Hello there
After a recent system update (Sorry, don’t precisely know which ): ) plasma desktop keeps crashing. I usually notice this by my CPU indicator in my panel getting stuck, or other features like spectacle, the clock, clipboard menu or color picker not working either.
The issues resolve themselves after a minute or two. I haven’t noticed any pattern surrounding the hiccups, altough they do seem to occur somewhat more frequently under higher CPU loads, but still regularly under low load.
When resuming everything that happened in the mean time comes back, notifications, clipboard manager, etc.
I can’t find any relevant logs in journalctl, neither before nor after, so I’m unsure what to luck for.
Any help would be appreciated (:
System info inxi -zv8:
Kernel: 6.18.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
root=UUID=5fa01e4b-a809-40e9-9fab-e5e13186db22 rw rootflags=subvol=@
resume=UUID=5fa01e4b-a809-40e9-9fab-e5e13186db22 resume_offset=3155200
Desktop: KDE Plasma v: 6.5.6 tk: Qt v: N/A info: frameworks v: 6.24.0
wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Laptop System: Dell product: XPS 15 9520 v: N/A
Mobo: Dell model: 0YD3W1 v: A00 serial: <superuser required> part-nu: 0B19
uuid: <superuser required> Firmware: UEFI vendor: Dell v: 1.37.0
date: 10/27/2025
ID-1: BAT0 charge: 68 Wh (100%) condition: 68/84.9 Wh (80%) health: good
temp: 27.3 C volts: 12.67 min: 11.4 model: SMD-COS3.82 DELL 70N2F95
made: 2025-04-26 type: Li-poly serial: <filter> charging: status: full
control: start: 50% end: 90% type: trickle
avail: adaptive,custom,fast,standard,trickle cycles: N/A
Device-1: hidpp_battery_2 model: Logitech MX Master 3S serial: <filter>
charge: 85% rechargeable: yes status: discharging
System RAM: total: 32 GiB available: 31.01 GiB used: 17.14 GiB (55.3%)
Device-1: DIMM A type: DDR5 detail: synchronous size: 16 GiB
speed: 4800 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: 80AD000080AD part-no: HMCG78MEBSA095N serial: <filter>
Device-2: DIMM B type: DDR5 detail: synchronous size: 16 GiB
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x43B
Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
desc: 1x24 MiB
Speed (MHz): avg: 400 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 107520
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
built: 2021-22+ ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2 chip-ID: 0c45:6732
class-ID: 0e02
alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x06b3 built: 2021 res: mode: 1920x1200
hz: 60 scale: 100% (1) dpi: 145 gamma: 1.2 chroma: red: x: 0.651 y: 0.329
green: x: 0.286 y: 0.635 blue: x: 0.145 y: 0.055 white: x: 0.314 y: 0.329
size: 336x210mm (13.23x8.27") diag: 396mm (15.6") ratio: 16:10
modes: 1920x1200
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (ADL
GT2) device-ID: 8086:46a6 memory: 30.29 GiB unified: yes display-ID: :1.0
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.18.18-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
IF-ID-1: br-4c8570e7ba6a state: down mac: <filter>
IF-ID-2: br-96ebd357a1ef state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: veth9f544d3 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: virbr0 state: down mac: <filter>
Info: services: NetworkManager, nginx, smbd, systemd-timesyncd,
wpa_supplicant
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 953.87 GiB used: 287 GiB (30.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN810
NVMe WDC 1024GB size: 953.87 GiB block-size: physical: 512 B
fw-rev: 61912523 temp: 29.9 C scheme: GPT
ID-1: / raw-size: 388.62 GiB size: 388.62 GiB (100.00%)
used: 286.88 GiB (73.8%) fs: btrfs dev: /dev/nvme0n1p8 maj-min: 259:8
label: N/A uuid: 5fa01e4b-a809-40e9-9fab-e5e13186db22
ID-2: /boot/efi raw-size: 240 MiB size: 236 MiB (98.33%)
used: 123 MiB (52.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: ESP
uuid: B04E-8C15
ID-3: /home raw-size: 388.62 GiB size: 388.62 GiB (100.00%)
ID-4: /swap raw-size: 388.62 GiB size: 388.62 GiB (100.00%)
ID-5: /var/cache raw-size: 388.62 GiB size: 388.62 GiB (100.00%)
ID-6: /var/log raw-size: 388.62 GiB size: 388.62 GiB (100.00%)
ID-1: swap-1 type: file size: 32 GiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 542.47 GiB fs: ntfs label: OS
uuid: 1AD052A0D05281C5
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 990 MiB fs: ntfs
label: WINRETOOLS uuid: 1226034F26033371
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 18.01 GiB fs: ntfs label: Image
uuid: 6E34039D34036783
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1.42 GiB fs: ntfs
label: DELLSUPPORT uuid: 583E96D93E96B00C
ID-6: /dev/nvme0n1p7 maj-min: 259:7 size: 2 GiB fs: ext4 label: N/A
uuid: e3e7fbaa-254f-4cd6-9b56-d252db49ceeb
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-6:2 info: Microdia Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0c45:6732 class-ID: 0e02
Device-2: 3-9:11 info: Shenzhen Goodix Fingerprint USB Device
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 27c6:63ac class-ID: ef00 serial: <filter>
Device-3: 3-10:4 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
System Temperatures: cpu: 35.0 C mobo: 27.0 C sodimm: 26.0 C
Fan Speeds (rpm): cpu: 0 fan-2: 0
Packages: 1665 pm: pacman pkgs: 1635 libs: 411 tools: pamac,yay pm: flatpak
pkgs: 30
1: https://mirror.fcix.net/manjaro/stable/$repo/$arch
