2.253548] systemd[1]: Finished Load Kernel Module configfs.
[ 2.253640] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 2.253682] systemd[1]: Finished Load Kernel Module drm.
[ 2.254119] systemd[1]: Mounting Kernel Configuration File System...
[ 2.254810] systemd[1]: Mounted Kernel Configuration File System.
[ 2.256372] fuse: init (API version 7.36)
[ 2.256654] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 2.256708] systemd[1]: Finished Load Kernel Module fuse.
[ 2.257082] systemd[1]: Mounting FUSE Control File System...
[ 2.257801] systemd[1]: Mounted FUSE Control File System.
[ 2.261381] vboxdrv: loading out-of-tree module taints kernel.
[ 2.261472] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[ 2.265390] vboxdrv: Found 32 processor cores
[ 2.270629] systemd[1]: Finished File System Check on Root Device.
[ 2.270655] audit: type=1130 audit(1666729708.130:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck-root comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.271107] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 2.274278] EXT4-fs (nvme0n1p1): re-mounted. Quota mode: none.
[ 2.274683] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 2.274703] audit: type=1130 audit(1666729708.134:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.274743] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 2.275053] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 2.275387] systemd[1]: Starting Load/Save Random Seed...
[ 2.275415] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 2.275763] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 2.281377] systemd[1]: Finished Load/Save Random Seed.
[ 2.281395] audit: type=1130 audit(1666729708.140:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.281433] systemd[1]: First Boot Complete was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 2.283066] systemd[1]: Started Journal Service.
[ 2.283092] audit: type=1130 audit(1666729708.140:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.285106] systemd-journald[488]: Received client request to flush runtime journal.
[ 2.290622] vboxdrv: TSC mode is Invariant, tentative frequency 3399997789 Hz
[ 2.290624] vboxdrv: Successfully loaded version 6.1.38 r153438 (interface 0x00320000)
[ 2.291340] VBoxNetAdp: Successfully started.
[ 2.292257] VBoxNetFlt: Successfully started.
[ 2.293353] audit: type=1130 audit(1666729708.150:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.293561] audit: type=1334 audit(1666729708.150:7): prog-id=9 op=LOAD
[ 2.293578] audit: type=1334 audit(1666729708.150:8): prog-id=10 op=LOAD
[ 2.298667] device-mapper: uevent: version 1.0.3
[ 2.298698] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[ 2.299448] usb 1-2: New USB device found, idVendor=152a, idProduct=8750, bcdDevice= 1.23
[ 2.299450] usb 1-2: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ 2.299451] usb 1-2: Product: DX3 Pro+
[ 2.299452] usb 1-2: Manufacturer: Topping
[ 2.301360] audit: type=1130 audit(1666729708.160:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.301645] audit: type=1130 audit(1666729708.160:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.377743] zenpower 0000:00:18.3: using ZEN2 calculation formula.
[ 2.381784] input: PC Speaker as /devices/platform/pcspkr/input/input6
[ 2.381962] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 2.381964] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 2.383057] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 2.383060] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 2.383115] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 2.383478] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 2.383855] usb 1-1.1: new full-speed USB device number 4 using xhci_hcd
[ 2.385556] cryptd: max_cpu_qlen set to 1000
[ 2.387380] ccp 0000:31:00.1: enabling device (0000 -> 0002)
[ 2.387436] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 2.387496] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 2.387518] ccp 0000:31:00.1: ccp: unable to access the device: you might be running a broken BIOS.
[ 2.387535] ccp 0000:31:00.1: psp enabled
[ 2.387943] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 2.400735] mlx4_core: Mellanox ConnectX core driver v4.0-0
[ 2.400743] mlx4_core: Initializing 0000:24:00.0
[ 2.400785] mlx4_core 0000:24:00.0: enabling device (0000 -> 0002)
[ 2.402402] AVX2 version of gcm_enc/dec engaged.
