Plasma 6: KWallet hangs and Dolphin SFTP fails — missing Secret Service backend?
I’m running Manjaro with Plasma 6.3.5 and I’ve hit an issue where Dolphin hangs for a long time when trying to open an SFTP bookmark. I also noticed KWalletManager hangs and fails to open.
Digging into it, I found this error:
An error occurred when connecting to the KWallet service:
Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
I checked the process:
ps -ef | grep kwalletd
It shows kwalletd6 is running, but when I run it manually with debugging:
KWALLET_DAEMON_DEBUG=1 kwalletd6
…I get repeating messages like:
libsecret-CRITICAL **: secret_service_load_collections_sync: assertion 'paths != NULL' failed kf.wallet.kwalletd: "Could not connect to Secret Service"
From what I gather, kwalletd6 now expects a working Secret Service backend (like ksecrets or gnome-keyring), but I can’t find any ksecrets package in the Manjaro or Arch repos.
So my questions are:
  • Is this a known Plasma 6 issue in Manjaro right now?
  • Should I be installing gnome-keyring as a workaround to provide the missing Secret Service?
  • Is there an ETA or plan to package ksecrets properly for Plasma 6 users?
Thanks in advance — just trying to confirm the “right” fix before I start patching things with GNOME components.
It was, and had you paid attention to the (previous) Stable Updates thread and/or looked around on the forum, then you would have known that it was solved by downgrading kwallet.
But that’s all academic now, because there was another Stable Update today, and everything should now work as desired.
No, you should update your system instead.
Yes. It’s today. :grin:
❱sudo pacman -Syyuu
:: Synchronising package databases...
 core        144.3 KiB   768 KiB/s 00:00 [#############################################################] 100%
 extra        8.4 MiB  7.02 MiB/s 00:01 [#############################################################] 100%
 multilib        147.9 KiB   913 KiB/s 00:00 [#############################################################] 100%
 there is nothing to do
try all the aur’s too, worth a look.
❱yay
 core is up to date
 extra is up to date
 multilib is up to date
:: Searching AUR for updates...
 -> xerox-phaser-6000-6010: ignoring package upgrade (1.01-3 => 1.01_20110222-1)
:: Checking development packages...
:: Searching databases for updates...
 -> Flagged Out Of Date AUR Packages: debtap  nuitka
I already had the update for today (this morning), that was when i first noticed it after that.
What is the output of… :point_down:
pacman -Qi kwallet
❱pacman -Qi kwallet
Version : 6.14.0-2
Description : Secure and unified container for user passwords
Architecture : x86_64
URL : Frameworks - KDE Community Wiki
Licenses : LGPL-2.0-only LGPL-3.0-only
Groups : kf6
Provides : org.freedesktop.secrets
Depends On : gcc-libs glib2 glibc gpgme kcolorscheme kconfig kcoreaddons kcrash kdbusaddons ki18n knotifications kwidgetsaddons kwindowsystem libgcrypt
libsecret qca-qt6 qt6-base
Optional Deps : kwalletmanager: Configuration GUI [installed]
Required By : kaccounts-integration kio ksshaskpass kwallet-pam kwalletmanager libksane okular plasma-nm plasma-workspace signon-kwallet-extension
Optional For : git libsecret vlc
Conflicts With : None
Replaces : None
Installed Size : 2.57 MiB
Packager : Peter Jung ptr1337@archlinux.org
Build Date : Fri 16 May 2025 10:22:44 BST
Install Date : Fri 16 May 2025 22:44:23 BST
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : Signature
Well, that is the correct version. As I gather, the introduction of the secrets daemon — I think it’s called ksecretsdshould have been in this update of KDE Frameworks, but I don’t have it on my system either, and over here, I am not having any problems. But then again, I also don’t have any sftp bookmarks. :thinking:
I do however use kmail, and chromium also depends on kwallet, and both of those work normally.
Hmm… :thinking:
hmm, well its not just the sftp, i can’t access my wallet (the wallet manger) at all. Its odd though as I’d have thought my wifi would “complain” (but it don’t) as would other things that have passwords in there but its just the dolphin sftp credentials that are hanging but the sftp does actually connect after a long long while so it is getting the login data at some point.
Yea iv searched ksecretsd & ksecrets but nothing…
I’ve put a link to this thread on the Stable Updates thread, given that this may have been an oversight in the package selection. I don’t really know what else I can do. :face_with_diagonal_mouth: :man_shrugging:
Thank you @Aragorn :slight_smile:
By the way, it’s called ksecretd, and it’s located in /usr/bin. But it may have crashed on your system.
well its a bit over my head.
❱yay ksecretd
⎼⎼⎼⎼⎼⎼⎼⎼⎼⎼ /home/greg ⎼⎼⎼⎼⎼⎼⎼⎼⎼⎼
❱sudo systemctl status ksecretd
Unit ksecretd.service could not be found.
4
❱lsp ksecretd
greg        2663  0.0  0.2 802236 79300 ?        SLsl 19:40   0:01 /usr/bin/ksecretd
❱yay -Qi ksecretd
error: package 'ksecretd' was not found
1
The binary exists and is running. its not a systemd service (not sure if its supposed to be). Does not show up in any package management.
Would downgrading kwallet work still? i mean im not really in a hurry to be using sftp atm, i can just wait and see what happens.
No, it’s part of the KDE Frameworks and it’s started by kwallet. It’s not a systemd thing. :wink:
No, not anymore now that Frameworks has been updated.
well this is quite frustrating though, I cant access my nas very easily. what exactly am i waiting for? who do i speak to?
GPT keeps saying to install gnome-keyring?
I tried downgrading kwallet and then upgrading it again but didn’t work.
is there any way to even get my passwords from the wallet?
maybe i roll-back the whole os to before the upgrade and don’t update kwallet ?
… and refreshing the list of mirrors and then running a full update again isn’t possible or doesn’t work?
❱sudo pacman-mirrors --fasttrack
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
  0.224 United_Kingdom : https://ask4.mm.fcix.net/manjaro/
  0.107 United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/
  0.132 United_Kingdom : http://manjaro.mirrors.uk2.net/
::INFO Writing mirror list
::United_Kingdom  : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
::United_Kingdom  : http://manjaro.mirrors.uk2.net/stable/$repo/$arch
::United_Kingdom  : https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
❱sudo pacman -Syyu
 core        144.4 KiB   897 KiB/s 00:00 [#############################################################] 100%
 extra        8.4 MiB  7.68 MiB/s 00:01 [#############################################################] 100%
 multilib        147.9 KiB   973 KiB/s 00:00 [#############################################################] 100%
I am having the same problem searching for a solution.
I don’t know what you have done since this post but you can open kwallet manual to access your nas (assuming you have kwalletmanager installed)
Sorry, im dumb. How do i open kwallet manual/manually?
Iv been looking at 458085 – Wallet system takes about 1 minute to start
Open application launcher and search for kwalletmanager, in that application you will find a buton ‘Open’
oh yea iv tried the GUI route already, it don’t work. Clicking the sidebar “KDE Wallet” hangs for a minute before showing any GUI widgets at all, then if i click on “Launch Wallet Manager” it hangs for another minute and then opens a blank window.
If i just try to run kwalletmanager from the main GUI menu it does much the same, it hangs for a minute and then opens a blank window.
OK, that’s another problem. Seems like there are some different problems related to kwallet floating around.