2: https://mirror.easyname.at/manjaro/stable/$repo/$arch
3: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
4: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
5: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
6: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
7: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
8: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
9: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
10: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
11: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
12: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
13: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
14: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
15: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
16: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
17: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
18: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
19: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
20: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
21: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
22: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
23: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
24: https://muug.ca/mirror/manjaro/stable/$repo/$arch
25: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
26: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
27: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
28: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
29: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
30: https://manjaro.grena.ge/stable/$repo/$arch
31: https://linorg.usp.br/manjaro/stable/$repo/$arch
32: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
33: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
34: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
35: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
36: https://mirror.init7.net/manjaro/stable/$repo/$arch
37: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
38: https://mirror.23m.com/manjaro/stable/$repo/$arch
39: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
40: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
41: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
42: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
43: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
44: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
45: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
46: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
47: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
48: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
49: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
50: https://mirrors2.manjaro.org/stable/$repo/$arch
51: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
52: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
53: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
54: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
55: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
56: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
57: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
58: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
59: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
60: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
61: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
62: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
63: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
64: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
65: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
66: https://manjaro.ynh.ovh/stable/$repo/$arch
67: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
68: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
69: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
70: https://mirrors.manjaro.org/repo/stable/$repo/$arch
71: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
72: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
73: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
74: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
75: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
76: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
77: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
78: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 477
1: cpu: 9.6% command: firefox pid: 18379 mem: 165.0 MiB (0.5%)
2: cpu: 4.0% command: qemu-system-x86_64 pid: 2548
mem: 12412.0 MiB (39.0%)
3: cpu: 3.4% command: firefox pid: 18532 mem: 82.9 MiB (0.2%)
4: cpu: 2.2% command: firefox pid: 3900 mem: 764.1 MiB (2.4%)
5: cpu: 1.4% command: firefox pid: 4219 mem: 67.9 MiB (0.2%)
Memory top: 5 of 477
1: mem: 12412.0 MiB (39.0%) command: qemu-system-x86_64 pid: 2548
cpu: 4.0%
2: mem: 764.1 MiB (2.4%) command: firefox pid: 3900 cpu: 2.2%
3: mem: 619.9 MiB (1.9%) command: plasmashell pid: 15329 cpu: 0.1%
4: mem: 456.3 MiB (1.4%) command: firefox pid: 4534 cpu: 0.2%
5: mem: 410.7 MiB (1.2%) command: firefox pid: 13197 cpu: 0.3%
Processes: 477 Power: uptime: 13h 22m states: freeze,mem,disk
suspend: s2idle wakeups: 6 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.34 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 259 default: graphical tool: systemctl
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: yakuake inxi: 3.3.40