[ 2.402495] AES CTR mode by8 optimization enabled
[ 2.513330] usb 1-1.1: New USB device found, idVendor=046d, idProduct=c083, bcdDevice= 8.01
[ 2.513334] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.513335] usb 1-1.1: Product: G403 Prodigy Gaming Mouse
[ 2.513336] usb 1-1.1: Manufacturer: Logitech
[ 2.513337] usb 1-1.1: SerialNumber: 197538613538
[ 2.560617] ucsi_ccg 0-0008: failed to get FW build information
[ 2.576878] SVM: TSC scaling supported
[ 2.576880] kvm: Nested Virtualization enabled
[ 2.576880] SVM: kvm: Nested Paging enabled
[ 2.576887] SVM: Virtual VMLOAD VMSAVE supported
[ 2.576887] SVM: Virtual GIF supported
[ 2.576887] SVM: LBR virtualization supported
[ 2.584750] MCE: In-kernel MCE decoding enabled.
[ 2.591144] EXT4-fs (nvme1n1p1): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.600424] input: Logitech G403 Prodigy Gaming Mouse as /devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:08.0/0000:2a:00.1/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C083.0005/input/input7
[ 2.600465] hid-generic 0003:046D:C083.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech G403 Prodigy Gaming Mouse] on usb-0000:2a:00.1-1.1/input0
[ 2.607486] input: Logitech G403 Prodigy Gaming Mouse Keyboard as /devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:08.0/0000:2a:00.1/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C083.0006/input/input8
[ 2.609577] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.613856] usb 1-4: new full-speed USB device number 5 using xhci_hcd
[ 2.624899] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.663993] hid-generic 0003:046D:C083.0006: input,hiddev98,hidraw5: USB HID v1.11 Keyboard [Logitech G403 Prodigy Gaming Mouse] on usb-0000:2a:00.1-1.1/input1
[ 2.665694] snd_hda_intel 0000:2f:00.1: enabling device (0000 -> 0002)
[ 2.665848] snd_hda_intel 0000:2f:00.1: Handle vga_switcheroo audio client
[ 2.665850] snd_hda_intel 0000:2f:00.1: Force to non-snoop mode
[ 2.673589] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:2d:00.0/0000:2e:00.0/0000:2f:00.1/sound/card0/input11
[ 2.673614] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:2d:00.0/0000:2e:00.0/0000:2f:00.1/sound/card0/input12
[ 2.673635] input: HDA ATI HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:2d:00.0/0000:2e:00.0/0000:2f:00.1/sound/card0/input13
[ 2.673655] input: HDA ATI HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:2d:00.0/0000:2e:00.0/0000:2f:00.1/sound/card0/input14
[ 2.673674] input: HDA ATI HDMI HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.1/0000:2d:00.0/0000:2e:00.0/0000:2f:00.1/sound/card0/input15
[ 2.673694] input: HDA ATI HDMI HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:03.1/0000:2d:00.0/0000:2e:00.0/0000:2f:00.1/sound/card0/input16
[ 2.743656] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.773251] EXT4-fs (sdb3): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.783307] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.788328] usb 1-4: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[ 2.788331] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.867184] usb 1-1.2: new full-speed USB device number 6 using xhci_hcd
[ 3.003322] usb 1-1.2: New USB device found, idVendor=320f, idProduct=5044, bcdDevice= 0.01
[ 3.003326] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.003328] usb 1-1.2: Product: GMMK Pro
[ 3.003329] usb 1-1.2: Manufacturer: Glorious
[ 3.075444] input: Glorious GMMK Pro as /devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:08.0/0000:2a:00.1/usb1/1-1/1-1.2/1-1.2:1.0/0003:320F:5044.0007/input/input17
[ 3.133943] hid-generic 0003:320F:5044.0007: input,hidraw6: USB HID v1.11 Keyboard [Glorious GMMK Pro] on usb-0000:2a:00.1-1.2/input0
[ 3.137489] input: Glorious GMMK Pro Mouse as /devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:08.0/0000:2a:00.1/usb1/1-1/1-1.2/1-1.2:1.1/0003:320F:5044.0008/input/input18
[ 3.137522] input: Glorious GMMK Pro System Control as /devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:08.0/0000:2a:00.1/usb1/1-1/1-1.2/1-1.2:1.1/0003:320F:5044.0008/input/input19
[ 3.197229] input: Glorious GMMK Pro Consumer Control as /devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:08.0/0000:2a:00.1/usb1/1-1/1-1.2/1-1.2:1.1/0003:320F:5044.0008/input/input20
[ 3.197261] input: Glorious GMMK Pro Keyboard as /devices/pci0000:00/0000:00:01.2/0000:20:00.0/0000:21:08.0/0000:2a:00.1/usb1/1-1/1-1.2/1-1.2:1.1/0003:320F:5044.0008/input/input21
[ 3.197376] hid-generic 0003:320F:5044.0008: input,hidraw7: USB HID v1.11 Mouse [Glorious GMMK Pro] on usb-0000:2a:00.1-1.2/input1
[ 3.430671] NET: Registered PF_QIPCRTR protocol family
[ 3.434037] [drm] amdgpu kernel modesetting enabled.
