Plasma desktop broken after update
i’m using testing branch
i wanted to update plasma to version 6 from teminal with this command:
sudo pacman -S plasma-workspace plasma-desktop gwenview dolphin baloo-widgets kate poppler-glib poppler-qt5
i wlways get a list of files that cannot be written
so i’ve added this to that command:
--overwrite '*'
after rebooting the plasma desktop gui is not working
i tried to make a full system upgrade but i get an error:
sudo pacman -Syu
[sudo] password for pc:
 core is up to date
 extra is up to date
 multilib is up to date
:: Replace breeze with extra/breeze5? [Y/n] y
y:: Replace ksysguard with extra/plasma-systemmonitor? [Y/n] y
warning: libkiwix: local (13.0.0-1) is newer than extra (12.1.1-2)
:: Replace oxygen with extra/oxygen5? [Y/n] y
:: Replace plasma-integration with extra/plasma5-integration? [Y/n] y
:: Replace plasma5-themes-breath with extra/plasma6-themes-breath? [Y/n] y
:: Replace plasma5-themes-breath-migration with extra/plasma6-themes-breath-migration? [Y/n] y
warning: plymouth: local (24.004.60-7) is newer than extra (22.02.122-17)
resolving dependencies...
:: removing plasma-integration breaks dependency 'plasma-integration' required by plasma-workspace
yes ? read questions :wink: if no version in package name, version is for (kde) 6
yes you are right. but the problem is with:
that error is shown in pamac-manager also
edit: after i choosed no to that questions the problem seems to disappear now it takes me to downloading the files
i will truy it and tell you
thank you
That doesnt make much sense.
When we upgrade, we upgrade everything.
Otherwise you are attempting for a ‘partial upgrade’ which is equal to broken.
Rarely, if ever, should you use this.
There we go. Use this.
Now I am extra confused.
That’s not how you upgrade system. It is, however, how you do a partial upgrade and break stuff. Also, at one point you had to use -Sy.
Anyway, no idea why plasma5-integration would want to replace plasma-integration. Say no to it. And double check if your mirror is synced.
yes plasma-workspace (6) require plasma-integration (6) and not plasma5-integration
I also had these inversions … :thinking: pacman sorts packages alphabetically to resolve conflicts ?
Yeah but they said they entered ‘no’ and it was able to continue…
(skipping all the other mishandling etc … that doesnt make sense to me)
i have a problem when trying a full upgrade
after few minutes the screen turns off and i cant turn it on again to see what is happening because of broken GUI
is there a command that i can run to prevent the system to lock the screen?
Plasma has manual sleep inhibition in the panel, through ‘presentation mode’ etc.
(click on the display or power tray icons)
You can can also do upgrades through the TTY.
Since the update to Plasma 6 is rather hefty … an abundance of caution can make sense … such as using default (breeze) themes, removing extra widgets, clearing cache, and/or resetting configurations entirely. In some situations one or more of these things may be required for a functional desktop.
i used the TTY to update the system and after updating and restarting the plasma is working again
thank you
