I can see that my latest nvidia driver version is 470.42.01
. After installing plasma-wayland-session
I restart my pc and tried to login with wayland. But PC gets stuck at loading screen. And it barely manage to go desktop. And it gets very laggy and stuck in desktop.
Is Plasma usable in wayland?
Kernel: 5.10.49-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.22.3 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: X550JK v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X550JK v: 1.0 serial: <filter>
UEFI: American Megatrends v: X550JK.304 date: 04/16/2019
ID-1: BAT0 charge: 4.0 Wh (97.6%) condition: 4.1/32.6 Wh (12.5%)
volts: 14.8 min: 14.8 model: ASUSTeK X550A30 status: Not charging
Info: Dual Core model: Intel Core i5-4200H bits: 64 type: MT MCP
arch: Haswell rev: 3 cache: L2: 3 MiB
bogomips: 22359
Speed: 2874 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 2874 2: 2888
3: 2901 4: 2994
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM107M [GeForce GTX 850M] vendor: ASUSTeK driver: nvidia
v: 470.42.01 bus-ID: 01:00.0
Device-3: Realtek USB Camera type: USB driver: uvcvideo bus-ID: 1-7:6
Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting,nvidia
resolution: 1: 1366x768~60Hz 2: 1600x900~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 21.1.4 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Sound Server-1: ALSA v: k5.10.49-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.31 running: no
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: AzureWave driver: ath9k v: kernel port: e000 bus-ID: 03:00.0
IF: wlp3s0 state: down mac: <filter>
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 04:00.1
IF: enp4s0f1 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: IMC Networks type: USB driver: btusb v: 0.8 bus-ID: 1-5:7
Local Storage: total: 1.93 TiB used: 41.2 GiB (2.1%)
ID-1: /dev/sda vendor: Western Digital model: WDS120G2G0A-00JH30
ID-2: /dev/sdb vendor: Seagate model: ST1000LM024 HN-M101MBB
ID-3: /dev/sdc type: USB vendor: Western Digital
model: WD My Passport 0827 size: 931.48 GiB
ID-1: / size: 109.19 GiB used: 15.23 GiB (13.9%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/sda1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 86.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3900
Processes: 195 Uptime: 5m Memory: 7.65 GiB used: 2.24 GiB (29.2%)
Init: systemd Compilers: gcc: 11.1.0 Packages: 1215 Shell: Bash v: 5.1.8
inxi: 3.3.05