[ 3.437542] nct6775: Found NCT6797D or compatible chip at 0x4e:0xa20
[ 3.438610] amdgpu: Ignoring ACPI CRAT on non-APU system
[ 3.438612] amdgpu: Virtual CRAT table created for CPU
[ 3.438618] amdgpu: Topology: Add CPU node
[ 3.438728] amdgpu 0000:2f:00.0: vgaarb: deactivate vga console
[ 3.438763] amdgpu 0000:2f:00.0: enabling device (0006 -> 0007)
[ 3.438812] [drm] initializing kernel modesetting (SIENNA_CICHLID 0x1002:0x73BF 0x1002:0x0E3A 0xC1).
[ 3.438820] [drm] register mmio base: 0xFC900000
[ 3.438821] [drm] register mmio size: 1048576
[ 3.441945] [drm] add ip block number 0 <nv_common>
[ 3.441947] [drm] add ip block number 1 <gmc_v10_0>
[ 3.441947] [drm] add ip block number 2 <navi10_ih>
[ 3.441948] [drm] add ip block number 3 <psp>
[ 3.441948] [drm] add ip block number 4 <smu>
[ 3.441949] [drm] add ip block number 5 <dm>
[ 3.441950] [drm] add ip block number 6 <gfx_v10_0>
[ 3.441950] [drm] add ip block number 7 <sdma_v5_2>
[ 3.441951] [drm] add ip block number 8 <vcn_v3_0>
[ 3.441951] [drm] add ip block number 9 <jpeg_v3_0>
[ 3.441964] amdgpu 0000:2f:00.0: amdgpu: Fetched VBIOS from VFCT
[ 3.441966] amdgpu: ATOM BIOS: 113-D4120500-101
[ 3.441973] [drm] VCN(0) decode is enabled in VM mode
[ 3.441973] [drm] VCN(1) decode is enabled in VM mode
[ 3.441974] [drm] VCN(0) encode is enabled in VM mode
[ 3.441974] [drm] VCN(1) encode is enabled in VM mode
[ 3.441976] [drm] JPEG decode is enabled in VM mode
[ 3.441976] amdgpu 0000:2f:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
[ 3.442000] amdgpu 0000:2f:00.0: amdgpu: MEM ECC is not presented.
[ 3.442000] amdgpu 0000:2f:00.0: amdgpu: SRAM ECC is not presented.
[ 3.442008] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[ 3.442011] amdgpu 0000:2f:00.0: amdgpu: VRAM: 16368M 0x0000008000000000 - 0x00000083FEFFFFFF (16368M used)
[ 3.442013] amdgpu 0000:2f:00.0: amdgpu: GART: 512M 0x0000000000000000 - 0x000000001FFFFFFF
[ 3.442014] amdgpu 0000:2f:00.0: amdgpu: AGP: 267894784M 0x0000008400000000 - 0x0000FFFFFFFFFFFF
[ 3.442020] [drm] Detected VRAM RAM=16368M, BAR=16384M
[ 3.442021] [drm] RAM width 256bits GDDR6
[ 3.442057] [drm] amdgpu: 16368M of VRAM memory ready
[ 3.442057] [drm] amdgpu: 32114M of GTT memory ready.
[ 3.442067] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 3.442190] [drm] PCIE GART of 512M enabled (table at 0x0000008000300000).
[ 3.447513] amdgpu 0000:2f:00.0: amdgpu: PSP runtime database doesn't exist
[ 3.447516] amdgpu 0000:2f:00.0: amdgpu: PSP runtime database doesn't exist
[ 3.623958] intel_rapl_common: Found RAPL domain package
[ 3.623960] intel_rapl_common: Found RAPL domain core
[ 3.630682] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.027918] mc: Linux media interface: v0.10
[ 4.051959] Bluetooth: Core ver 2.22
[ 4.051973] NET: Registered PF_BLUETOOTH protocol family
[ 4.051974] Bluetooth: HCI device and connection manager initialized
[ 4.051976] Bluetooth: HCI socket layer initialized
[ 4.051977] Bluetooth: L2CAP socket layer initialized
[ 4.051979] Bluetooth: SCO socket layer initialized
[ 4.209672] usbcore: registered new interface driver btusb
[ 4.209714] usb 1-2: 1:3 : unsupported format bits 0x100000000
[ 4.289526] usbcore: registered new interface driver snd-usb-audio
[ 4.317761] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.317763] Bluetooth: BNEP filters: protocol multicast
[ 4.317765] Bluetooth: BNEP socket layer initialized
[ 4.465150] mousedev: PS/2 mouse device common for all mice
[ 5.492910] amdgpu 0000:2f:00.0: amdgpu: STB initialized to 2048 entries
[ 5.493233] [drm] Loading DMUB firmware via PSP: version=0x02020013
[ 5.495587] [drm] use_doorbell being set to: [true]
[ 5.495600] [drm] use_doorbell being set to: [true]
[ 5.495610] [drm] use_doorbell being set to: [true]
[ 5.495619] [drm] use_doorbell being set to: [true]
[ 5.496134] [drm] Found VCN firmware Version ENC: 1.24 DEC: 2 VEP: 0 Revision: 0
[ 5.496142] amdgpu 0000:2f:00.0: amdgpu: Will use PSP to load VCN firmware
[ 5.561046] [drm] reserve 0xa00000 from 0x8001000000 for PSP TMR
[ 5.690517] amdgpu 0000:2f:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[ 5.690537] amdgpu 0000:2f:00.0: amdgpu: smu driver if version = 0x00000040, smu fw if version = 0x00000041, smu fw program = 0, version = 0x003a5400 (58.84.0)
[ 5.690539] amdgpu 0000:2f:00.0: amdgpu: SMU driver if version not matched
[ 5.690567] amdgpu 0000:2f:00.0: amdgpu: use vbios provided pptable
[ 5.762288] amdgpu 0000:2f:00.0: amdgpu: SMU is initialized successfully!
[ 5.762485] [drm] Display Core initialized with v3.2.198!
[ 5.763739] [drm] DMUB hardware initialized: version=0x02020013
[ 5.766640] snd_hda_intel 0000:2f:00.1: bound 0000:2f:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 6.207925] [drm] kiq ring mec 2 pipe 1 q 0
[ 6.216446] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[ 6.216615] [drm] JPEG decode initialized successfully.
[ 6.217624] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[ 6.217740] amdgpu: sdma_bitmap: ffff
[ 6.264356] memmap_init_zone_device initialised 4194304 pages in 17ms
[ 6.264360] amdgpu: HMM registered 16368MB device memory
[ 6.264413] amdgpu: SRAT table not found
[ 6.264413] amdgpu: Virtual CRAT table created for GPU
[ 6.264559] amdgpu: Topology: Add dGPU node [0x73bf:0x1002]
[ 6.264562] kfd kfd: amdgpu: added device 1002:73bf
[ 6.264586] amdgpu 0000:2f:00.0: amdgpu: SE 4, SH per SE 2, CU per SH 10, active_cu_number 72
[ 6.264648] amdgpu 0000:2f:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 6.264649] amdgpu 0000:2f:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 6.264650] amdgpu 0000:2f:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 6.264650] amdgpu 0000:2f:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[ 6.264651] amdgpu 0000:2f:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[ 6.264652] amdgpu 0000:2f:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[ 6.264652] amdgpu 0000:2f:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[ 6.264653] amdgpu 0000:2f:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[ 6.264653] amdgpu 0000:2f:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[ 6.264654] amdgpu 0000:2f:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[ 6.264654] amdgpu 0000:2f:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[ 6.264655] amdgpu 0000:2f:00.0: amdgpu: ring sdma1 uses VM inv eng 13 on hub 0
[ 6.264655] amdgpu 0000:2f:00.0: amdgpu: ring sdma2 uses VM inv eng 14 on hub 0
[ 6.264656] amdgpu 0000:2f:00.0: amdgpu: ring sdma3 uses VM inv eng 15 on hub 0
[ 6.264656] amdgpu 0000:2f:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 1
[ 6.264657] amdgpu 0000:2f:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 1
[ 6.264658] amdgpu 0000:2f:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 1
[ 6.264659] amdgpu 0000:2f:00.0: amdgpu: ring vcn_dec_1 uses VM inv eng 5 on hub 1
[ 6.264659] amdgpu 0000:2f:00.0: amdgpu: ring vcn_enc_1.0 uses VM inv eng 6 on hub 1
[ 6.264660] amdgpu 0000:2f:00.0: amdgpu: ring vcn_enc_1.1 uses VM inv eng 7 on hub 1
[ 6.264661] amdgpu 0000:2f:00.0: amdgpu: ring jpeg_dec uses VM inv eng 8 on hub 1
[ 6.265686] amdgpu 0000:2f:00.0: amdgpu: Using BACO for runtime pm
[ 6.265976] [drm] Initialized amdgpu 3.48.0 20150101 for 0000:2f:00.0 on minor 0
[ 6.275921] fbcon: amdgpudrmfb (fb0) is primary device
[ 6.275923] fbcon: Deferring console take-over
[ 6.275924] amdgpu 0000:2f:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 6.327200] Bluetooth: hci0: command 0xfc05 tx timeout
[ 6.330515] Bluetooth: hci0: Reading Intel version command failed (-110)
[ 6.340931] [drm] DSC precompute is not needed.
[ 7.537698] kauditd_printk_skb: 200 callbacks suppressed
[ 7.537700] audit: type=1100 audit(1666729713.397:105): pid=1662 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="shihatsu" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 7.539120] audit: type=1101 audit(1666729713.397:106): pid=1662 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="shihatsu" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 7.539454] audit: type=1103 audit(1666729713.397:107): pid=1662 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="shihatsu" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 7.539487] audit: type=1006 audit(1666729713.397:108): pid=1662 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[ 7.539490] audit: type=1300 audit(1666729713.397:108): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffd33494870 a2=4 a3=7ffd33494584 items=0 ppid=1160 pid=1662 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" key=(null)
[ 7.539493] audit: type=1327 audit(1666729713.397:108): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746866343639653937612D396337312D346439642D383331322D366335613732323332373236002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
[ 7.579078] audit: type=1130 audit(1666729713.437:109): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.581953] audit: type=1101 audit(1666729713.440:110): pid=1664 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="shihatsu" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.581965] audit: type=1103 audit(1666729713.440:111): pid=1664 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="shihatsu" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 7.581985] audit: type=1006 audit(1666729713.440:112): pid=1664 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 10.033940] mlx4_core 0000:24:00.0: DMFS high rate steer mode is: disabled performance optimized steering
[ 10.034339] mlx4_core 0000:24:00.0: 31.504 Gb/s available PCIe bandwidth (8.0 GT/s PCIe x4 link)
[ 10.202119] mlx4_en: Mellanox ConnectX HCA Ethernet driver v4.0-0
[ 10.202327] mlx4_en 0000:24:00.0: Activating port:1
[ 10.205100] mlx4_en: 0000:24:00.0: Port 1: Using 32 TX rings
[ 10.205103] mlx4_en: 0000:24:00.0: Port 1: Using 16 RX rings
[ 10.206586] mlx4_en: 0000:24:00.0: Port 1: Initializing port
[ 10.208358] mlx4_en 0000:24:00.0: registered PHC clock
[ 10.210885] mlx4_core 0000:24:00.0 enp36s0: renamed from eth0
[ 10.219273] <mlx4_ib> mlx4_ib_add: mlx4_ib: Mellanox ConnectX InfiniBand driver v4.0-0
[ 10.221689] <mlx4_ib> mlx4_ib_add: counter index 1 for port 1 allocated 1
[ 10.295990] mlx4_en: enp36s0: Steering Mode 1
[ 10.328153] mlx4_en: enp36s0: Link Down
[ 12.590742] mlx4_en: enp36s0: Link Up
[ 12.590759] IPv6: ADDRCONF(NETDEV_CHANGE): enp36s0: link becomes ready
[ 12.667207] mlx4_en: enp36s0: Steering Mode 1
[ 12.698126] mlx4_en: enp36s0: Link Down
[ 12.755703] mlx4_en: enp36s0: Link Up
[ 13.446215] kauditd_printk_skb: 12 callbacks suppressed
[ 13.446218] audit: type=1131 audit(1666729719.304:123): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.803321] audit: type=1130 audit(1666729724.660:124): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.113857] sd 3:0:0:0: [sda] Synchronizing SCSI cache
[ 27.116835] sd 3:0:0:0: [sda] Stopping disk
[ 28.811840] audit: type=1131 audit(1666729734.670:125): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 34.324538] audit: type=1131 audit(1666729741.418:126): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 34.433890] audit: type=1334 audit(1666729741.528:127): prog-id=0 op=UNLOAD
[ 34.433894] audit: type=1334 audit(1666729741.528:128): prog-id=0 op=UNLOAD
[ 34.433896] audit: type=1334 audit(1666729741.528:129): prog-id=0 op=UNLOAD
[ 123.561270] audit: type=1131 audit(1666729830.652:130): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=libvirtd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 343.361960] audit: type=1100 audit(1666730050.455:131): pid=5762 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="shihatsu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 343.361965] audit: type=1101 audit(1666730050.455:132): pid=5762 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="shihatsu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 343.362294] audit: type=1110 audit(1666730050.455:133): pid=5762 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 343.363307] audit: type=1105 audit(1666730050.459:134): pid=5762 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 343.375532] audit: type=1106 audit(1666730050.469:135): pid=5762 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 343.375570] audit: type=1104 audit(1666730050.469:136): pid=5762 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 407.754321] audit: type=1101 audit(1666730114.849:137): pid=6178 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="shihatsu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 426.637970] audit: type=1101 audit(1666730133.733:138): pid=6286 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="shihatsu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 426.638333] audit: type=1110 audit(1666730133.733:139): pid=6286 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 426.639383] audit: type=1105 audit(1666730133.736:140): pid=6286 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 536.652425] audit: type=1106 audit(1666730243.751:141): pid=6286 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 536.652437] audit: type=1104 audit(1666730243.751:142): pid=6286 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 552.954187] audit: type=1101 audit(1666730260.055:143): pid=7041 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="shihatsu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 552.954570] audit: type=1110 audit(1666730260.055:144): pid=7041 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 552.955610] audit: type=1105 audit(1666730260.055:145): pid=7041 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 552.958539] audit: type=1106 audit(1666730260.058:146): pid=7041 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 552.958551] audit: type=1104 audit(1666730260.058:147): pid=7041 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 609.765625] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 609.767910] ata4.00: supports DRM functions and may not be fully accessible
[ 609.773311] ata4.00: supports DRM functions and may not be fully accessible
[ 609.777657] ata4.00: configured for UDMA/133
[ 609.787764] sd 3:0:0:0: [sda] Starting disk
[ 609.787946] ata4.00: Enabling discard_zeroes_data
[ 628.227312] sd 3:0:0:0: [sda] Synchronizing SCSI cache
[ 628.230497] sd 3:0:0:0: [sda] Stopping disk
[ 913.782485] audit: type=1130 audit(1666730620.887:148): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 913.782489] audit: type=1131 audit(1666730620.887:149): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1209.751932] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1209.754205] ata4.00: supports DRM functions and may not be fully accessible
[ 1209.759590] ata4.00: supports DRM functions and may not be fully accessible
[ 1209.764001] ata4.00: configured for UDMA/133
[ 1209.774107] sd 3:0:0:0: [sda] Starting disk
[ 1209.774267] ata4.00: Enabling discard_zeroes_data
[ 1228.298695] sd 3:0:0:0: [sda] Synchronizing SCSI cache
[ 1228.301903] sd 3:0:0:0: [sda] Stopping disk
[ 1403.443404] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1403.445863] ata4.00: supports DRM functions and may not be fully accessible
[ 1403.451261] ata4.00: supports DRM functions and may not be fully accessible
[ 1403.455651] ata4.00: configured for UDMA/133
[ 1403.465768] sd 3:0:0:0: [sda] Starting disk
[ 1403.465932] ata4.00: Enabling discard_zeroes_data
[ 1421.604704] sd 3:0:0:0: [sda] Synchronizing SCSI cache
[ 1421.607878] sd 3:0:0:0: [sda] Stopping disk
[ 1550.556790] audit: type=1100 audit(1666731257.666:150): pid=14535 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="shihatsu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1550.556854] audit: type=1101 audit(1666731257.666:151): pid=14535 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="shihatsu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1550.557247] audit: type=1110 audit(1666731257.666:152): pid=14535 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1550.558294] audit: type=1105 audit(1666731257.666:153): pid=14535 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1551.075211] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1551.077504] ata4.00: supports DRM functions and may not be fully accessible
[ 1551.082827] ata4.00: supports DRM functions and may not be fully accessible
[ 1551.087802] ata4.00: configured for UDMA/133
[ 1551.097950] sd 3:0:0:0: [sda] Starting disk
[ 1551.098130] ata4.00: Enabling discard_zeroes_data
[ 1551.104043] audit: type=1106 audit(1666731258.213:154): pid=14535 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1551.104073] audit: type=1104 audit(1666731258.213:155): pid=14535 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1558.377688] audit: type=1101 audit(1666731265.486:156): pid=14595 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="shihatsu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1558.378085] audit: type=1110 audit(1666731265.486:157): pid=14595 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1558.379167] audit: type=1105 audit(1666731265.490:158): pid=14595 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1558.721616] audit: type=1106 audit(1666731265.830:159): pid=14595 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1558.721637] audit: type=1104 audit(1666731265.830:160): pid=14595 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1569.155647] sd 3:0:0:0: [sda] Synchronizing SCSI cache
[ 1569.158856] sd 3:0:0:0: [sda] Stopping disk
[ 1583.898602] audit: type=1101 audit(1666731291.010:161): pid=14752 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="shihatsu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1583.899004] audit: type=1110 audit(1666731291.010:162): pid=14752 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1583.900166] audit: type=1105 audit(1666731291.010:163): pid=14752 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1583.922335] audit: type=1106 audit(1666731291.033:164): pid=14752 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1583.922346] audit: type=1104 audit(1666731291.033:165): pid=14752 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1614.258865] audit: type=1101 audit(1666731321.370:166): pid=14935 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="shihatsu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1614.259231] audit: type=1110 audit(1666731321.370:167): pid=14935 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1614.260385] audit: type=1105 audit(1666731321.370:168): pid=14935 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1614.282327] audit: type=1106 audit(1666731321.393:169): pid=14935 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1614.282336] audit: type=1104 audit(1666731321.393:170): pid=14935 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1752.423048] audit: type=1101 audit(1666731459.531:171): pid=15771 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="shihatsu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1752.423452] audit: type=1110 audit(1666731459.535:172): pid=15771 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1752.424495] audit: type=1105 audit(1666731459.535:173): pid=15771 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1752.431012] audit: type=1106 audit(1666731459.541:174): pid=15771 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1752.431023] audit: type=1104 audit(1666731459.541:175): pid=15771 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1796.275493] audit: type=1101 audit(1666731503.385:176): pid=16031 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="shihatsu" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1796.275828] audit: type=1110 audit(1666731503.385:177): pid=16031 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 1796.276891] audit: type=1105 audit(1666731503.389:178): pid=16031 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
journal shows no obvious “new” error, just the same that I had from the beginning:
journalctl -b -p err..alert
Okt 25 22:28:28 Neuromancer kernel: ucsi_ccg 0-0008: failed to get FW build information
Okt 25 22:28:32 Neuromancer kernel: Bluetooth: hci0: command 0xfc05 tx timeout
Okt 25 22:28:32 Neuromancer kernel: Bluetooth: hci0: Reading Intel version command failed (-110)
Okt 25 22:28:33 Neuromancer sddm-helper[1662]: gkr-pam: couldn't unlock the login keyring.
So… what am I supposed to do now? The system is ultra slow, plasma fires up on thread to 100%, every click takes like literally 10s of seconds to register. Doing this posting has taken me like 20 minutes, I don’t kid you.
